Hi all,
I’ve written an Edge LAN driver for an appliance and have a discovery mechanism working for it which scans the network and creates a device for the discovered appliance - great so far.
I want to store the IP address (and possibly other settable properties of the discovered device) in the device properties such that the user can later go and view/change them, like if the IP changes after a reboot, or they want to view/change the appliance’s screen brightness.
However, I’ve not been able to do this - I’ve tried setting the preferences string (containing the IP for the discovered device in an appropriate field) in the metadata passed to try_create_device(metadata)
I‘ve also tried later setting it by calling device:try_update_metadata({ preferences = pref_json }) but neither of those end up setting the preference value, such that when I open the settings page in the app, the fields are all still blank (the default).
How can I set values for preferences on discovery, but still allow the user to go view/change them later?
If preferences are not programmatically settable, how else can I achieve the desired capability?
Thanks,
John
