(EDGE Driver-Mc) Zigbee switch MC, Zigbee switch power MC, Zigbee multi switch and child MC
Mariano,
Power reporting is off by a factor of 1000.
It is reporting 12.4 kW when it should be reporting 12.4 W.
Yes, it is an error that was reported by @philh30 in the latest edge libraries, they corrected the energy consumed and damaged the power
Let’s hope they fix it soon
You can get proper scaling in your driver by copying the default handler into the driver and correcting the error.
I thought they were going to fix it before and keep the default handlers
I am going to publish a version to correct the power, which has the error in the default libraries and multiplies it by 1000.
Please tell me if it works fine.
When they fix it I’ll modify it again.
│ Name        │ Zigbee Switch Power Mc               │
│ Version     │ 2022-03-11T19:00:28.118155           │
Da questa mattina, nessuno dei miei 4 switch
414AcfSkjDL.AC_SL1500
They do not work more than n this drive, all the other switch in the house work. The problem is that only these 4 use edge drives, so the problem could be the drive, but also the devices. I’m trying to find out which one. Does it all work well for you?
Yes, all is working fine
Mariano,
I got the update and it is still reading 12.4 kW instead of correct 12.4 W.
I think it must be because it does not perform the configuration when updating the new version.
In the new version it should work.
Please, if it doesn’t work, could you send me a log of the installation of the new version?
│ Version     │ 2022-03-12T11:07:22.571217           │
I am currently out of town. When I get back I can re-pare it and post the log.
I don’t know if it can help, maybe just a coincidence, but they worked until I updated the edge drive, then that’s it, but they kept staying online. Today I tried to delete one of them, and then reach it… Surprise, all sorted out. They all started working perfectly again. :man_shrugging:t2:
Mariano,
I deleted and repaired the CentraLite (Iris) plug. It is still reading power in kW instead of watts. 8.5 kW instead in 8.5 W. The following are the paring logs:
2022-03-14T16:02:41.695321796+00:00 TRACE Zigbee Switch Power Mc Setup driver Zigbee_Switch with lifecycle handlers:
DeviceLifecycleDispatcher: Zigbee_Switch
default_handlers:
infoChanged:
init:
doConfigure:
removed:
driverSwitched:
child_dispatchers:
2022-03-14T16:02:41.701177046+00:00 TRACE Zigbee Switch Power Mc Setup driver Zigbee_Switch with Capability handlers:
CapabilityCommandDispatcher: Zigbee_Switch
default_handlers:
energyMeter:
resetEnergyMeter
legendabsolute60149.randomOnOff2:
setRandomOnOff
refresh:
refresh
switchLevel:
setLevel
legendabsolute60149.getGroups:
setGetGroups
switch:
on
off
child_dispatchers:
2022-03-14T16:02:41.706385796+00:00 TRACE Zigbee Switch Power Mc Setup driver Zigbee_Switch with Zigbee handlers:
ZigbeeMessageDispatcher: Zigbee_Switch
default_handlers:
attr:
ZclClusterAttributeValueHandler: cluster: ElectricalMeasurement, attribute: ACPowerMultiplier
ZclClusterAttributeValueHandler: cluster: ElectricalMeasurement, attribute: ACPowerDivisor
ZclClusterAttributeValueHandler: cluster: ElectricalMeasurement, attribute: ActivePower
ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
ZclClusterAttributeValueHandler: cluster: SimpleMetering, attribute: InstantaneousDemand
ZclClusterAttributeValueHandler: cluster: SimpleMetering, attribute: Multiplier
ZclClusterAttributeValueHandler: cluster: SimpleMetering, attribute: Divisor
ZclClusterAttributeValueHandler: cluster: SimpleMetering, attribute: CurrentSummationDelivered
ZclClusterAttributeValueHandler: cluster: Level, attribute: CurrentLevel
global:
ZclGlobalCommandHandler: cluster: OnOff, command: DefaultResponse
cluster:
ZclClusterCommandHandler: cluster: Groups, command: GetGroupMembership
ZclClusterCommandHandler: cluster: SimpleMetering, command: 0x400
zdo:
child_dispatchers:
2022-03-14T16:02:41.741277462+00:00 TRACE Zigbee Switch Power Mc Received event with handler _resync
2022-03-14T16:02:41.744510796+00:00 TRACE Zigbee Switch Power Mc Received event with handler environment_info
2022-03-14T16:02:41.754350087+00:00 TRACE Zigbee Switch Power Mc Found DeviceLifecycleDispatcher handler in Zigbee_Switch
2022-03-14T16:02:41.760924212+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 7d90c215-996c-4646-8b9a-ebd3c33e344e [0x5053] (CentraLite Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x5053, dest_endpoint: 0x01, profile: 0x0104, cluster: ElectricalMeasurement >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x050B > > >
2022-03-14T16:02:41.768402546+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 7d90c215-996c-4646-8b9a-ebd3c33e344e [0x5053] (CentraLite Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x5053, dest_endpoint: 0x01, profile: 0x0104, cluster: SimpleMetering >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0400 > > >
2022-03-14T16:02:41.788149587+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 7d90c215-996c-4646-8b9a-ebd3c33e344e [0x5053] (CentraLite Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x5053, dest_endpoint: 0x01, profile: 0x0104, cluster: SimpleMetering >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0000 > > >
2022-03-14T16:02:41.797149629+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 7d90c215-996c-4646-8b9a-ebd3c33e344e [0x5053] (CentraLite Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x5053, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0000 > > >
2022-03-14T16:02:41.805982379+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 7d90c215-996c-4646-8b9a-ebd3c33e344e [0x5053] (CentraLite Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x5053, dest_endpoint: 0x01, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: 000D6F000CA60D98, src_endpoint: 0x01, cluster: ElectricalMeasurement, dest_addr_mode: 0x03, dest_address: D052A8A36DA80001, dest_endpoint: 0x01 > > >
2022-03-14T16:02:41.824538546+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 7d90c215-996c-4646-8b9a-ebd3c33e344e [0x5053] (CentraLite Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x5053, dest_endpoint: 0x01, profile: 0x0104, cluster: ElectricalMeasurement >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x050B, DataType: Int16, minimum_reporting_interval: 0x0001, maximum_reporting_interval: 0x0E10, reportable_change: 1 > > > >
2022-03-14T16:02:41.843894379+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 7d90c215-996c-4646-8b9a-ebd3c33e344e [0x5053] (CentraLite Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x5053, dest_endpoint: 0x01, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: 000D6F000CA60D98, src_endpoint: 0x01, cluster: SimpleMetering, dest_addr_mode: 0x03, dest_address: D052A8A36DA80001, dest_endpoint: 0x01 > > >
2022-03-14T16:02:41.853949921+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 7d90c215-996c-4646-8b9a-ebd3c33e344e [0x5053] (CentraLite Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x5053, dest_endpoint: 0x01, profile: 0x0104, cluster: SimpleMetering >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x0400, DataType: Int24, minimum_reporting_interval: 0x0001, maximum_reporting_interval: 0x0E10, reportable_change: 1 > > > >
2022-03-14T16:02:41.874388921+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 7d90c215-996c-4646-8b9a-ebd3c33e344e [0x5053] (CentraLite Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x5053, dest_endpoint: 0x01, profile: 0x0104, cluster: SimpleMetering >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x0000, DataType: Uint48, minimum_reporting_interval: 0x0005, maximum_reporting_interval: 0x0E10, reportable_change: 0x000000000001 > > > >
2022-03-14T16:02:41.887090546+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 7d90c215-996c-4646-8b9a-ebd3c33e344e [0x5053] (CentraLite Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x5053, dest_endpoint: 0x01, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: 000D6F000CA60D98, src_endpoint: 0x01, cluster: OnOff, dest_addr_mode: 0x03, dest_address: D052A8A36DA80001, dest_endpoint: 0x01 > > >
2022-03-14T16:02:41.902299254+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 7d90c215-996c-4646-8b9a-ebd3c33e344e [0x5053] (CentraLite Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x5053, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x0000, DataType: Boolean, minimum_reporting_interval: 0x0000, maximum_reporting_interval: 0x012C > > > >
2022-03-14T16:02:41.910547129+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 7d90c215-996c-4646-8b9a-ebd3c33e344e [0x5053] (CentraLite Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x5053, dest_endpoint: 0x01, profile: 0x0104, cluster: ElectricalMeasurement >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0605 > > >
2022-03-14T16:02:41.926689421+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 7d90c215-996c-4646-8b9a-ebd3c33e344e [0x5053] (CentraLite Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x5053, dest_endpoint: 0x01, profile: 0x0104, cluster: ElectricalMeasurement >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0604 > > >
