(EDGE Driver-Mc) Zigbee switch MC, Zigbee switch power MC, Zigbee multi switch and child MC
Hi @Joao_Santos
Added to this driver version
 Name         Zigbee Switch Power Mc
 Version      2023-03-07T10:42:04.328251094
- id: "_TZ3000_amdymr71/TS011F"
    deviceLabel: TS011F Plug
    manufacturer: _TZ3000_amdymr71
    model: TS011F
    deviceProfileName: switch-power-energy-plug
The driver does not appear to select. Neither can’t i find the id in the list of fingerprints. I restarted the hub without sucess. Am i doing something wrong?
According to this capture driver is installed in your hub.
What driver is your device paired to?
The currect version of the driver appears in the hubs controllers tab but not for select on the device. The device was initially recognize as a switch by smartthings.
@Joao_Santos
Try to uninstall driver and reinstall again from Channel
Just did and still no luck. But it doesnt show in the fingerprints.yml, at least I can’t find it.
Github id not updated yet.
Hey Team,
Wondering if this is an easy fix. I bought a powered (in wall) multi-gang switch that is designed for TUYA. I want it in ST.
Research has me here: I’ve already enrolled and have 3 multi-switch power strips working with your drivers - but for some reason this one just won’t work with any of the various drivers I’ve installed.
Hoping you can help.
Here is what it looks like:
It looks like you may have done something very similar here:
Hi @SJENS721
This device uses EF00 Tuya cluster and not works with my driver
Write in this specific thread for EF00 cluster devices
Sorry, Mariano–I don’t have those options. I’m running the “Smartenit/ZBMLC30” device in your Zigbee Multi Switch and Child Mc driver dated 2023-03-10T14:51:06… I cannot delete drivers to reinstall, as it complains that the drivers are “currently being used.” I am still subscribed to your channel Mariano Shared Beta Driver.
It still only shows up as a power switch with switch-2 as child, but we have to control switch-2 manually.
Hi @Mariano_Colmenarejo Is it possible to add this Aeotec range extender.
  • id: “AEOTEC/WG001-Z01”
    manufacturer: AL001
    model: WG001-Z01
    deviceLabel: Aeotec Range Extender Zi
    deviceProfileName: range-extender
Thank you
Hi Giacomo
 Name         Zigbee Range Extender Mc
 Version      2023-03-14T11:37:43.276410938
- id: "AEOTEC/WG001-Z01"
    manufacturer: AL001
    model: WG001-Z01
I don’t really know what you mean, but if you don’t see component 2 in routines and you’re using App IOs right now you have that problem, which is reported, and it’s not a driver problem.
Not an Apple device–It’s an Android device. Here are the screen shots:
(also, You may not be able to tell, but my “Switch All On Off 1” is not a functioning button–you cannot change its state–your note above shows it “Off” to the left)
There are no routines available for switch2–only for main.
Multi-Tile Switch in a room:
Tile opened:
Switch 2 after scroll down on main:
Driver:
Settings:
Routines (only for main)
“Pool Pump Controller” is switch-1. That’s my main pool pump. Switch-2 is my cleaner pump. They each operate independently, and on separate schedules. The whole device is just a Zigbee relay controller, with 2 relays for 2 loads. And a power meter reporting.
I can turn them on/off independently. I can also now set a timer routine for switch1. But we must operate switch2 manually.
Really would be helpful to see 2 buttons (they could be children on a static tile, with the power meter), so that I can operate each pump separately, (just as before the driver change). And then set a routine for each button to turn on/off at various times of the day. Now we have a child on a parent, but cannot set a separate routine for the child, so it must be turned on/off manually. Thanks again for all your help and sorry to be such a pain…
Have you tried this setting?
@Mariano_Colmenarejo & NickA
Thanks–Yeah–as you can see above, it’s already set to “Create Single Device” – the alternative is “No Create Single Device” and I don’t even see a difference in the layout or options when it’s changed to the “No…” option. Happy to try anything, tho…
Before the driver changes earlier this year, it was a static tile with two buttons and a power meter. The two buttons were controls I could put on separate routines to operate each of my pool pumps. Never really cared about power consumption. Now it’s a button on a button, and only the parent has a routine–would like to try and sort that out.
Hi @wtmayes
As @NickA told you when you select create device in preferences, a separate switch is created for switch-2. When it is created it appears in the room where the Hub is and with the name of the switch2-main device name.
The timer problem in multicomponent devices has been reported for more than 1 year, then you can report it to smartthings again.
Creating the child device would not need it.
For switch 1 you can choose a simple tile in preferences and you will now have 2 independent devices.
If you tell me what model it is, I can change it to a profile with only power and energy on switch 1.
Ok–I found it. The Switch2 tile appeared in another room where I never look. Thanks.
Is there some way to ensure the third tile for “All Switch On-Off” does not appear…? Two independent switches (Sw1/Sw2) are all that is necessary for my application.
It is the “ZBMLC30-1” from “Compacta International, Ltd” If it shows the total power and energy for both, that’s fine.
Hi @wtmayes
If it’s already created, simply delete it like any other device.
In preferences, as long as you don’t make a value change from inactive to active in create the All switches device will not be recreated.
ZBMLC30-1 is already assigned to the profile that only shows power and energy in the main switch, I don’t know why in the screenshots it is seen in switch2 as well
Hi, @Mariano_Colmenarejo. I’m using your drivers very well. Thanks for your efforts.
May I ask to make some driver for me?
This is 2 gang battery- button switchs.
Infomation is below. Thanks in advance.
