(NEW RELEASE) Version 2.0 of Edge Driver Zigbee Temp Sensor and Thermostat Mc:
Improvements and bug fixes:
- As the driver runs locally, I have added corrections to prevent the temperature control Timer stopping, if a Reboot HUB occurs and the thermostat is running.
When the Hub is back online, it will continue to work with the settings it had.
This could happen unintentionally during a Hub firmware update. - Added in preferences an adjustment for Underfloor Heating installation with the No, Heat (Heat only) and Heat & Cool options.
- With this option the temperatures of the change to the Heating and / or Cooling state are corrected, to bring them closer to the set point Heat and Cool. In this way it begins to heat or cool earlier than in other air conditioning systems, to compensate that the underfloor heating system has more thermal inertia and takes longer to heat and cool the floor.
To facilitate the update, I am going to change version 1.0 to the name Zigbee Temp Sensor and Thermostat Mc (OLD).
I will publish the new version 2.0 with the original name Zigbee Temp Sensor and Thermostat Mc.
In this way, your driver installed will have the name with (OLD), indicating that there is a new version available and you can install the new version with a driver change whenever you want.
Devices added to driver:
- id: "SmartThings-Motion-Sensor"
deviceLabel: ST Motion Sensor
manufacturer: Samjin
model: motion
deviceProfileName: motion-temp-therm-battery
- id: "lumi.weather"
deviceLabel: Aqara Weather
manufacturer: LUMI
model: lumi.weather
deviceProfileName: temp-humid-press-therm-battery
- id: "TUYATEC/RH3052"
deviceLabel: TUYATEC RH3052
manufacturer: TUYATEC-prhs1rsd
model: RH3052
deviceProfileName: temp-humid-therm-battery
