(EDGE Driver-Mc): Zigbee Light Multifunction Mc
@Mariano_Colmenarejo, All seems to be fine now as I checked my running the colour changing mode for 5 min but no idea what happened yesterday when I ran the colour changing mode to 30 min.
I also wanted to turn on the bulb and start the color changing mode straightaway but then realised that I need to write one routine to set the colour changing mode to active first and then another routine to turn on the bulb.
It works, but I cant get a 2700K color that works right. It looks totally blue when I use the driver slider to and drag it to 2700. Do I have to do a custom Hue and Saturation too? If so, what are people using for soft white? Left side off this image is the color produced when using the slider to 2700K.
Hi @Mariano_Colmenarejo, I was using this driver with my GLEDOPTO LED controller. It was working fine. But yesterday I was not able to change colors using the app. So I removed the device and added it back on. I had to re-install the driver but now I don’t see any options to change the colors. All the options are new which look very different. Can you please help with this?
That’s a bug in SmartThings, either the app or the cloud. I’ve also seen the colour picker disappear once and I don’t use Mc drivers.
Maybe wait till it solves itself or try the usual clear caches of the app or force stop if it’s on Android.
@Mariano_Colmenarejo, Just checking if this driver will support this Neon strip (link below) in case someone else has requested this or something like this before?
Zigbee 3.0 Neon LED Strip RGB Light USB 5V Tape Ribbon Dimmable Work With Tuya Smart Gateway Hue Bridge SmartThings Alexa Google - AliExpress 39
I don’t know, without knowing the fingerprints and the clusters it is impossible
@Mariano_Colmenarejo, I have been using his driver for my Zigbee bulbs and it turns on when the door is opened and turns off when the door is closed. I have noticed twice now that the bulb does not turn off when the door is closed though it has worked perfectly in the last few months. Now it’s working but I had to take the bulb off and put it back in for it to start working normally. Previously when the bulb did not turn off, I looked at the app and the status was ‘off’ and then I tried to turn it back on but was not able to as it threw a server or network error so I had to take the bulb out and put it back in after which it started working. Any advice what could have gone wrong? All other bulbs are working normally.
The driver hasn’t changed in a long time and so I don’t think it’s the driver’s fault.
What has changed is the hub firmware to 53.19 and I had a similar problem with 3 devices, smoke sensor and 2 remote controls.
I sent the hub logs to @nayelyz and the smartthings team analyzed them.
The conclusion was that the 3 devices had a common device as a zigbee route to the hub.
This device did a rejoint and changed ID and the 3 devices that weren’t working were left orphaned, with no route to connect to the hub.
I had to remove the battery and reinstall it, so that they would relink via a new route to the hub.
The route should have been redone by itself, but after more than a day it didn’t happen.
maybe the new zigbee stack of firmware 53.19 doesn’t work correctly in these cases. It hasn’t happened to me again since the beginning of July.
I don’t know if this is your case, but it seems similar to me.
Many thanks, will monitor for a few more days and hopefully it should have sorted itself now
Hi @Mariano_Colmenarejo, how are you?
Please add the fingerprint to your driver for this gledopto bulb:
Gledopto 7W LED Filament Bulb Pro
It has the Switch, Level & ColorTemperature Profile.
According to Gledopto, color temp range is 2200 to 2700?
From Zigbee Things MC:
Manufacturer: GLEDOPTO
Model: GL-B-003P
FingerPrinted_EndPoint.Id: 0x0B
App Version: 0x01
ZCL Version: 0x03
Network ID: 0x73DF
Zigbee EUI: A4C138FE9485FEA6
Device ID: bf2e0f7a-6c83-42fe-b535-16ddddd4a69a
Server Cluster:
Ep: 0x0B={ 0000,0003,0004,0005,0006,0008,0300,
1000 }
Client Clusters:
Ep: 0xF2={ 0021 }
Ep: 0x0B={ 0019 }
Signal Metrics:
LQI: 255 .... RSSI: -64 dbm
Hi, @marcos.scheffler
Added to this driver version with profile level-colortemp-2200-6500. According Gledopto web
You need uninstall device and reinstall with thi driver version installed in your Hub for correct profile assignment and device configuration
 Name         Zigbee Light Multifunction Mc
 Version      2024-08-16T21:09:06.849556314
- id: "GLEDOPTO/GL-B-003P"
    deviceLabel: GLEDOPTO GL-B-003P
    manufacturer: GLEDOPTO
    model: GL-B-003P
    deviceProfileName: level-colortemp-2200-6500
Hello,
In case anyone is interested, I have added the RGBW Bulb LEDVANCE, Classic 60 E27 Multicolor, it works very well and is cheap 13 Eur on Amazon.