2022-03-14T16:02:41.946221046+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 7d90c215-996c-4646-8b9a-ebd3c33e344e [0x5053] (CentraLite Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x5053, dest_endpoint: 0x01, profile: 0x0104, cluster: SimpleMetering >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0302 > > >
2022-03-14T16:02:41.971561629+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 7d90c215-996c-4646-8b9a-ebd3c33e344e [0x5053] (CentraLite Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x5053, dest_endpoint: 0x01, profile: 0x0104, cluster: SimpleMetering >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0301 > > >
2022-03-14T16:02:41.986406921+00:00 PRINT Zigbee Switch Power Mc <<<< random_state >>>>
2022-03-14T16:02:41.997720004+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 7d90c215-996c-4646-8b9a-ebd3c33e344e [0x5053] (CentraLite Plug)> emitting event: {“component_id”:“main”,“state”:{“value”:“Inactive”},“attribute_id”:“randomOnOff”,“capability_id”:“legendabsolute60149.randomOnOff2”}
2022-03-14T16:02:42.020735629+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 7d90c215-996c-4646-8b9a-ebd3c33e344e [0x5053] (CentraLite Plug)> emitting event: {“component_id”:“main”,“state”:{“value”:“Inactive”},“attribute_id”:“randomNext”,“capability_id”:“legendabsolute60149.randomNextStep2”}
2022-03-14T16:02:42.048294296+00:00 PRINT Zigbee Switch Power Mc device_running[id]= <ZigbeeDevice: 7d90c215-996c-4646-8b9a-ebd3c33e344e [0x5053] (CentraLite Plug)>
2022-03-14T16:02:42.056026796+00:00 PRINT Zigbee Switch Power Mc device_running, random_Step= <ZigbeeDevice: 7d90c215-996c-4646-8b9a-ebd3c33e344e [0x5053] (CentraLite Plug)> 1
2022-03-14T16:02:42.066302712+00:00 PRINT Zigbee Switch Power Mc device_running, random_totalStep= <ZigbeeDevice: 7d90c215-996c-4646-8b9a-ebd3c33e344e [0x5053] (CentraLite Plug)> 2
2022-03-14T16:02:42.072718379+00:00 PRINT Zigbee Switch Power Mc device_running, random_timer= <ZigbeeDevice: 7d90c215-996c-4646-8b9a-ebd3c33e344e [0x5053] (CentraLite Plug)> 18
2022-03-14T16:02:42.081201171+00:00 PRINT Zigbee Switch Power Mc random_state >>>>> Inactive
2022-03-14T16:02:42.087477379+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T16:02:42.092785296+00:00 TRACE Zigbee Switch Power Mc Received event with handler _resync
2022-03-14T16:02:42.096298421+00:00 TRACE Zigbee Switch Power Mc Received event with handler environment_info
2022-03-14T16:02:42.099415004+00:00 DEBUG Zigbee Switch Power Mc Z-Wave hub node ID environment changed.
2022-03-14T16:02:42.108886879+00:00 TRACE Zigbee Switch Power Mc Received event with handler device_lifecycle
2022-03-14T16:02:42.112171504+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 7d90c215-996c-4646-8b9a-ebd3c33e344e [0x5053] (CentraLite Plug)> received lifecycle event: added
2022-03-14T16:02:42.116928796+00:00 TRACE Zigbee Switch Power Mc <ZigbeeDevice: 7d90c215-996c-4646-8b9a-ebd3c33e344e [0x5053] (CentraLite Plug)> received unhandled lifecycle event: added
2022-03-14T16:02:42.120340921+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T16:02:42.140618296+00:00 TRACE Zigbee Switch Power Mc Received event with handler device_lifecycle
2022-03-14T16:02:42.144019087+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 7d90c215-996c-4646-8b9a-ebd3c33e344e [0x5053] (CentraLite Plug)> received lifecycle event: doConfigure
2022-03-14T16:02:42.148712921+00:00 TRACE Zigbee Switch Power Mc Found DeviceLifecycleDispatcher handler in Zigbee_Switch
2022-03-14T16:02:42.151884629+00:00 TRACE Zigbee Switch Power Mc Found CapabilityCommandDispatcher handler in Zigbee_Switch
2022-03-14T16:02:42.155994921+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 7d90c215-996c-4646-8b9a-ebd3c33e344e [0x5053] (CentraLite Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x5053, dest_endpoint: 0x01, profile: 0x0104, cluster: ElectricalMeasurement >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x050B > > >
2022-03-14T16:02:42.163327837+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 7d90c215-996c-4646-8b9a-ebd3c33e344e [0x5053] (CentraLite Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x5053, dest_endpoint: 0x01, profile: 0x0104, cluster: SimpleMetering >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0400 > > >
2022-03-14T16:02:42.176161046+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 7d90c215-996c-4646-8b9a-ebd3c33e344e [0x5053] (CentraLite Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x5053, dest_endpoint: 0x01, profile: 0x0104, cluster: SimpleMetering >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0000 > > >
2022-03-14T16:02:42.197439004+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 7d90c215-996c-4646-8b9a-ebd3c33e344e [0x5053] (CentraLite Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x5053, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0000 > > >
2022-03-14T16:02:42.326877963+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 7d90c215-996c-4646-8b9a-ebd3c33e344e [0x5053] (CentraLite Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x5053, dest_endpoint: 0x01, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: 000D6F000CA60D98, src_endpoint: 0x01, cluster: ElectricalMeasurement, dest_addr_mode: 0x03, dest_address: D052A8A36DA80001, dest_endpoint: 0x01 > > >
2022-03-14T16:02:42.355865671+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 7d90c215-996c-4646-8b9a-ebd3c33e344e [0x5053] (CentraLite Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x5053, dest_endpoint: 0x01, profile: 0x0104, cluster: ElectricalMeasurement >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x050B, DataType: Int16, minimum_reporting_interval: 0x0001, maximum_reporting_interval: 0x0E10, reportable_change: 1 > > > >
2022-03-14T16:02:42.416494879+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 7d90c215-996c-4646-8b9a-ebd3c33e344e [0x5053] (CentraLite Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x5053, dest_endpoint: 0x01, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: 000D6F000CA60D98, src_endpoint: 0x01, cluster: SimpleMetering, dest_addr_mode: 0x03, dest_address: D052A8A36DA80001, dest_endpoint: 0x01 > > >
2022-03-14T16:02:42.435760796+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 7d90c215-996c-4646-8b9a-ebd3c33e344e [0x5053] (CentraLite Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x5053, dest_endpoint: 0x01, profile: 0x0104, cluster: SimpleMetering >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x0400, DataType: Int24, minimum_reporting_interval: 0x0001, maximum_reporting_interval: 0x0E10, reportable_change: 1 > > > >
2022-03-14T16:02:42.461456588+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 7d90c215-996c-4646-8b9a-ebd3c33e344e [0x5053] (CentraLite Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x5053, dest_endpoint: 0x01, profile: 0x0104, cluster: SimpleMetering >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x0000, DataType: Uint48, minimum_reporting_interval: 0x0005, maximum_reporting_interval: 0x0E10, reportable_change: 0x000000000001 > > > >
2022-03-14T16:02:42.491988296+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 7d90c215-996c-4646-8b9a-ebd3c33e344e [0x5053] (CentraLite Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x5053, dest_endpoint: 0x01, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: 000D6F000CA60D98, src_endpoint: 0x01, cluster: OnOff, dest_addr_mode: 0x03, dest_address: D052A8A36DA80001, dest_endpoint: 0x01 > > >
2022-03-14T16:02:42.513922254+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 7d90c215-996c-4646-8b9a-ebd3c33e344e [0x5053] (CentraLite Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x5053, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x0000, DataType: Boolean, minimum_reporting_interval: 0x0000, maximum_reporting_interval: 0x012C > > > >
2022-03-14T16:02:42.530026629+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T16:02:42.543591129+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-03-14T16:02:42.560424879+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 7d90c215-996c-4646-8b9a-ebd3c33e344e [0x5053] (CentraLite Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x5053, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: ElectricalMeasurement >, lqi: 0xFF, rssi: -27, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x3E, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x050B, ZclStatus: SUCCESS, DataType: Int16, ActivePower: 0 > > > >
2022-03-14T16:02:42.592544796+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T16:02:42.597893546+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-03-14T16:02:42.611598004+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 7d90c215-996c-4646-8b9a-ebd3c33e344e [0x5053] (CentraLite Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x5053, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: SimpleMetering >, lqi: 0xFF, rssi: -27, body_length: 0x0006, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x3F, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0400, ZclStatus: UNSUPPORTED_ATTRIBUTE > > > >
2022-03-14T16:02:42.626875338+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch
2022-03-14T16:02:42.644936921+00:00 INFO Zigbee Switch Power Mc Executing ZclClusterAttributeValueHandler: cluster: ElectricalMeasurement, attribute: ActivePower
