I installed zigbee thing mc and paired it again, it automatically defaulted to Z-Wave Controller again when I added a new device.
Is there something else I can do to prevent that?
Thanks @Mariano_Colmenarejo , the problem is that it is Zigbee device!
(Iβm not sure why itβs being discovered as a Z-Wave Controller)
Is there anything else I can do to stop it mapping as a Z-Wave controller?
Here are the device details as soon as it pairs: https://puu.sh/JwFTA/10074cbdd5.png
The drivers for the 2 gang (different device that works great with your driver) mapped as βplaceholderβ https://puu.sh/JwFSV/f199b1ce54.png for the type (where device handler would previously be selected) and Febit 2 Gang Switch as the label and name.
Iβve swapped the 3gang type to Thing and placeholder but donβt get the same details/information screen as others.
@kortex
Do not change anything in IDE for edge drivers, they will stop working.
You have to uninstall the device with the app
Install the driver with the version date equal to or greater than the one I posted on your hub This is the correct channel link
Reinstall the device with the app
I have deleted and readded the device from the app.
It is still mapping as Z-Wave Controller.
Looking at the API+ browser it shows me it is still being added as Type: DTH.
Need to find this driver for the Zigbee Multi-Switch Mc if it works with the Smartenit ZBMLC30 dual load controller. Not finding this device in any fingerprints.
My switch just quit responding a few days ago, so I dumped my groovy DTH.
The Zigbee Switch Beta I tried does not allow control of both switchesβI have 2 pool pumpsβso I cannot run them both at the same time anymore. Tried Zigbee Thing and Zigbee Power/Metered typesβalso no luck.
BUT! ST has Smartenit Multi Load Controller native in the ST app, and it finds the device. It just installs Zigbee Switch. Old DTH worked great, but now Iβm stuckβany help would be appreciated!!
Okβfound the link that invites me to your beta channel. I installed the Zigbe Thing Mc and hereβs the screenshot!! It chops off the Manufacturer but thatβs βCompacta International, Ltdβ
I will delete and re-install with the Zigbee Multi Switch Mc and testβwill let you know soon.
Okβdifferent problem: If I want to choose your Mc driver, I donβt see it as available when I open the device. If I delete the device and then try to delete the original Zigbee Switch driver, it says the device is in use, and cannot be deleted. I have unsubscribed from the channel that provides their version of the driver. Only subscribed to yours.
Is there another way to force deletion of the drivers?
βββββββββββββββββββββββββββββββββββββββββββββββββββ
Name Zigbee Multi Switch and Child Mc
Version 2023-01-16T09:17:38.778779143
deviceLabel: FeiBit 3 Switch
manufacturer: FeiBit
model: FB56+ZSW1IKJ1.7
deviceProfileName: three-switch
Added to this driver version
This device support power and energy summation of two switch in main switch component (endpoint 1)
You have to uninstall the old version of Zigbee Multi Switch and Child Mc driver from your hub and reinstall the new version.
Uninstall the device and reinstall it.
If the driver does not recognize it, it could be that the manufacturer is not the correct one, I have doubts about the β, Ltdβ will not be a β. Ltdβ?
If the power or consumption is not correct tell me
- id: "Compacta International/ZBMLC30-1"
deviceLabel: ZBMLC30-1 Two Switch
manufacturer: Compacta International, Ltd
model: ZBMLC30-1
deviceProfileName: two-switch-power-energy-1