This bulb supports the adjustment of the settings after a power loss, with the options:
  • Turn Off
  • Turn On
  • Restore Previous State
When you choose Turn On or Restore Previous State, the bulb turns on with the same values ​​of level, color Temperature and color used before the power outage.
Transition times for off, level, color temperature commands works fine too
These are the fingerprints of the bulb.
- id: "LEDVANCE/A60 RGBW T"
    deviceLabel: LEDVANCE Classis A60 RGBW
    manufacturer: LEDVANCE
    model: A60 RGBW T
    deviceProfileName: rgbw-level-colortemp-2000-6500
Thanks @Mariano_Colmenarejo !
Purchased the 5m neon light strip and paired with your driver straight. All working fine, thanks.
No issues in the last few weeks so must have sorted itself out.
Would you be able to add the following innr comfort buld tunable white 2000k-6500k bulb please? It currently adds with your driver but doesn’t function other than on/off.
Model AE 270 T
Type ZIGBEE
Manufacturer Code innr
Thanks in advance
Hi @Terri_Baker
I don’t think this will solve the problem. If it persists you should send the logs so we can analyze what is happening.
 Version      2024-09-24T11:43:50.891740264
- id: "innr/AE 270 T"
    deviceLabel: innr RGBW
    manufacturer: innr
    model: AE 270 T
    deviceProfileName: level-colortemp-2000-6500
The light adds with the correct fingerprint. When added it is at 100%.
Dimming will not work.
Temp using presets or slide bar work.
Blink function works alternating between off>1%>100%>off 3 times.
Off works
On works but it comes on at 1% brightness and cannot be adjusted.
There is not Logs
Inclusion Log
Manufacturer: innr Model: AE 270 T
[1]: server: Basic, Identify, Groups, Scenes, OnOff, Level, ColorControl, TouchlinkCommissioning | client: Time, OTAUpgrade [242]: server | client: 0x0021
2024-09-26T19:12:18.996639883Z INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 09b705ac-20a2-4b7b-84fa-fc29d64490bc [0xD96B] (innr RGBW)> received lifecycle event: added
2024-09-26T19:12:19.485550133Z TRACE Zigbee Light Multifunction Mc Received event with handler device_lifecycle
2024-09-26T19:12:19.565522766Z INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 09b705ac-20a2-4b7b-84fa-fc29d64490bc [0xD96B] (innr RGBW)> received lifecycle event: doConfigure
2024-09-26T19:12:19.584720110Z TRACE Zigbee Light Multifunction Mc Found DeviceLifecycleDispatcher handler in zigbee_light_multifunctions
2024-09-26T19:12:19.684444572Z INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 09b705ac-20a2-4b7b-84fa-fc29d64490bc [0xD96B] (innr RGBW)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xD96B, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x0000, DataType: Boolean, minimum_reporting_interval: 0x0000, maximum_reporting_interval: 0x012C > > > >
2024-09-26T19:12:19.853406178Z PRINT Zigbee Light Multifunction Mc Remove Groups >>>>>>>>>>>>>>>>>
2024-09-26T19:12:20.457386433Z INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 09b705ac-20a2-4b7b-84fa-fc29d64490bc [0xD96B] (innr RGBW)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xD96B, dest_endpoint: 0x01, profile: 0x0104, cluster: Groups >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x01, seqno: 0x00, ZCLCommandId: 0x03 >, < RemoveGroup || group_id: 0x0001 > > >
2024-09-26T19:12:20.614640855Z INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 09b705ac-20a2-4b7b-84fa-fc29d64490bc [0xD96B] (innr RGBW)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xD96B, dest_endpoint: 0x01, profile: 0x0104, cluster: Groups >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x01, seqno: 0x00, ZCLCommandId: 0x02 >, < GetGroupMembership || group_list_length: 0x00 > > >
2024-09-26T19:12:20.729817748Z INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 09b705ac-20a2-4b7b-84fa-fc29d64490bc [0xD96B] (innr RGBW)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xD96B, dest_endpoint: 0x01, profile: 0x0104, cluster: Groups >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x01, seqno: 0x00, ZCLCommandId: 0x02 >, < GetGroupMembership || group_list_length: 0x00 > > >