2022-03-14T16:02:42.650286921+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 7d90c215-996c-4646-8b9a-ebd3c33e344e [0x5053] (CentraLite Plug)> emitting event: {“component_id”:“main”,“state”:{“value”:0.0,“unit”:“W”},“attribute_id”:“power”,“capability_id”:“powerMeter”}
2022-03-14T16:02:42.689799629+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T16:02:42.711846129+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-03-14T16:02:42.719315296+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 7d90c215-996c-4646-8b9a-ebd3c33e344e [0x5053] (CentraLite Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x5053, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: SimpleMetering >, lqi: 0xFF, rssi: -27, body_length: 0x000D, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x40, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0000, ZclStatus: SUCCESS, DataType: Uint48, CurrentSummationDelivered: 0x000000000010 > > > >
2022-03-14T16:02:42.744697463+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T16:02:42.748802213+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-03-14T16:02:42.760533046+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 7d90c215-996c-4646-8b9a-ebd3c33e344e [0x5053] (CentraLite Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x5053, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xFF, rssi: -27, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x41, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0000, ZclStatus: SUCCESS, DataType: Boolean, OnOff: true > > > >
2022-03-14T16:02:42.784429046+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch
2022-03-14T16:02:42.794825088+00:00 INFO Zigbee Switch Power Mc Executing ZclClusterAttributeValueHandler: cluster: SimpleMetering, attribute: CurrentSummationDelivered
2022-03-14T16:02:42.805429754+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 7d90c215-996c-4646-8b9a-ebd3c33e344e [0x5053] (CentraLite Plug)> emitting event: {“component_id”:“main”,“state”:{“value”:16.0,“unit”:“kWh”},“attribute_id”:“energy”,“capability_id”:“energyMeter”}
2022-03-14T16:02:42.822343171+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T16:02:42.828662921+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-03-14T16:02:42.838856421+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 7d90c215-996c-4646-8b9a-ebd3c33e344e [0x5053] (CentraLite Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x5053, src_endpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: 0x8021 >, lqi: 0xFF, rssi: -27, body_length: 0x0002, < ZDOMessageBody || < ZDOHeader || seqno: 0x6C >, < BindRequestResponse || status: 0x00 > > >
2022-03-14T16:02:42.866221588+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch
2022-03-14T16:02:43.023467004+00:00 INFO Zigbee Switch Power Mc Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2022-03-14T16:02:43.094350338+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 7d90c215-996c-4646-8b9a-ebd3c33e344e [0x5053] (CentraLite Plug)> emitting event: {“component_id”:“main”,“state”:{“value”:“on”},“attribute_id”:“switch”,“capability_id”:“switch”}
2022-03-14T16:02:43.226068671+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T16:02:43.309576671+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-03-14T16:02:43.330986546+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 7d90c215-996c-4646-8b9a-ebd3c33e344e [0x5053] (CentraLite Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x5053, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: ElectricalMeasurement >, lqi: 0xFF, rssi: -27, body_length: 0x0004, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x42, ZCLCommandId: 0x07 >, < ConfigureReportingReponse || ZclStatus: SUCCESS > > >
2022-03-14T16:02:43.409169421+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T16:02:43.436384796+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-03-14T16:02:43.459452629+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 7d90c215-996c-4646-8b9a-ebd3c33e344e [0x5053] (CentraLite Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x5053, src_endpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: 0x8021 >, lqi: 0xFF, rssi: -27, body_length: 0x0002, < ZDOMessageBody || < ZDOHeader || seqno: 0x6D >, < BindRequestResponse || status: 0x00 > > >
2022-03-14T16:02:43.502368254+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T16:02:43.511557963+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-03-14T16:02:43.532583254+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 7d90c215-996c-4646-8b9a-ebd3c33e344e [0x5053] (CentraLite Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x5053, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: SimpleMetering >, lqi: 0xFF, rssi: -27, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x43, ZCLCommandId: 0x07 >, < ConfigureReportingReponse || < ConfigureReportingResponseRecord || ZclStatus: UNSUPPORTED_ATTRIBUTE, direction: 0x00, attr_id: 0x0400 > > > >
2022-03-14T16:02:43.567294879+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T16:02:43.579527338+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-03-14T16:02:43.599479338+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 7d90c215-996c-4646-8b9a-ebd3c33e344e [0x5053] (CentraLite Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x5053, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: SimpleMetering >, lqi: 0xFF, rssi: -27, body_length: 0x0004, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x44, ZCLCommandId: 0x07 >, < ConfigureReportingReponse || ZclStatus: SUCCESS > > >
2022-03-14T16:02:43.624815671+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T16:02:43.629769296+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-03-14T16:02:43.652876171+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 7d90c215-996c-4646-8b9a-ebd3c33e344e [0x5053] (CentraLite Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x5053, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: ElectricalMeasurement >, lqi: 0xFF, rssi: -27, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x46, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0605, ZclStatus: SUCCESS, DataType: Uint16, ACPowerDivisor: 0x000A > > > >
2022-03-14T16:02:43.692937004+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T16:02:43.697234921+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-03-14T16:02:43.707196296+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 7d90c215-996c-4646-8b9a-ebd3c33e344e [0x5053] (CentraLite Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x5053, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: ElectricalMeasurement >, lqi: 0xFF, rssi: -27, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x47, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0604, ZclStatus: SUCCESS, DataType: Uint16, ACPowerMultiplier: 0x0001 > > > >
2022-03-14T16:02:43.728031963+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch
2022-03-14T16:02:43.731514296+00:00 INFO Zigbee Switch Power Mc Executing ZclClusterAttributeValueHandler: cluster: ElectricalMeasurement, attribute: ACPowerDivisor
2022-03-14T16:02:43.734966504+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T16:02:43.738064254+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-03-14T16:02:43.762746879+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 7d90c215-996c-4646-8b9a-ebd3c33e344e [0x5053] (CentraLite Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x5053, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: SimpleMetering >, lqi: 0xFF, rssi: -28, body_length: 0x000A, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x49, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0301, ZclStatus: SUCCESS, DataType: Uint24, Multiplier: 1 > > > >
2022-03-14T16:02:43.785129546+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch
2022-03-14T16:02:43.790093754+00:00 INFO Zigbee Switch Power Mc Executing ZclClusterAttributeValueHandler: cluster: ElectricalMeasurement, attribute: ACPowerMultiplier
2022-03-14T16:02:43.796392213+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T16:02:43.802345171+00:00 TRACE Zigbee Switch Power Mc Received event with handler device_lifecycle
2022-03-14T16:02:43.825935838+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 7d90c215-996c-4646-8b9a-ebd3c33e344e [0x5053] (CentraLite Plug)> received lifecycle event: infoChanged
2022-03-14T16:02:43.851011338+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch
I see in the logs that this device does not support the 0x0400 InstantaneousDemand attribute and only supports the 0x050B ActivePower attribute and for that attribute I had not put the corrected manual handler.
Try this version to see if it works
│ Version     │ 2022-03-14T18:22:39.804066           │
I updated to your Zigbee Switch Power Mc v2022-03-14T18:22:39.804066.
It did not fix the problem, and it made the plug partly unresponsive in the app, and I was getting network error messages.
So I deleted the plug and tried to re-pair, but it would NOT pair with Zigbee Switch Power Mc v2022-03-14T18:22:39.804066. So I reinstalled “Zigbee Switch Power Mc - Old” and it paired with the old version with out any problems.
Then I manually switched the driver to Zigbee Switch Power Mc v2022-03-14T18:22:39.804066 using the app and it switched with no problems. The app now responds to changes with the plug but power reading are still off by 1000.
