(EDGE Driver-Mc): Zigbee Temp Sensor and Child Thermostat Mc, Zigbee Temp Sensor with Thermostat Mc
(NEW RELEASE) New Version 2.5 of Edge Beta Driver: Zigbee Temp Humidity Sensor Mc:
Improvements:
  1. Added new profile with Temperature, RelativeHumidity, Atmospheric Pressure in (kPa & mBar) and Illuminance
  2. Added report interval settings in preferences for all capabilities
    Note: Not all devices accept configuration changes after pairing
  3. For some manufacturers added new subdriver to Battery voltage handler @Raimundo
  4. New devices added
  - id: "KMPCIL/sensor"
    deviceLabel: Environment Sensor
    manufacturer: KMPCIL
    model: RES001
    deviceProfileName: temp-humid-press-illumin
  - id: "KMPCIL/BME280"
    deviceLabel: Environment Sensor BME280
    model: RES001BME280
  - id: "KMPCIL/RES005"
    deviceLabel: Environment Sensor RES005
    model: RES005
As the new version has new Custom Capabilities, Profile and preferences, the update is not performed automatically, it will be done by changing the driver on the device, driver menu, select another driver.
To facilitate the update, I am going to change version 2.0 to the name Zigbee Temp Humidity Sensor Mc-(OLD).
I will publish the new version 2.5 with the original name Zigbee Temp Humidity Sensor Mc.
In this way, your driver installed will have the rename with (OLD), indicating that there is a new version available and you can install the new version with a driver change whenever you want.