2024-09-26T19:12:21.367168806Z INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 09b705ac-20a2-4b7b-84fa-fc29d64490bc [0xD96B] (innr RGBW)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xD96B, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x02 >, < WriteAttribute || < AttributeRecord || attr_id: 0x4003, DataType: Enum8, data: 0xFF > > > >
2024-09-26T19:12:21.633396603Z INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 09b705ac-20a2-4b7b-84fa-fc29d64490bc [0xD96B] (innr RGBW)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xD96B, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x02 >, < WriteAttribute || < AttributeRecord || attr_id: 0x8002, DataType: Enum8, data: 0x02 > > > >
2024-09-26T19:12:21.806638139Z PRINT Zigbee Light Multifunction Mc Device ID <ZigbeeDevice: 09b705ac-20a2-4b7b-84fa-fc29d64490bc [0xD96B] (innr RGBW)>
2024-09-26T19:12:21.810484019Z PRINT Zigbee Light Multifunction Mc Manufacturer >>> innr Manufacturer_Len >>> 4
2024-09-26T19:12:21.851741513Z PRINT Zigbee Light Multifunction Mc Model >>> AE 270 T Model_len >>> 8
2024-09-26T19:12:21.862060253Z PRINT Zigbee Light Multifunction Mc <<<<< Firmware Version >>>>> nil
2024-09-26T19:12:21.873067420Z PRINT Zigbee Light Multifunction Mc Memory >>>>>>> 1322.5244140625
Kbytes
2024-09-26T19:12:21.883205737Z DEBUG Zigbee Light Multifunction Mc innr RGBW device thread event handled
2024-09-26T19:12:21.954143772Z TRACE Zigbee Light Multifunction Mc Received event with handler zigbee
2024-09-26T19:12:22.395342094Z INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 09b705ac-20a2-4b7b-84fa-fc29d64490bc [0xD96B] (innr RGBW)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD96B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xCE, rssi: -59, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x12, ZCLCommandId: 0x07 >, < ConfigureReportingResponse || < ConfigureReportingResponseRecord || ZclStatus: SUCCESS, direction: 0x00, attr_id: 0x0000 > > > >
2024-09-26T19:12:23.669450121Z TRACE Zigbee Light Multifunction Mc Found DeviceLifecycleDispatcher handler in zigbee_light_multifunctions
2024-09-26T19:12:24.385056246Z INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 09b705ac-20a2-4b7b-84fa-fc29d64490bc [0xD96B] (innr RGBW)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xD96B, dest_endpoint: 0x01, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: A4C1382AA2390DE0, src_endpoint: 0x01, cluster: ColorControl, dest_addr_mode: 0x03, dest_address: 286D970002072EFB, dest_endpoint: 0x01 > > >
2024-09-26T19:12:24.607028885Z INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 09b705ac-20a2-4b7b-84fa-fc29d64490bc [0xD96B] (innr RGBW)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xD96B, dest_endpoint: 0x01, profile: 0x0104, cluster: ColorControl >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x0007, DataType: Uint16, minimum_reporting_interval: 0x0001, maximum_reporting_interval: 0x0E10, reportable_change: 0x0010 > > > >
2024-09-26T19:12:24.792858503Z INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 09b705ac-20a2-4b7b-84fa-fc29d64490bc [0xD96B] (innr RGBW)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xD96B, dest_endpoint: 0x01, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: A4C1382AA2390DE0, src_endpoint: 0x01, cluster: OnOff, dest_addr_mode: 0x03, dest_address: 286D970002072EFB, dest_endpoint: 0x01 > > >
2024-09-26T19:12:24.907673007Z INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 09b705ac-20a2-4b7b-84fa-fc29d64490bc [0xD96B] (innr RGBW)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xD96B, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x0000, DataType: Boolean, minimum_reporting_interval: 0x0000, maximum_reporting_interval: 0x012C > > > >
2024-09-26T19:12:25.070904457Z INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 09b705ac-20a2-4b7b-84fa-fc29d64490bc [0xD96B] (innr RGBW)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xD96B, dest_endpoint: 0x01, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: A4C1382AA2390DE0, src_endpoint: 0x01, cluster: Level, dest_addr_mode: 0x03, dest_address: 286D970002072EFB, dest_endpoint: 0x01 > > >