I can’t provide you pairing logs because the device would not pair with Zigbee Switch Power Mc v2022-03-14T18:22:39.804066. The following is a log of the plug turning on and off after manually switching to Zigbee Switch Power Mc v2022-03-14T18:22:39.804066:
2022-03-14T19:18:17.715747397+00:00 TRACE Zigbee Switch Power Mc Received event with handler capability
2022-03-14T19:18:17.722705480+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 7ac3424b-251e-42c9-afc2-1a3e56c02166 [0x5053] (CentraLite Plug)> received command: {“args”:,“positional_args”:,“component”:“main”,“command”:“off”,“capability”:“switch”}
2022-03-14T19:18:17.726328314+00:00 TRACE Zigbee Switch Power Mc Found CapabilityCommandDispatcher handler in Zigbee_Switch
2022-03-14T19:18:17.742326730+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T19:18:17.893571314+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-03-14T19:18:17.898348814+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 7ac3424b-251e-42c9-afc2-1a3e56c02166 [0x5053] (CentraLite Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x5053, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xFF, rssi: -13, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x08, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x00, ZclStatus: SUCCESS > > >
2022-03-14T19:18:17.911773689+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch2022-03-14T19:18:17.914906355+00:00 INFO Zigbee Switch Power Mc Executing ZclGlobalCommandHandler: cluster: OnOff, command: DefaultResponse
2022-03-14T19:18:17.919032230+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 7ac3424b-251e-42c9-afc2-1a3e56c02166 [0x5053] (CentraLite Plug)> emitting event: {“state”:{“value”:“off”},“capability_id”:“switch”,“component_id”:“main”,“attribute_id”:“switch”}
2022-03-14T19:18:17.931042647+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T19:18:17.943910730+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-03-14T19:18:17.951079105+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 7ac3424b-251e-42c9-afc2-1a3e56c02166 [0x5053] (CentraLite Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x5053, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xFF, rssi: -13, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x07, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Boolean, OnOff: false > > > >
2022-03-14T19:18:17.965094189+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch2022-03-14T19:18:17.968179480+00:00 INFO Zigbee Switch Power Mc Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2022-03-14T19:18:17.977646814+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 7ac3424b-251e-42c9-afc2-1a3e56c02166 [0x5053] (CentraLite Plug)> emitting event: {“state”:{“value”:“off”},“capability_id”:“switch”,“component_id”:“main”,“attribute_id”:“switch”}
2022-03-14T19:18:17.987265480+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T19:18:18.013768147+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-03-14T19:18:18.021080230+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 7ac3424b-251e-42c9-afc2-1a3e56c02166 [0x5053] (CentraLite Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x5053, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: ElectricalMeasurement >, lqi: 0xFF, rssi: -14, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x08, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x050B, DataType: Int16, ActivePower: 0 > > > >
2022-03-14T19:18:18.033436605+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch2022-03-14T19:18:18.036498980+00:00 INFO Zigbee Switch Power Mc Executing ZclClusterAttributeValueHandler: cluster: ElectricalMeasurement, attribute: ActivePower
2022-03-14T19:18:18.040819355+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 7ac3424b-251e-42c9-afc2-1a3e56c02166 [0x5053] (CentraLite Plug)> emitting event: {“state”:{“unit”:“W”,“value”:0.0},“capability_id”:“powerMeter”,“component_id”:“main”,“attribute_id”:“power”}
2022-03-14T19:18:18.052544897+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T19:18:19.963293147+00:00 TRACE Zigbee Switch Power Mc Received event with handler capability
2022-03-14T19:18:19.975583939+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 7ac3424b-251e-42c9-afc2-1a3e56c02166 [0x5053] (CentraLite Plug)> received command: {“args”:,“positional_args”:,“component”:“main”,“command”:“on”,“capability”:“switch”}
2022-03-14T19:18:19.978997689+00:00 TRACE Zigbee Switch Power Mc Found CapabilityCommandDispatcher handler in Zigbee_Switch
2022-03-14T19:18:19.985856606+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T19:18:20.123588522+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-03-14T19:18:20.128408147+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 7ac3424b-251e-42c9-afc2-1a3e56c02166 [0x5053] (CentraLite Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x5053, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xFF, rssi: -13, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x09, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x01, ZclStatus: SUCCESS > > >
2022-03-14T19:18:20.143181397+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch2022-03-14T19:18:20.146181647+00:00 INFO Zigbee Switch Power Mc Executing ZclGlobalCommandHandler: cluster: OnOff, command: DefaultResponse
2022-03-14T19:18:20.150014356+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 7ac3424b-251e-42c9-afc2-1a3e56c02166 [0x5053] (CentraLite Plug)> emitting event: {“state”:{“value”:“on”},“capability_id”:“switch”,“component_id”:“main”,“attribute_id”:“switch”}
2022-03-14T19:18:20.161262231+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T19:18:20.164918939+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-03-14T19:18:20.170872731+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 7ac3424b-251e-42c9-afc2-1a3e56c02166 [0x5053] (CentraLite Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x5053, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xFF, rssi: -14, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x09, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Boolean, OnOff: true > > > >
2022-03-14T19:18:20.185093022+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch2022-03-14T19:18:20.188243814+00:00 INFO Zigbee Switch Power Mc Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2022-03-14T19:18:20.192529439+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 7ac3424b-251e-42c9-afc2-1a3e56c02166 [0x5053] (CentraLite Plug)> emitting event: {“state”:{“value”:“on”},“capability_id”:“switch”,“component_id”:“main”,“attribute_id”:“switch”}
2022-03-14T19:18:20.201511522+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T19:18:21.063930189+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-03-14T19:18:21.068959564+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 7ac3424b-251e-42c9-afc2-1a3e56c02166 [0x5053] (CentraLite Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x5053, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: ElectricalMeasurement >, lqi: 0xFF, rssi: -13, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x0A, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x050B, DataType: Int16, ActivePower: 64 > > > >
2022-03-14T19:18:21.080987189+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch2022-03-14T19:18:21.084106439+00:00 INFO Zigbee Switch Power Mc Executing ZclClusterAttributeValueHandler: cluster: ElectricalMeasurement, attribute: ActivePower
2022-03-14T19:18:21.088041856+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 7ac3424b-251e-42c9-afc2-1a3e56c02166 [0x5053] (CentraLite Plug)> emitting event: {“state”:{“unit”:“W”,“value”:6400.0},“capability_id”:“powerMeter”,“component_id”:“main”,“attribute_id”:“power”}
2022-03-14T19:18:21.099783356+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T19:18:22.294053772+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-03-14T19:18:22.299010856+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 7ac3424b-251e-42c9-afc2-1a3e56c02166 [0x5053] (CentraLite Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x5053, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: ElectricalMeasurement >, lqi: 0xFF, rssi: -13, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x0B, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x050B, DataType: Int16, ActivePower: 86 > > > >
2022-03-14T19:18:22.312129397+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch2022-03-14T19:18:22.315286856+00:00 INFO Zigbee Switch Power Mc Executing ZclClusterAttributeValueHandler: cluster: ElectricalMeasurement, attribute: ActivePower
2022-03-14T19:18:22.319244606+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 7ac3424b-251e-42c9-afc2-1a3e56c02166 [0x5053] (CentraLite Plug)> emitting event: {“state”:{“unit”:“W”,“value”:8600.0},“capability_id”:“powerMeter”,“component_id”:“main”,“attribute_id”:“power”}
2022-03-14T19:18:22.331041647+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T19:18:23.534965856+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-03-14T19:18:23.543499106+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 7ac3424b-251e-42c9-afc2-1a3e56c02166 [0x5053] (CentraLite Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x5053, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: ElectricalMeasurement >, lqi: 0xFF, rssi: -16, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x0C, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x050B, DataType: Int16, ActivePower: 85 > > > >
2022-03-14T19:18:23.566194398+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch2022-03-14T19:18:23.570639023+00:00 INFO Zigbee Switch Power Mc Executing ZclClusterAttributeValueHandler: cluster: ElectricalMeasurement, attribute: ActivePower
2022-03-14T19:18:23.575620523+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 7ac3424b-251e-42c9-afc2-1a3e56c02166 [0x5053] (CentraLite Plug)> emitting event: {“state”:{“unit”:“W”,“value”:8500.0},“capability_id”:“powerMeter”,“component_id”:“main”,“attribute_id”:“power”}
2022-03-14T19:18:23.592165731+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T19:18:26.882885565+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee health poll
It is seen in the logs, that they do not enter the handler for active power and use the default.
Install the driver again in the hub, in a previous version I wrote the attribute wrong and it gave a fatal error, it is possible that it was installed incorrectly.
I deleted the device and both drivers. I reinstalled Zigbee Switch Power Mc and the plug paired quickly and easily. The the devide works in the app with no delay, but it still reads 8.5kW instead of 8.5 W. The 1st half of the pairing log is attached.The file is too large to include the entire log.
