(EDGE Driver-Mc) Zigbee switch MC, Zigbee switch power MC, Zigbee multi switch and child MC
Hi @Mariano_Colmenarejo
Ledvance Compact plug works with this driver very well.
Ledvance Outdoor plug is in other location and I couldn’t test it now.
Energy Meter is a nice added feature.
Many thanks again!
Bit unusual to supply the details needed for the driver in the link below Mariano but hopefully this page will supply required info
Oddly i thought you had already included the device but looking closer the device shows cloud in the ide so i csnt get the device info from there
I am using your driver for sure so maybe another zwave device has a similar fingerprint
Here is a link to the Zwave alliance details page for the device
https://products.z-wavealliance.org/products/629
Hi @fido
This device is Zwave, since this thread is zigbee I thought it was zigbee device.
I added it as generic without configuration parameters and I told you that with the Z-Wave Device Config Mc driver you could scan the values of all the device parameters and you could configure them according to the manual.
I should not have lost the configuration I had with the DTH
The driver works with the default handlers of the zwave edge libraries, if it doesn’t work and I have to make a custom subdriver, I think I won’t be able to do it.
Maybe @philh30 and @csstup can add it to their zwave driver and see if it works
It does work Mariano, on off and reports power, just fails to reflect changes in power draw unless pull down refresh is used
Your work is always appreciated though so thank you for your thoughts
Are you use IOs app? in Android does not work the refresh pull down
Android Mariano, pull down refresh works and changes the devices power draw shown on the devices page
It is a shame we lost the polster smart app, i could poll the device myself
Hi @thesels and @Subramanian_Swaminat
Added to this driver version
 Name         Zigbee Switch Mc
 Version      2022-09-28T18:23:09.372010692
  - id: "TS011F/_TZ3000_pnzfdr9y"
    deviceLabel: TS0101 Plug
    manufacturer: _TZ3000_pnzfdr9y
    model: TS0101
    deviceProfileName: single-switch-plug
  - id: "TS0001/_TZ3000_m0btfbt7"
    deviceLabel: TS0001 Plug
    manufacturer: _TZ3000_m0btfbt7
    model: TS0001
@fido I think this is a DTH that supported the device in question?
By default it should send energy reports with any 2% change in power, if I’m reading it right. The DTH also makes mention of different firmware versions supporting different features.
Without having the device to test with I’m not sure how practical it is to write a driver to support it.
Many thanks and appreciate your swift response, works perfectly.
That is the DTH i was using, it is still in my IDE but no longer used
I have a vague memory about fw differences which were minor changes in the devices settings but tbh it was a long time ago
Guessing you are in the US corey ?
Yep, sorry!
Thanks Mariano,
The LIDL TS0101 plug works with this driver.
Hi @Mariano_Colmenarejo, can the virtual mirror be configured as a button? In practice, I would need that once activated it would stay on for 0.5 seconds and then turn off. I searched the settings and found nothing. Thank you
I had some issues getting the child switch to be created but then somehow it worked and was discovered by alexa - not sure what i did but ill figure it out again with my others.
Works quickly and well so far
I am confused by one thing - should this now create 2 tile icons in the app or are both switches shown on one tile?
My only issue is when switches are on, switch 2 always shows off
Great work :muscle:t2:
Hi @welshbryn
The created device appears in the unassigned room.
Then you edit it and move it where you want and give it whatever name you want.
The switch-2 of the multi-tile should show the same as the one created.
The multiitile can be changed to a simple one, if you want
Hi.
Got the other tile yes :+1:t2: cant seem to simplify the main tile to only show device 1 no matter what I change, what am i missing?
Is it possible that the tile be changed to show a ‘socket icon’ instead of a switch?
To change it to single tiles:
In android, the change of mass between multiple and single works well, there are users who are complaining about this, I don’t know if it has to do with the app version, operating system or its accessories.
The icon to change options depends of the category of the profile, switch has some and smartPlug has others.
It has been requested that the icon be separated from the profile category and all icons be offered, but smartthings do not seem very receptive now
Shocker!!! They dont seem to be receptive to anything at the moment.
Hmmm. Ive done this with no change