2024-09-26T19:12:25.352255354Z INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 09b705ac-20a2-4b7b-84fa-fc29d64490bc [0xD96B] (innr RGBW)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xD96B, dest_endpoint: 0x01, profile: 0x0104, cluster: Level >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x0000, DataType: Uint8, minimum_reporting_interval: 0x0001, maximum_reporting_interval: 0x0E10, reportable_change: 0x01 > > > >
2024-09-26T19:12:25.398855559Z PRINT Zigbee Light Multifunction Mc doConfigure performed, transitioning device to PROVISIONED
2024-09-26T19:12:25.448047601Z DEBUG Zigbee Light Multifunction Mc innr RGBW device thread event handled
2024-09-26T19:12:25.461321068Z DEBUG Zigbee Light Multifunction Mc <ZigbeeDevice: 09b705ac-20a2-4b7b-84fa-fc29d64490bc [0xD96B] (innr RGBW)> doConfigure callback did not fail, transitioning device to “PROVISIONED”
2024-09-26T19:12:25.474544009Z TRACE Zigbee Light Multifunction Mc Found DeviceLifecycleDispatcher handler in zigbee_light_multifunctions
2024-09-26T19:12:25.563495421Z PRINT Zigbee Light Multifunction Mc <<<<< Device Init >>>>>>
2024-09-26T19:12:25.576931928Z PRINT Zigbee Light Multifunction Mc <<<<< device: <ZigbeeDevice: 09b705ac-20a2-4b7b-84fa-fc29d64490bc [0xD96B] (innr RGBW)>
2024-09-26T19:12:25.590499250Z INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 09b705ac-20a2-4b7b-84fa-fc29d64490bc [0xD96B] (innr RGBW)> emitting event: {“attribute_id”:“progOn”,“capability_id”:“legendabsolute60149.progressiveOn1”,“component_id”:“main”,“state”:{“value”:“Inactive”}}
2024-09-26T19:12:25.658613415Z INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 09b705ac-20a2-4b7b-84fa-fc29d64490bc [0xD96B] (innr RGBW)> emitting event: {“attribute_id”:“progOff”,“capability_id”:“legendabsolute60149.progressiveOff1”,“component_id”:“main”,“state”:{“value”:“Inactive”}}
2024-09-26T19:12:25.781038638Z INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 09b705ac-20a2-4b7b-84fa-fc29d64490bc [0xD96B] (innr RGBW)> emitting event: {“attribute_id”:“circadian”,“capability_id”:“legendabsolute60149.circadian”,“component_id”:“main”,“state”:{“value”:“Inactive”}}
2024-09-26T19:12:26.096131981Z INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 09b705ac-20a2-4b7b-84fa-fc29d64490bc [0xD96B] (innr RGBW)> emitting event: {“attribute_id”:“randomOnOff”,“capability_id”:“legendabsolute60149.randomOnOff1”,“component_id”:“main”,“state”:{“value”:“Inactive”}}
2024-09-26T19:12:26.436091418Z INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 09b705ac-20a2-4b7b-84fa-fc29d64490bc [0xD96B] (innr RGBW)> emitting event: {“attribute_id”:“randomNext”,“capability_id”:“legendabsolute60149.randomNextStep”,“component_id”:“main”,“state”:{“value”:“Inactive”}}
2024-09-26T19:12:26.752729449Z INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 09b705ac-20a2-4b7b-84fa-fc29d64490bc [0xD96B] (innr RGBW)> emitting event: {“attribute_id”:“forcedOnLevel”,“capability_id”:“legendabsolute60149.forcedOnLevel”,“component_id”:“main”,“state”:{“value”:0}}
2024-09-26T19:12:26.950409490Z INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 09b705ac-20a2-4b7b-84fa-fc29d64490bc [0xD96B] (innr RGBW)> emitting event: {“attribute_id”:“mirrorGroupFunction”,“capability_id”:“legendabsolute60149.mirrorGroupFunction”,“component_id”:“main”,“state”:{“value”:“Inactive”}}
2024-09-26T19:12:28.665973635Z INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 09b705ac-20a2-4b7b-84fa-fc29d64490bc [0xD96B] (innr RGBW)> emitting event: {“attribute_id”:“effectsSetCommand”,“capability_id”:“legendabsolute60149.effectsSetCommand”,“component_id”:“main”,“state”:{“value”:“Inactive”}}
2024-09-26T19:12:29.416986162Z INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 09b705ac-20a2-4b7b-84fa-fc29d64490bc [0xD96B] (innr RGBW)> emitting event: {“attribute_id”:“levelSteps”,“capability_id”:“legendabsolute60149.levelSteps”,“component_id”:“main”,“state”:{“value”:0}}
2024-09-26T19:12:29.836250606Z INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 09b705ac-20a2-4b7b-84fa-fc29d64490bc [0xD96B] (innr RGBW)> emitting event: {“attribute_id”:“colorTempSteps”,“capability_id”:“legendabsolute60149.colorTemperatureSteps”,“component_id”:“main”,“state”:{“value”:0}}
2024-09-26T19:12:30.053999135Z DEBUG Zigbee Light Multifunction Mc innr RGBW device thread event handled
2024-09-26T19:12:30.232761680Z TRACE Zigbee Light Multifunction Mc Received event with handler zigbee