2022-03-14T22:01:28.648301395+00:00 TRACE Zigbee Switch Power Mc Setup driver Zigbee_Switch with lifecycle handlers:
default_handlers:
doConfigure:
driverSwitched:
infoChanged:
removed:
init:
child_dispatchers:
2022-03-14T22:01:28.654032979+00:00 TRACE Zigbee Switch Power Mc Setup driver Zigbee_Switch with Capability handlers:
default_handlers:
energyMeter:
resetEnergyMeter
setGetGroups
switchLevel:
setLevel
switch:
on
off
setRandomOnOff
refresh:
refresh
child_dispatchers:
2022-03-14T22:01:28.659894104+00:00 TRACE Zigbee Switch Power Mc Setup driver Zigbee_Switch with Zigbee handlers:
default_handlers:
attr:
global:
cluster:
ZclClusterCommandHandler: cluster: ElectricalMeasurement, command: 0x50B
zdo:
child_dispatchers:
2022-03-14T22:01:28.692723395+00:00 TRACE Zigbee Switch Power Mc Received event with handler _resync
2022-03-14T22:01:28.695774187+00:00 TRACE Zigbee Switch Power Mc Received event with handler environment_info
2022-03-14T22:01:28.704436979+00:00 TRACE Zigbee Switch Power Mc Found DeviceLifecycleDispatcher handler in Zigbee_Switch
2022-03-14T22:01:28.711531145+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x4F76, dest_endpoint: 0x01, profile: 0x0104, cluster: ElectricalMeasurement >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x050B > > >
2022-03-14T22:01:28.719043270+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x4F76, dest_endpoint: 0x01, profile: 0x0104, cluster: SimpleMetering >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0000 > > >
2022-03-14T22:01:28.736554354+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x4F76, dest_endpoint: 0x01, profile: 0x0104, cluster: SimpleMetering >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0400 > > >
2022-03-14T22:01:28.749257687+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x4F76, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0000 > > >
2022-03-14T22:01:28.759013645+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x4F76, dest_endpoint: 0x01, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: 000D6F000CA60D98, src_endpoint: 0x01, cluster: ElectricalMeasurement, dest_addr_mode: 0x03, dest_address: D052A8A36DA80001, dest_endpoint: 0x01 > > >
2022-03-14T22:01:28.779579645+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x4F76, dest_endpoint: 0x01, profile: 0x0104, cluster: ElectricalMeasurement >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x050B, DataType: Int16, minimum_reporting_interval: 0x0001, maximum_reporting_interval: 0x0E10, reportable_change: 1 > > > >
2022-03-14T22:01:28.790174854+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x4F76, dest_endpoint: 0x01, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: 000D6F000CA60D98, src_endpoint: 0x01, cluster: SimpleMetering, dest_addr_mode: 0x03, dest_address: D052A8A36DA80001, dest_endpoint: 0x01 > > >
2022-03-14T22:01:28.798656729+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x4F76, dest_endpoint: 0x01, profile: 0x0104, cluster: SimpleMetering >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x0000, DataType: Uint48, minimum_reporting_interval: 0x0005, maximum_reporting_interval: 0x0E10, reportable_change: 0x000000000001 > > > >
2022-03-14T22:01:28.823872312+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x4F76, dest_endpoint: 0x01, profile: 0x0104, cluster: SimpleMetering >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x0400, DataType: Int24, minimum_reporting_interval: 0x0001, maximum_reporting_interval: 0x0E10, reportable_change: 1 > > > >
2022-03-14T22:01:28.963018853+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x4F76, dest_endpoint: 0x01, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: 000D6F000CA60D98, src_endpoint: 0x01, cluster: OnOff, dest_addr_mode: 0x03, dest_address: D052A8A36DA80001, dest_endpoint: 0x01 > > >
2022-03-14T22:01:29.000457187+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x4F76, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x0000, DataType: Boolean, minimum_reporting_interval: 0x0000, maximum_reporting_interval: 0x012C > > > >
2022-03-14T22:01:29.011717895+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x4F76, dest_endpoint: 0x01, profile: 0x0104, cluster: ElectricalMeasurement >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0605 > > >
2022-03-14T22:01:29.035864895+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x4F76, dest_endpoint: 0x01, profile: 0x0104, cluster: ElectricalMeasurement >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0604 > > >
2022-03-14T22:01:29.054001687+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x4F76, dest_endpoint: 0x01, profile: 0x0104, cluster: SimpleMetering >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0302 > > >
2022-03-14T22:01:29.065731020+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x4F76, dest_endpoint: 0x01, profile: 0x0104, cluster: SimpleMetering >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0301 > > >
2022-03-14T22:01:29.075867895+00:00 PRINT Zigbee Switch Power Mc <<<< random_state >>>>
2022-03-14T22:01:29.092602853+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> emitting event: {“attribute_id”:“randomOnOff”,“component_id”:“main”,“capability_id”:“legendabsolute60149.randomOnOff2”,“state”:{“value”:“Inactive”}}
2022-03-14T22:01:29.122788312+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> emitting event: {“attribute_id”:“randomNext”,“component_id”:“main”,“capability_id”:“legendabsolute60149.randomNextStep2”,“state”:{“value”:“Inactive”}}
2022-03-14T22:01:29.160198145+00:00 PRINT Zigbee Switch Power Mc device_running[id]= <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)>
2022-03-14T22:01:29.166568062+00:00 PRINT Zigbee Switch Power Mc device_running, random_Step= <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> 1
2022-03-14T22:01:29.179987728+00:00 PRINT Zigbee Switch Power Mc device_running, random_totalStep= <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> 2
2022-03-14T22:01:29.191867145+00:00 PRINT Zigbee Switch Power Mc device_running, random_timer= <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> 10
2022-03-14T22:01:29.195138395+00:00 PRINT Zigbee Switch Power Mc random_state >>>>> Inactive
2022-03-14T22:01:29.202206645+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T22:01:29.206644812+00:00 TRACE Zigbee Switch Power Mc Received event with handler _resync
2022-03-14T22:01:29.213084520+00:00 TRACE Zigbee Switch Power Mc Received event with handler environment_info
2022-03-14T22:01:29.218030020+00:00 DEBUG Zigbee Switch Power Mc Z-Wave hub node ID environment changed.
2022-03-14T22:01:29.238902978+00:00 TRACE Zigbee Switch Power Mc Received event with handler device_lifecycle
2022-03-14T22:01:29.251891062+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> received lifecycle event: added
2022-03-14T22:01:29.262663187+00:00 TRACE Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> received unhandled lifecycle event: added
2022-03-14T22:01:29.265788312+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T22:01:29.270678645+00:00 TRACE Zigbee Switch Power Mc Received event with handler device_lifecycle
2022-03-14T22:01:29.281343520+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> received lifecycle event: doConfigure
2022-03-14T22:01:29.288710187+00:00 TRACE Zigbee Switch Power Mc Found DeviceLifecycleDispatcher handler in Zigbee_Switch
2022-03-14T22:01:29.292003478+00:00 TRACE Zigbee Switch Power Mc Found CapabilityCommandDispatcher handler in Zigbee_Switch
2022-03-14T22:01:29.300506228+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x4F76, dest_endpoint: 0x01, profile: 0x0104, cluster: ElectricalMeasurement >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x050B > > >
2022-03-14T22:01:29.319640437+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x4F76, dest_endpoint: 0x01, profile: 0x0104, cluster: SimpleMetering >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0000 > > >
2022-03-14T22:01:29.342939770+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x4F76, dest_endpoint: 0x01, profile: 0x0104, cluster: SimpleMetering >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0400 > > >
2022-03-14T22:01:29.359482812+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x4F76, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0000 > > >
2022-03-14T22:01:29.380518228+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x4F76, dest_endpoint: 0x01, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: 000D6F000CA60D98, src_endpoint: 0x01, cluster: ElectricalMeasurement, dest_addr_mode: 0x03, dest_address: D052A8A36DA80001, dest_endpoint: 0x01 > > >
2022-03-14T22:01:29.389191228+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x4F76, dest_endpoint: 0x01, profile: 0x0104, cluster: ElectricalMeasurement >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x050B, DataType: Int16, minimum_reporting_interval: 0x0001, maximum_reporting_interval: 0x0E10, reportable_change: 1 > > > >
2022-03-14T22:01:29.403263895+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x4F76, dest_endpoint: 0x01, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: 000D6F000CA60D98, src_endpoint: 0x01, cluster: SimpleMetering, dest_addr_mode: 0x03, dest_address: D052A8A36DA80001, dest_endpoint: 0x01 > > >
2022-03-14T22:01:29.430068062+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x4F76, dest_endpoint: 0x01, profile: 0x0104, cluster: SimpleMetering >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x0000, DataType: Uint48, minimum_reporting_interval: 0x0005, maximum_reporting_interval: 0x0E10, reportable_change: 0x000000000001 > > > >
2022-03-14T22:01:29.459119395+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x4F76, dest_endpoint: 0x01, profile: 0x0104, cluster: SimpleMetering >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x0400, DataType: Int24, minimum_reporting_interval: 0x0001, maximum_reporting_interval: 0x0E10, reportable_change: 1 > > > >
2022-03-14T22:01:29.469423895+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x4F76, dest_endpoint: 0x01, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: 000D6F000CA60D98, src_endpoint: 0x01, cluster: OnOff, dest_addr_mode: 0x03, dest_address: D052A8A36DA80001, dest_endpoint: 0x01 > > >
2022-03-14T22:01:29.488239770+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x4F76, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x0000, DataType: Boolean, minimum_reporting_interval: 0x0000, maximum_reporting_interval: 0x012C > > > >
2022-03-14T22:01:29.504406853+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T22:01:29.510123645+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-03-14T22:01:29.529042812+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4F76, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: ElectricalMeasurement >, lqi: 0xFF, rssi: -27, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x44, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x050B, ZclStatus: SUCCESS, DataType: Int16, ActivePower: 87 > > > >
2022-03-14T22:01:29.558986895+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T22:01:29.567433228+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-03-14T22:01:29.577203603+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4F76, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: SimpleMetering >, lqi: 0xFF, rssi: -27, body_length: 0x000D, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x45, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0000, ZclStatus: SUCCESS, DataType: Uint48, CurrentSummationDelivered: 0x00000000002E > > > >
2022-03-14T22:01:29.590879645+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch
2022-03-14T22:01:29.596765937+00:00 INFO Zigbee Switch Power Mc Executing ZclClusterAttributeValueHandler: cluster: ElectricalMeasurement, attribute: ActivePower
2022-03-14T22:01:29.604831853+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> emitting event: {“attribute_id”:“power”,“component_id”:“main”,“capability_id”:“powerMeter”,“state”:{“value”:87000.0,“unit”:“W”}}
2022-03-14T22:01:29.668542145+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T22:01:29.680904020+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-03-14T22:01:29.701414562+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4F76, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: SimpleMetering >, lqi: 0xFF, rssi: -27, body_length: 0x0006, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x46, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0400, ZclStatus: UNSUPPORTED_ATTRIBUTE > > > >
2022-03-14T22:01:29.737787020+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch
2022-03-14T22:01:29.747336520+00:00 INFO Zigbee Switch Power Mc Executing ZclClusterAttributeValueHandler: cluster: SimpleMetering, attribute: CurrentSummationDelivered
2022-03-14T22:01:29.783414187+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> emitting event: {“attribute_id”:“energy”,“component_id”:“main”,“capability_id”:“energyMeter”,“state”:{“value”:46.0,“unit”:“kWh”}}
2nd half of pairing log.
