hello again, today i had my main UPS go out, which brought down the hub. Once i got power restored, my new Sengled e11 n13a will not reconnect to the hub. it installed with the Zigbee Switch driver. will this device work with one of your drivers?
details:
gracias parcero. this is my first experience with a zigbee bulb device losing connection and turning on and not reconnecting. i did some reading, and saw that others changed their bulbs, for a bulb that had a driver that would reconnect properly after a hub power outage. i was just wondering if this was possible. thanks, i performed Sengled re-pair procedure, and the bulb reconnected after performing a Scan for Nearby Devices during the bulb reset procedure, it paired and remained the same device in my list. not the most inconvenient issue… but… still an issue. thanks for looking in to this.