2024-09-26T19:12:30.976931287Z INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 09b705ac-20a2-4b7b-84fa-fc29d64490bc [0xD96B] (innr RGBW)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD96B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Groups >, lqi: 0xCE, rssi: -58, body_length: 0x0006, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x19, seqno: 0x13, ZCLCommandId: 0x03 >, < RemoveGroupResponse || status: 0x8B, group_id: 0x0001 > > >
2024-09-26T19:12:31.683458291Z DEBUG Zigbee Light Multifunction Mc innr RGBW device thread event handled
2024-09-26T19:12:32.063714824Z TRACE Zigbee Light Multifunction Mc Received event with handler zigbee
2024-09-26T19:12:32.370891169Z INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 09b705ac-20a2-4b7b-84fa-fc29d64490bc [0xD96B] (innr RGBW)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD96B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Groups >, lqi: 0xCC, rssi: -58, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x19, seqno: 0x14, ZCLCommandId: 0x02 >, < GetGroupMembershipResponse || capacity: 0x20, group_list_length: 0x00 > > >
2024-09-26T19:12:34.727734585Z DEBUG Zigbee Light Multifunction Mc innr RGBW device thread event handled
2024-09-26T19:12:34.747191350Z TRACE Zigbee Light Multifunction Mc Received event with handler zigbee
2024-09-26T19:12:34.748403915Z INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 09b705ac-20a2-4b7b-84fa-fc29d64490bc [0xD96B] (innr RGBW)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD96B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Groups >, lqi: 0xCE, rssi: -59, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x19, seqno: 0x15, ZCLCommandId: 0x02 >, < GetGroupMembershipResponse || capacity: 0x20, group_list_length: 0x00 > > >
2024-09-26T19:12:35.922712067Z DEBUG Zigbee Light Multifunction Mc innr RGBW device thread event handled
2024-09-26T19:12:36.078030729Z TRACE Zigbee Light Multifunction Mc Found ZigbeeMessageDispatcher handler in zigbee_light_multifunctions
2024-09-26T19:12:36.082486748Z INFO Zigbee Light Multifunction Mc Executing ZclClusterCommandHandler: cluster: Groups, command: GetGroupMembership
2024-09-26T19:12:36.093352261Z PRINT Zigbee Light Multifunction Mc group_list >>>>>> {}
2024-09-26T19:12:36.236768517Z INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 09b705ac-20a2-4b7b-84fa-fc29d64490bc [0xD96B] (innr RGBW)> emitting event: {“attribute_id”:“getGroups”,“capability_id”:“legendabsolute60149.getGroups”,“component_id”:“main”,“state”:{“value”:“DeleteAllGroups”}}
2024-09-26T19:12:36.603393946Z DEBUG Zigbee Light Multifunction Mc innr RGBW device thread event handled
2024-09-26T19:12:36.620919288Z DEBUG Zigbee Light Multifunction Mc driver device thread event handled
2024-09-26T19:12:36.624112550Z TRACE Zigbee Light Multifunction Mc Received event with handler zigbee
2024-09-26T19:12:37.362180025Z INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 09b705ac-20a2-4b7b-84fa-fc29d64490bc [0xD96B] (innr RGBW)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD96B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xCE, rssi: -60, body_length: 0x0004, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x16, ZCLCommandId: 0x04 >, < WriteAttributeReponse || ZclStatus: SUCCESS > > >
2024-09-26T19:12:38.700166351Z TRACE Zigbee Light Multifunction Mc Found ZigbeeMessageDispatcher handler in zigbee_light_multifunctions
2024-09-26T19:12:38.721950696Z INFO Zigbee Light Multifunction Mc Executing ZclClusterCommandHandler: cluster: Groups, command: GetGroupMembership
2024-09-26T19:12:38.839511447Z PRINT Zigbee Light Multifunction Mc group_list >>>>>> {}
2024-09-26T19:12:38.845033748Z INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 09b705ac-20a2-4b7b-84fa-fc29d64490bc [0xD96B] (innr RGBW)> emitting event: {“attribute_id”:“getGroups”,“capability_id”:“legendabsolute60149.getGroups”,“component_id”:“main”,“state”:{“value”:“DeleteAllGroups”}}
2024-09-26T19:12:39.244654625Z DEBUG Zigbee Light Multifunction Mc innr RGBW device thread event handled
2024-09-26T19:12:39.329143057Z TRACE Zigbee Light Multifunction Mc Received event with handler zigbee