2022-03-14T22:01:29.863130437+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T22:01:29.871268103+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-03-14T22:01:29.877448937+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4F76, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xFF, rssi: -27, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x47, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0000, ZclStatus: SUCCESS, DataType: Boolean, OnOff: true > > > >
2022-03-14T22:01:29.886505062+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T22:01:29.891318395+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-03-14T22:01:29.906274020+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4F76, src_endpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: 0x8021 >, lqi: 0xFF, rssi: -27, body_length: 0x0002, < ZDOMessageBody || < ZDOHeader || seqno: 0x26 >, < BindRequestResponse || status: 0x00 > > >
2022-03-14T22:01:29.929085728+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch
2022-03-14T22:01:29.934284562+00:00 INFO Zigbee Switch Power Mc Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2022-03-14T22:01:29.970696478+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> emitting event: {“attribute_id”:“switch”,“component_id”:“main”,“capability_id”:“switch”,“state”:{“value”:“on”}}
2022-03-14T22:01:29.981613478+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T22:01:29.984905187+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-03-14T22:01:29.992687937+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4F76, src_endpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: 0x8021 >, lqi: 0xFF, rssi: -27, body_length: 0x0002, < ZDOMessageBody || < ZDOHeader || seqno: 0x27 >, < BindRequestResponse || status: 0x00 > > >
2022-03-14T22:01:30.001585728+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T22:01:30.012437020+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-03-14T22:01:30.030442812+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4F76, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: SimpleMetering >, lqi: 0xFF, rssi: -27, body_length: 0x0004, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x49, ZCLCommandId: 0x07 >, < ConfigureReportingReponse || ZclStatus: SUCCESS > > >
2022-03-14T22:01:30.042791187+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T22:01:30.046130853+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-03-14T22:01:30.051422145+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4F76, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: SimpleMetering >, lqi: 0xFF, rssi: -27, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x4A, ZCLCommandId: 0x07 >, < ConfigureReportingReponse || < ConfigureReportingResponseRecord || ZclStatus: UNSUPPORTED_ATTRIBUTE, direction: 0x00, attr_id: 0x0400 > > > >
2022-03-14T22:01:30.060905520+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T22:01:30.064438312+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-03-14T22:01:30.071670020+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4F76, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: ElectricalMeasurement >, lqi: 0xFF, rssi: -29, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x4C, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0605, ZclStatus: SUCCESS, DataType: Uint16, ACPowerDivisor: 0x000A > > > >
2022-03-14T22:01:30.079961895+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T22:01:30.084133812+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-03-14T22:01:30.097531353+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x02, < AddressHeader || src_addr: 0x4F76, src_endpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: Basic >, lqi: 0xFF, rssi: -35, body_length: 0x000B, < ZDOMessageBody || < ZDOHeader || seqno: 0xC5 >, GenericBody: 01 00 A8 6D A3 A8 52 D0 00 00 > >
2022-03-14T22:01:30.112643062+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch
2022-03-14T22:01:30.119937603+00:00 INFO Zigbee Switch Power Mc Executing ZclClusterAttributeValueHandler: cluster: ElectricalMeasurement, attribute: ACPowerDivisor
2022-03-14T22:01:30.123499187+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T22:01:30.127238395+00:00 TRACE Zigbee Switch Power Mc Received event with handler device_lifecycle
2022-03-14T22:01:30.137460145+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> received lifecycle event: infoChanged
2022-03-14T22:01:30.149202312+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T22:01:30.152509228+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-03-14T22:01:30.158095937+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4F76, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: SimpleMetering >, lqi: 0xFF, rssi: -27, body_length: 0x000A, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x4E, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0302, ZclStatus: SUCCESS, DataType: Uint24, Divisor: 10000 > > > >
2022-03-14T22:01:30.167947895+00:00 TRACE Zigbee Switch Power Mc Found DeviceLifecycleDispatcher handler in Zigbee_Switch
2022-03-14T22:01:30.171240478+00:00 PRINT Zigbee Switch Power Mc device.preferences[infoChanged]= 0.0
2022-03-14T22:01:30.175240687+00:00 PRINT Zigbee Switch Power Mc << Preference changed: name, old, new >> groupAdd nil 0.0
2022-03-14T22:01:30.180409395+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x4F76, dest_endpoint: 0x01, profile: 0x0104, cluster: Groups >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x01, seqno: 0x00, ZCLCommandId: 0x02 >, < GetGroupMembership || group_list_length: 0x00 > > >
2022-03-14T22:01:30.187563395+00:00 PRINT Zigbee Switch Power Mc device.preferences[infoChanged]=
2022-03-14T22:01:30.191738812+00:00 PRINT Zigbee Switch Power Mc << Preference changed: name, old, new >> version nil
2022-03-14T22:01:30.195079603+00:00 PRINT Zigbee Switch Power Mc device.preferences[infoChanged]= 10
2022-03-14T22:01:30.198412937+00:00 PRINT Zigbee Switch Power Mc << Preference changed: name, old, new >> offTime nil 10
2022-03-14T22:01:30.210105978+00:00 PRINT Zigbee Switch Power Mc device.preferences[infoChanged]= 1.0
2022-03-14T22:01:30.213479645+00:00 PRINT Zigbee Switch Power Mc << Preference changed: name, old, new >> groupRemove nil 1.0
2022-03-14T22:01:30.216895437+00:00 PRINT Zigbee Switch Power Mc Remove Groups >>>>>>>>>>>>>>>>>
2022-03-14T22:01:30.224415395+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x4F76, dest_endpoint: 0x01, profile: 0x0104, cluster: Groups >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x01, seqno: 0x00, ZCLCommandId: 0x03 >, < RemoveGroup || group_id: 0x0001 > > >
2022-03-14T22:01:30.232171687+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x4F76, dest_endpoint: 0x01, profile: 0x0104, cluster: Groups >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x01, seqno: 0x00, ZCLCommandId: 0x02 >, < GetGroupMembership || group_list_length: 0x00 > > >
2022-03-14T22:01:30.239224228+00:00 PRINT Zigbee Switch Power Mc device.preferences[infoChanged]= 10
2022-03-14T22:01:30.242940978+00:00 PRINT Zigbee Switch Power Mc << Preference changed: name, old, new >> onTime nil 10
2022-03-14T22:01:30.246264812+00:00 PRINT Zigbee Switch Power Mc device.preferences[infoChanged]= 0
2022-03-14T22:01:30.249801437+00:00 PRINT Zigbee Switch Power Mc << Preference changed: name, old, new >> localTimeOffset nil 0
2022-03-14T22:01:30.253106562+00:00 PRINT Zigbee Switch Power Mc device.preferences[infoChanged]= Plug
2022-03-14T22:01:30.256658228+00:00 PRINT Zigbee Switch Power Mc << Preference changed: name, old, new >> changeProfileEner nil Plug
2022-03-14T22:01:30.263950228+00:00 PRINT Zigbee Switch Power Mc device.preferences[infoChanged]= 1.0
2022-03-14T22:01:30.268274145+00:00 PRINT Zigbee Switch Power Mc << Preference changed: name, old, new >> randomMin nil 1.0
2022-03-14T22:01:30.271634187+00:00 PRINT Zigbee Switch Power Mc device.preferences[infoChanged]= 10.0
2022-03-14T22:01:30.275167478+00:00 PRINT Zigbee Switch Power Mc << Preference changed: name, old, new >> randomMax nil 10.0
2022-03-14T22:01:30.279908478+00:00 PRINT Zigbee Switch Power Mc Device ID <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)>
2022-03-14T22:01:30.283557187+00:00 PRINT Zigbee Switch Power Mc Manufacturer >>> CentraLite Manufacturer_Len >>> 10
2022-03-14T22:01:30.287354562+00:00 PRINT Zigbee Switch Power Mc Model >>> 3210-L Model_len >>> 6
2022-03-14T22:01:30.291141812+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T22:01:30.294406062+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-03-14T22:01:30.300006728+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4F76, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: SimpleMetering >, lqi: 0xFF, rssi: -27, body_length: 0x000A, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x4F, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0301, ZclStatus: SUCCESS, DataType: Uint24, Multiplier: 1 > > > >
2022-03-14T22:01:30.309392812+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch
2022-03-14T22:01:30.316129936+00:00 INFO Zigbee Switch Power Mc Executing ZclClusterAttributeValueHandler: cluster: SimpleMetering, attribute: Divisor
2022-03-14T22:01:30.322629353+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T22:01:30.327183478+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-03-14T22:01:30.334010478+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4F76, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: ElectricalMeasurement >, lqi: 0xFF, rssi: -27, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x50, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x050B, ZclStatus: SUCCESS, DataType: Int16, ActivePower: 86 > > > >
2022-03-14T22:01:30.350341520+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch
2022-03-14T22:01:30.354537603+00:00 INFO Zigbee Switch Power Mc Executing ZclClusterAttributeValueHandler: cluster: SimpleMetering, attribute: Multiplier
2022-03-14T22:01:30.357941686+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T22:01:30.361163311+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-03-14T22:01:30.367972895+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4F76, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: SimpleMetering >, lqi: 0xFF, rssi: -27, body_length: 0x000D, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x51, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0000, ZclStatus: SUCCESS, DataType: Uint48, CurrentSummationDelivered: 0x00000000002E > > > >
2022-03-14T22:01:30.379283978+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch
2022-03-14T22:01:30.384574561+00:00 INFO Zigbee Switch Power Mc Executing ZclClusterAttributeValueHandler: cluster: ElectricalMeasurement, attribute: ActivePower
2022-03-14T22:01:30.388976853+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> emitting event: {“attribute_id”:“power”,“component_id”:“main”,“capability_id”:“powerMeter”,“state”:{“value”:8600.0,“unit”:“W”}}
2022-03-14T22:01:30.400503895+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T22:01:30.413731145+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-03-14T22:01:30.420581270+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4F76, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xFF, rssi: -28, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x53, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0000, ZclStatus: SUCCESS, DataType: Boolean, OnOff: true > > > >
2022-03-14T22:01:30.432998020+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch
2022-03-14T22:01:30.442198103+00:00 INFO Zigbee Switch Power Mc Executing ZclClusterAttributeValueHandler: cluster: SimpleMetering, attribute: CurrentSummationDelivered
2022-03-14T22:01:30.450190770+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> emitting event: {“attribute_id”:“energy”,“component_id”:“main”,“capability_id”:“energyMeter”,“state”:{“value”:0.0046,“unit”:“kWh”}}
2022-03-14T22:01:30.463960728+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T22:01:30.467286478+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-03-14T22:01:30.472908061+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4F76, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: SimpleMetering >, lqi: 0xFF, rssi: -27, body_length: 0x0006, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x52, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0400, ZclStatus: UNSUPPORTED_ATTRIBUTE > > > >
2022-03-14T22:01:30.483112895+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch
2022-03-14T22:01:30.486406436+00:00 INFO Zigbee Switch Power Mc Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2022-03-14T22:01:30.491006936+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> emitting event: {“attribute_id”:“switch”,“component_id”:“main”,“capability_id”:“switch”,“state”:{“value”:“on”}}
2022-03-14T22:01:30.500652186+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T22:01:30.510096353+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-03-14T22:01:30.519479353+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4F76, src_endpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: 0x8021 >, lqi: 0xFF, rssi: -27, body_length: 0x0002, < ZDOMessageBody || < ZDOHeader || seqno: 0x29 >, < BindRequestResponse || status: 0x00 > > >
2022-03-14T22:01:30.531146686+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T22:01:30.534751978+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-03-14T22:01:30.539872311+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4F76, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: ElectricalMeasurement >, lqi: 0xFF, rssi: -27, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x5E, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x050B, DataType: Int16, ActivePower: 86 > > > >
2022-03-14T22:01:30.551275936+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T22:01:30.556491936+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch
2022-03-14T22:01:30.564443020+00:00 INFO Zigbee Switch Power Mc Executing ZclClusterAttributeValueHandler: cluster: ElectricalMeasurement, attribute: ActivePower
2022-03-14T22:01:30.568416686+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> emitting event: {“attribute_id”:“power”,“component_id”:“main”,“capability_id”:“powerMeter”,“state”:{“value”:8600.0,“unit”:“W”}}
2022-03-14T22:01:30.585375436+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T22:01:30.589187770+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-03-14T22:01:30.595876478+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4F76, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: ElectricalMeasurement >, lqi: 0xFF, rssi: -35, body_length: 0x0004, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x54, ZCLCommandId: 0x07 >, < ConfigureReportingReponse || ZclStatus: SUCCESS > > >
2022-03-14T22:01:30.621311478+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T22:01:30.625457853+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-03-14T22:01:30.629904561+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4F76, src_endpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: 0x8021 >, lqi: 0xFF, rssi: -28, body_length: 0x0002, < ZDOMessageBody || < ZDOHeader || seqno: 0x2A >, < BindRequestResponse || status: 0x00 > > >
2022-03-14T22:01:30.640776895+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T22:01:30.718374353+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-03-14T22:01:30.725465728+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4F76, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xFF, rssi: -27, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x47, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0000, ZclStatus: SUCCESS, DataType: Boolean, OnOff: true > > > >
2022-03-14T22:01:30.812866186+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch
2022-03-14T22:01:30.816335603+00:00 INFO Zigbee Switch Power Mc Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2022-03-14T22:01:30.820192728+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> emitting event: {“attribute_id”:“switch”,“component_id”:“main”,“capability_id”:“switch”,“state”:{“value”:“on”}}
2022-03-14T22:01:30.838200311+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T22:01:30.848627895+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-03-14T22:01:30.860275145+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4F76, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: SimpleMetering >, lqi: 0xFE, rssi: -27, body_length: 0x0004, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x55, ZCLCommandId: 0x07 >, < ConfigureReportingReponse || ZclStatus: SUCCESS > > >
2022-03-14T22:01:30.871426270+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T22:01:30.993846978+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-03-14T22:01:30.999715895+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4F76, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: ElectricalMeasurement >, lqi: 0xFF, rssi: -27, body_length: 0x0004, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x48, ZCLCommandId: 0x07 >, < ConfigureReportingReponse || ZclStatus: SUCCESS > > >
2022-03-14T22:01:31.011090228+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T22:01:31.020131436+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-03-14T22:01:31.024808228+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4F76, src_endpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: 0x8021 >, lqi: 0xFF, rssi: -27, body_length: 0x0002, < ZDOMessageBody || < ZDOHeader || seqno: 0x2B >, < BindRequestResponse || status: 0x00 > > >
2022-03-14T22:01:31.042629686+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T22:01:31.094001811+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-03-14T22:01:31.100170561+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4F76, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xFF, rssi: -27, body_length: 0x0004, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x4B, ZCLCommandId: 0x07 >, < ConfigureReportingReponse || ZclStatus: SUCCESS > > >
2022-03-14T22:01:31.110505478+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T22:01:31.274331686+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-03-14T22:01:31.279812811+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4F76, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Groups >, lqi: 0xFF, rssi: -27, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x09, seqno: 0x58, ZCLCommandId: 0x02 >, < GetGroupMembershipResponse || capacity: 0xFF, group_list_length: 0x00 > > >
2022-03-14T22:01:31.291659853+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch
2022-03-14T22:01:31.295173270+00:00 INFO Zigbee Switch Power Mc Executing ZclClusterCommandHandler: cluster: Groups, command: GetGroupMembership
2022-03-14T22:01:31.298464228+00:00 PRINT Zigbee Switch Power Mc group_list >>>>>> {}
2022-03-14T22:01:31.302946770+00:00 PRINT Zigbee Switch Power Mc All Deleted
2022-03-14T22:01:31.307786186+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> emitting event: {“attribute_id”:“getGroups”,“component_id”:“main”,“capability_id”:“legendabsolute60149.getGroups”,“state”:{“value”:“All Deleted”}}
2022-03-14T22:01:31.324896020+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T22:01:31.364370186+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-03-14T22:01:31.373830103+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4F76, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xFF, rssi: -37, body_length: 0x0004, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x57, ZCLCommandId: 0x07 >, < ConfigureReportingReponse || ZclStatus: SUCCESS > > >
2022-03-14T22:01:31.384821020+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T22:01:31.424158478+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-03-14T22:01:31.431283561+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4F76, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: ElectricalMeasurement >, lqi: 0xFF, rssi: -27, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x4D, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0604, ZclStatus: SUCCESS, DataType: Uint16, ACPowerMultiplier: 0x0001 > > > >
2022-03-14T22:01:31.441919228+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch
2022-03-14T22:01:31.445072645+00:00 INFO Zigbee Switch Power Mc Executing ZclClusterAttributeValueHandler: cluster: ElectricalMeasurement, attribute: ACPowerMultiplier