2024-09-26T19:12:39.389971372Z INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 09b705ac-20a2-4b7b-84fa-fc29d64490bc [0xD96B] (innr RGBW)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD96B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xCA, rssi: -58, body_length: 0x0006, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x17, ZCLCommandId: 0x04 >, < WriteAttributeReponse || < WriteAttributeResponseRecord || ZclStatus: UNSUPPORTED_ATTRIBUTE, AttributeId: 0x8002 > > > >
2024-09-26T19:12:39.969739195Z DEBUG Zigbee Light Multifunction Mc innr RGBW device thread event handled
2024-09-26T19:12:40.054258016Z TRACE Zigbee Light Multifunction Mc Received event with handler zigbee
2024-09-26T19:12:40.092653746Z INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 09b705ac-20a2-4b7b-84fa-fc29d64490bc [0xD96B] (innr RGBW)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD96B, src_endpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: 0x8021 >, lqi: 0xD0, rssi: -58, body_length: 0x0002, < ZDOMessageBody || < ZDOHeader || seqno: 0x19 >, < BindRequestResponse || status: 0x00 > > >
2024-09-26T19:12:40.832081109Z DEBUG Zigbee Light Multifunction Mc innr RGBW device thread event handled
2024-09-26T19:12:40.834510698Z TRACE Zigbee Light Multifunction Mc Received event with handler zigbee
2024-09-26T19:12:41.181527328Z INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 09b705ac-20a2-4b7b-84fa-fc29d64490bc [0xD96B] (innr RGBW)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD96B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: ColorControl >, lqi: 0xD0, rssi: -58, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x1A, ZCLCommandId: 0x07 >, < ConfigureReportingResponse || < ConfigureReportingResponseRecord || ZclStatus: SUCCESS, direction: 0x00, attr_id: 0x0007 > > > >
2024-09-26T19:12:41.646014581Z DEBUG Zigbee Light Multifunction Mc innr RGBW device thread event handled
2024-09-26T19:12:41.649638892Z TRACE Zigbee Light Multifunction Mc Received event with handler zigbee
2024-09-26T19:12:41.654229894Z INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 09b705ac-20a2-4b7b-84fa-fc29d64490bc [0xD96B] (innr RGBW)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD96B, src_endpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: 0x8021 >, lqi: 0xCC, rssi: -58, body_length: 0x0002, < ZDOMessageBody || < ZDOHeader || seqno: 0x1A >, < BindRequestResponse || status: 0x00 > > >
2024-09-26T19:12:42.231236212Z DEBUG Zigbee Light Multifunction Mc innr RGBW device thread event handled
2024-09-26T19:12:42.242557870Z TRACE Zigbee Light Multifunction Mc Received event with handler zigbee
2024-09-26T19:12:42.243499132Z INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 09b705ac-20a2-4b7b-84fa-fc29d64490bc [0xD96B] (innr RGBW)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD96B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xCC, rssi: -58, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x61, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Boolean, OnOff: true > > > >
2024-09-26T19:12:43.528104906Z DEBUG Zigbee Light Multifunction Mc innr RGBW device thread event handled
2024-09-26T19:12:43.540840729Z TRACE Zigbee Light Multifunction Mc Received event with handler zigbee
2024-09-26T19:12:43.541683650Z INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 09b705ac-20a2-4b7b-84fa-fc29d64490bc [0xD96B] (innr RGBW)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD96B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xCC, rssi: -57, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x1C, ZCLCommandId: 0x07 >, < ConfigureReportingResponse || < ConfigureReportingResponseRecord || ZclStatus: SUCCESS, direction: 0x00, attr_id: 0x0000 > > > >
2024-09-26T19:12:44.583738876Z TRACE Zigbee Light Multifunction Mc Found ZigbeeMessageDispatcher handler in zigbee_light_multifunctions
2024-09-26T19:12:44.653851623Z INFO Zigbee Light Multifunction Mc Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2024-09-26T19:12:44.692593401Z INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 09b705ac-20a2-4b7b-84fa-fc29d64490bc [0xD96B] (innr RGBW)> emitting event: {“attribute_id”:“signalMetrics”,“capability_id”:“legendabsolute60149.signalMetrics”,“component_id”:“main”,“state”:{“value”:“2024/09/26 Time: 19:12, LQI: 204 … rssi: -58”},“visibility”:{“displayed”:false}}