2022-03-14T22:01:31.448893520+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T22:01:31.504258895+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-03-14T22:01:31.510537228+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4F76, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Groups >, lqi: 0xFF, rssi: -27, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x09, seqno: 0x5A, ZCLCommandId: 0x02 >, < GetGroupMembershipResponse || capacity: 0xFF, group_list_length: 0x00 > > >
2022-03-14T22:01:31.520985311+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch
2022-03-14T22:01:31.524217811+00:00 INFO Zigbee Switch Power Mc Executing ZclClusterCommandHandler: cluster: Groups, command: GetGroupMembership
2022-03-14T22:01:31.527836728+00:00 PRINT Zigbee Switch Power Mc group_list >>>>>> {}
2022-03-14T22:01:31.533783020+00:00 PRINT Zigbee Switch Power Mc All Deleted
2022-03-14T22:01:31.537516186+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> emitting event: {“attribute_id”:“getGroups”,“component_id”:“main”,“capability_id”:“legendabsolute60149.getGroups”,“state”:{“value”:“All Deleted”}}
2022-03-14T22:01:31.546964603+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T22:01:32.363894353+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-03-14T22:01:32.369298853+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4F76, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: SimpleMetering >, lqi: 0xFF, rssi: -27, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x56, ZCLCommandId: 0x07 >, < ConfigureReportingReponse || < ConfigureReportingResponseRecord || ZclStatus: UNSUPPORTED_ATTRIBUTE, direction: 0x00, attr_id: 0x0400 > > > >
2022-03-14T22:01:32.379666978+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T22:01:32.834383394+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-03-14T22:01:32.853888519+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4F76, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Groups >, lqi: 0xFF, rssi: -27, body_length: 0x0006, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x09, seqno: 0x59, ZCLCommandId: 0x03 >, < RemoveGroupResponse || status: 0x8B, group_id: 0x0001 > > >
Logs for 1 on cycle
2022-03-14T22:18:22.086535496+00:00 TRACE Zigbee Switch Power Mc Received event with handler capability
2022-03-14T22:18:22.092294496+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> received command: {“args”:,“positional_args”:,“component”:“main”,“command”:“on”,“capability”:“switch”}
2022-03-14T22:18:22.095930787+00:00 TRACE Zigbee Switch Power Mc Found CapabilityCommandDispatcher handler in Zigbee_Switch
2022-03-14T22:18:22.102668204+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T22:18:22.281558996+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-03-14T22:18:22.286319912+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4F76, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xFF, rssi: -13, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x18, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x01, ZclStatus: SUCCESS > > >
2022-03-14T22:18:22.295447371+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch2022-03-14T22:18:22.298617787+00:00 INFO Zigbee Switch Power Mc Executing ZclGlobalCommandHandler: cluster: OnOff, command: DefaultResponse
2022-03-14T22:18:22.303101746+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> emitting event: {“attribute_id”:“switch”,“component_id”:“main”,“capability_id”:“switch”,“state”:{“value”:“on”}}
2022-03-14T22:18:22.314813996+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T22:18:22.318023996+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-03-14T22:18:22.323486996+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4F76, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xFF, rssi: -13, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x02, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Boolean, OnOff: true > > > >
2022-03-14T22:18:22.335299662+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch2022-03-14T22:18:22.338785329+00:00 INFO Zigbee Switch Power Mc Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2022-03-14T22:18:22.344002329+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> emitting event: {“attribute_id”:“switch”,“component_id”:“main”,“capability_id”:“switch”,“state”:{“value”:“on”}}
2022-03-14T22:18:22.353435287+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T22:18:22.903952954+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-03-14T22:18:22.911512621+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4F76, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: ElectricalMeasurement >, lqi: 0xFF, rssi: -13, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x03, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x050B, DataType: Int16, ActivePower: 3 > > > >
2022-03-14T22:18:22.925542787+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch2022-03-14T22:18:22.929870079+00:00 INFO Zigbee Switch Power Mc Executing ZclClusterAttributeValueHandler: cluster: ElectricalMeasurement, attribute: ActivePower
2022-03-14T22:18:22.937525662+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> emitting event: {“attribute_id”:“power”,“component_id”:“main”,“capability_id”:“powerMeter”,“state”:{“value”:300.0,“unit”:“W”}}
2022-03-14T22:18:22.953365204+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T22:18:24.146125620+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-03-14T22:18:24.155928370+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4F76, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: ElectricalMeasurement >, lqi: 0xFF, rssi: -13, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x04, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x050B, DataType: Int16, ActivePower: 75 > > > >
2022-03-14T22:18:24.167075370+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch2022-03-14T22:18:24.170277620+00:00 INFO Zigbee Switch Power Mc Executing ZclClusterAttributeValueHandler: cluster: ElectricalMeasurement, attribute: ActivePower
2022-03-14T22:18:24.176152162+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> emitting event: {“attribute_id”:“power”,“component_id”:“main”,“capability_id”:“powerMeter”,“state”:{“value”:7500.0,“unit”:“W”}}
2022-03-14T22:18:24.188007079+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T22:18:25.294394453+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-03-14T22:18:25.299519787+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4F76, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: ElectricalMeasurement >, lqi: 0xFF, rssi: -13, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x05, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x050B, DataType: Int16, ActivePower: 85 > > > >
2022-03-14T22:18:25.309670120+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch2022-03-14T22:18:25.312855245+00:00 INFO Zigbee Switch Power Mc Executing ZclClusterAttributeValueHandler: cluster: ElectricalMeasurement, attribute: ActivePower
2022-03-14T22:18:25.316822370+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> emitting event: {“attribute_id”:“power”,“component_id”:“main”,“capability_id”:“powerMeter”,“state”:{“value”:8500.0,“unit”:“W”}}
2022-03-14T22:18:25.328417162+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T22:18:28.932806453+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee health poll
2022-03-14T22:18:31.414490452+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-03-14T22:18:31.419615035+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4F76, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: ElectricalMeasurement >, lqi: 0xFF, rssi: -13, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x06, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x050B, DataType: Int16, ActivePower: 86 > > > >
2022-03-14T22:18:31.430509244+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch
2022-03-14T22:18:31.434588619+00:00 INFO Zigbee Switch Power Mc Executing ZclClusterAttributeValueHandler: cluster: ElectricalMeasurement, attribute: ActivePower
2022-03-14T22:18:31.438800910+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> emitting event: {“attribute_id”:“power”,“component_id”:“main”,“capability_id”:“powerMeter”,“state”:{“value”:8600.0,“unit”:“W”}}
2022-03-14T22:18:31.450559869+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
2022-03-14T22:18:32.634241952+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-03-14T22:18:32.639627743+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4F76, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: ElectricalMeasurement >, lqi: 0xFF, rssi: -13, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x07, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x050B, DataType: Int16, ActivePower: 85 > > > >
2022-03-14T22:18:32.650890868+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch
2022-03-14T22:18:32.654190285+00:00 INFO Zigbee Switch Power Mc Executing ZclClusterAttributeValueHandler: cluster: ElectricalMeasurement, attribute: ActivePower
2022-03-14T22:18:32.658130910+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: a6771aa7-e554-4c32-90b6-6ec3d1f70807 [0x4F76] (CentraLite Plug)> emitting event: {“attribute_id”:“power”,“component_id”:“main”,“capability_id”:“powerMeter”,“state”:{“value”:8500.0,“unit”:“W”}}
2022-03-14T22:18:32.669932160+00:00 DEBUG Zigbee Switch Power Mc CentraLite Plug device thread event handled
listening for logs… -
I do not understand why it does not enter the handler to emit the correct event and goes directly to the default
The multiplier it reads is 1 and the divisor is 10, which are the correct ones so that handler emits 8.5w instead of 8500w.
I have made some changes, I don’t know if it will work
You can install new version with CLI, without unistall device
│ Name        │ Zigbee Switch Power Mc               │
│ Version     │ 2022-03-14T23:05:03.609415           │
I installed Zigbee Switch Power Mc 2022-03-14T23:05:03.609415.
Now the app just spins when I try to operate the plug and goes to network error. So I can’t control the plug.
Manual operation of the plug does not show up in the app,
Logs are NOT generated for app or manual operation.