2024-09-26T19:12:44.873071803Z INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 09b705ac-20a2-4b7b-84fa-fc29d64490bc [0xD96B] (innr RGBW)> emitting event: {“attribute_id”:“switch”,“capability_id”:“switch”,“component_id”:“main”,“state”:{“value”:“on”}}
2024-09-26T19:12:44.990738315Z DEBUG Zigbee Light Multifunction Mc innr RGBW device thread event handled
2024-09-26T19:12:45.060453781Z TRACE Zigbee Light Multifunction Mc Received event with handler zigbee
2024-09-26T19:12:45.066794575Z INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 09b705ac-20a2-4b7b-84fa-fc29d64490bc [0xD96B] (innr RGBW)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD96B, src_endpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: 0x8021 >, lqi: 0xCE, rssi: -59, body_length: 0x0002, < ZDOMessageBody || < ZDOHeader || seqno: 0x1B >, < BindRequestResponse || status: 0x00 > > >
2024-09-26T19:12:45.970879558Z DEBUG Zigbee Light Multifunction Mc innr RGBW device thread event handled
2024-09-26T19:12:45.972141939Z TRACE Zigbee Light Multifunction Mc Received event with handler zigbee
2024-09-26T19:12:46.062377701Z INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 09b705ac-20a2-4b7b-84fa-fc29d64490bc [0xD96B] (innr RGBW)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD96B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Level >, lqi: 0xD0, rssi: -58, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x1D, ZCLCommandId: 0x07 >, < ConfigureReportingResponse || < ConfigureReportingResponseRecord || ZclStatus: SUCCESS, direction: 0x00, attr_id: 0x0000 > > > >
2024-09-26T19:12:47.170245525Z DEBUG Zigbee Light Multifunction Mc innr RGBW device thread event handled
2024-09-26T19:12:47.185776578Z TRACE Zigbee Light Multifunction Mc Received event with handler zigbee
2024-09-26T19:12:47.932125066Z INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 09b705ac-20a2-4b7b-84fa-fc29d64490bc [0xD96B] (innr RGBW)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD96B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: ColorControl >, lqi: 0xCC, rssi: -57, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x62, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0007, DataType: Uint16, ColorTemperatureMireds: 0x0172 > > > >
2024-09-26T19:12:49.438949852Z DEBUG Zigbee Light Multifunction Mc innr RGBW device thread event handled
2024-09-26T19:12:49.455311820Z TRACE Zigbee Light Multifunction Mc Received event with handler zigbee
2024-09-26T19:12:49.647994030Z INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 09b705ac-20a2-4b7b-84fa-fc29d64490bc [0xD96B] (innr RGBW)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD96B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Level >, lqi: 0xCE, rssi: -58, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x63, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Uint8, CurrentLevel: 0xFE > > > >
2024-09-26T19:12:50.574451152Z TRACE Zigbee Light Multifunction Mc Found ZigbeeMessageDispatcher handler in zigbee_light_multifunctions
2024-09-26T19:12:50.638306564Z INFO Zigbee Light Multifunction Mc Executing ZclClusterAttributeValueHandler: cluster: ColorControl, attribute: ColorTemperatureMireds
2024-09-26T19:12:50.716963915Z INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 09b705ac-20a2-4b7b-84fa-fc29d64490bc [0xD96B] (innr RGBW)> emitting event: {“attribute_id”:“colorTemperature”,“capability_id”:“colorTemperature”,“component_id”:“main”,“state”:{“value”:6500}}
2024-09-26T19:12:50.984146689Z DEBUG Zigbee Light Multifunction Mc innr RGBW device thread event handled
2024-09-26T19:12:51.003655355Z TRACE Zigbee Light Multifunction Mc Received event with handler device_lifecycle
2024-09-26T19:12:51.211672520Z INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 09b705ac-20a2-4b7b-84fa-fc29d64490bc [0xD96B] (innr RGBW 1)> received lifecycle event: infoChanged
2024-09-26T19:12:52.527404933Z TRACE Zigbee Light Multifunction Mc Found ZigbeeMessageDispatcher handler in zigbee_light_multifunctions
2024-09-26T19:12:52.541965751Z INFO Zigbee Light Multifunction Mc Executing ZclClusterAttributeValueHandler: cluster: Level, attribute: CurrentLevel
2024-09-26T19:12:52.543313133Z INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 09b705ac-20a2-4b7b-84fa-fc29d64490bc [0xD96B] (innr RGBW 1)> emitting event: {“attribute_id”:“level”,“capability_id”:“switchLevel”,“component_id”:“main”,“state”:{“value”:100}}
2024-09-26T19:12:53.968151405Z DEBUG Zigbee Light Multifunction Mc innr RGBW device thread event handled
2024-09-26T19:12:53.992273210Z TRACE Zigbee Light Multifunction Mc Found DeviceLifecycleDispatcher handler in zigbee_light_multifunctions
2024-09-26T19:12:54.083287986Z PRINT Zigbee Light Multifunction Mc Device ID <ZigbeeDevice: 09b705ac-20a2-4b7b-84fa-fc29d64490bc [0xD96B] (innr RGBW 1)>
2024-09-26T19:12:54.170016454Z PRINT Zigbee Light Multifunction Mc Manufacturer >>> innr Manufacturer_Len >>> 4
2024-09-26T19:12:54.197372708Z PRINT Zigbee Light Multifunction Mc Model >>> AE 270 T Model_len >>> 8
2024-09-26T19:12:54.232112444Z PRINT Zigbee Light Multifunction Mc <<<<< Firmware Version >>>>> nil
2024-09-26T19:12:54.254542654Z PRINT Zigbee Light Multifunction Mc Memory >>>>>>> 1783.4326171875
Kbytes
2024-09-26T19:12:54.261021683Z DEBUG Zigbee Light Multifunction Mc innr RGBW device thread event handled
2024-09-26T19:12:54.288767133Z DEBUG Zigbee Light Multifunction Mc driver device thread event handled
2024-09-26T19:13:21.164624516Z DEBUG Zigbee Light Multifunction Mc driver device thread event handled
2024-09-26T19:13:30.121302284Z TRACE Zigbee Light Multifunction Mc Received event with handler zigbee
2024-09-26T19:13:30.191545805Z INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 82ac0a2c-d409-427d-9f25-0dd46c3b996e [0xF336] (Lamp)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xF336, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xC8, rssi: -57, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x3A, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Boolean, OnOff: false > > > >
2024-09-26T19:13:30.557832940Z TRACE Zigbee Light Multifunction Mc Found ZigbeeMessageDispatcher handler in zigbee_light_multifunctions
2024-09-26T19:13:30.561357702Z INFO Zigbee Light Multifunction Mc Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2024-09-26T19:13:30.585609155Z INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 82ac0a2c-d409-427d-9f25-0dd46c3b996e [0xF336] (Lamp)> emitting event: {“attribute_id”:“signalMetrics”,“capability_id”:“legendabsolute60149.signalMetrics”,“component_id”:“main”,“state”:{“value”:“2024/09/26 Time: 19:13, LQI: 200 … rssi: -57”},“visibility”:{“displayed”:false}}
2024-09-26T19:13:30.646365101Z INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 82ac0a2c-d409-427d-9f25-0dd46c3b996e [0xF336] (Lamp)> emitting event: {“attribute_id”:“switch”,“capability_id”:“switch”,“component_id”:“main”,“state”:{“value”:“off”}}
2024-09-26T19:13:30.750494973Z DEBUG Zigbee Light Multifunction Mc Lamp device thread event handled
2024-09-26T19:13:42.881810518Z TRACE Zigbee Light Multifunction Mc Received event with handler zigbee
2024-09-26T19:13:43.144373776Z INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 64447c52-9d50-4a65-b032-c293bac53e37 [0xC0F6] (Master Lamp 2)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xC0F6, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xD2, rssi: -80, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x41, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Boolean, OnOff: false > > > >
2024-09-26T19:13:43.875043636Z TRACE Zigbee Light Multifunction Mc Found ZigbeeMessageDispatcher handler in zigbee_light_multifunctions
2024-09-26T19:13:43.886025875Z INFO Zigbee Light Multifunction Mc Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2024-09-26T19:13:43.912853115Z INFO Zigbee Light Multifunction Mc <ZigbeeDevice: 64447c52-9d50-4a65-b032-c293bac53e37 [0xC0F6] (Master Lamp 2)> emitting event: {“attribute_id”:“switch”,“capability_id”:“switch”,“component_id”:“main”,“state”:{“value”:“off”}}
2024-09-26T19:13:44.019777884Z DEBUG Zigbee Light Multifunction Mc Master Lamp 2 device thread event handled
2024-09-26T19:13:51.346827871Z DEBUG Zigbee Light Multifunction Mc driver device thread event handled
2024-09-26T19:14:21.154257849Z DEBUG Zigbee Light Multifunction Mc driver device thread event handled
