Ah ok. Then letβs hope a solution presents itself
Hello
Please add this china made zigbee rgb e27 bulb.
Itβs Yandhi A60 Tuya Zigbee rgb+cw+ww 10w 806lm.
Data:
zigbeeNodeType: ROUTER
application: 52
endpointId: 01
manufacturer: _TZ3000_12sxjap4
model: TS0505B
Raw Description:
01 0104 010D 01 08 0000 0003 0004 0005 0006 1000 0008 0300 02 0019 000A
Hello
I have Lidl bulb and have tried to use Zigbee Light Multifunction Mc driver.
But bulb is always using IDE driver.
Bulb type is Lidl Livarno Lux E27 9W RGBW Bulb (Model HG07834C)
Color temperature 2000-6500K
Data * application: 41
endpointId: 01
manufacturer: _TZ3000_qd7hej8u
model: TS0505B
Raw Description 01 0104 010D 01 08 0000 0003 0004 0005 0006 1000 0008 0300 02 0019 000A
Please add this bulb to driver
Added to this driver version
βββββββββββββββ¬βββββββββββββββββββββββββββββββββββββββ
β Name β Zigbee Light Multifunction Mc β
β Version β 2022-02-19T12:18:38.869593 β
βββββββββββββββ΄βββββββββββββββββββββββββββββββββββββββ
- id: "_TZ3000_12sxjap4/TS0505B"
deviceLabel: TS0505B RGBW
model: TS0505B
deviceProfileName: rgbw-level-colortemp-2700-6500
- id: "_TZ3000_qd7hej8u/TS0505B"
model: TS0505B
Thanks for your quick reply.
Now Lidl bulb is using Zigbee Light Multifunction Mc driver.
Many thanks for your great work!
Here in Canada i have an ikea tradfri E12 bulb that seems to fit the E14 profile shown at the top, but obviously isnt getting picked up since it doesnβt match.
Data * application: 21
- endpointId: 01
- firmwareFullVersion: 23050631
- firmwareImageType: 16901
- firmwareManufacturerCode: 4476
- manufacturer: IKEA of Sweden
- model: TRADFRI bulb E12 WS 450lm
- zigbeeNodeType: ROUTER
Raw Description 01 0104 010C 01 09 0000 0003 0004 0005 0006 0008 0300 1000 FC7C 04 0005 0019 0020 1000
Could this be added to your driver?
β Version β 2022-02-23T22:17:17.782625 β
- id: "IKEA/Bulb E12 WS"
deviceLabel: IKEA Bulb
deviceProfileName: level-colortemp-2200-4000
model: TRADFRI bulb E26 CWS 806lm
Colourtemp ranges from 2700K to 6500K.
Could you please add this as well?
So far ikea RGBW bulbs donβt work with edge drivers that use the default Edge libraries.
The stock zigbee switch driver which should pick up ikea bulbs that have stock DTH, also doesnβt have CWS Ikea bulbs.
If you want I add it and try it, but there are already several who have reported that the color does not work.
Thank you, itβs working very well.
Hi there,
Would it be possible to add support for Innr bulbs to this driver?
* application: **10**
* endpointId: **01**
* firmwareFullVersion: **10061567**
* firmwareImageType: **275**
* firmwareManufacturerCode: **4454**
* manufacturer: **innr**
* model: **RB 285 C**
* zigbeeNodeType: **ROUTER**
Raw Description 01 0104 010D 01 08 0000 0003 0004 0005 0006 0008 0300 1000 01 0019
Hello,
I wonβt be able to do it until tomorrow.
If you just want the standard features, this bulb is included in the stock Zigbee Switch driver from the smartthings beta drivers channel, just in case you want to try it out.
https://api.smartthings.com/invitation-web/accept?id=450930c1-02a6-43d8-adaa-4cbc51027956
When you have an edge driver installed you can easily switch to another edge driver compatible with your device at any time with the driver change tool in the driver menu in the device settings
Many thanks for the response, and no problem at all on when youβre able to do it - I appreciate you taking the time to add support!
Iβve got the bulb currently running with the default driver on the hub, but wanted to make use of the colour change feature available in your driver. I will check our the beta drivers channel though!
β Version β 2022-03-01T12:37:12.746561 β
- id: "innr/RB 285 C"
deviceLabel: innr RGBW
manufacturer: innr
model: RB 285 C
Just wanted to say thank you - this is working great now!
I was just having a quick play with this driver and an IKEA Tradfri bulb.
The driver is showing as the version from 2022-03-03, so should be the very latest.
I set the min and max circadian lighting limits to 99-100 and the progressive active to off (tried on, too).
I then toggled the Circadian to on.
Was aiming to set the colour temperature depending on the time of day, but keep the brightness to 99 or 100% regardless.
When Circadian is on, the brightness is set to a random % each time I turn it on (even if I change the brightness before I turn it off). This doesnβt happen if Circadian is off. The colour temp changes, too - so thatβs good. But it seems to ignore the brightness min/max settings for Circadian lighting. Just wondering if youβre aware of this?
Many thanks.
Hello,
The circadian function turns on and varies the color temperature and brightness depending on the local time of day (between 06:00 and 18:00) and with the minimum and maximum limits set in preferences for brightness and between 2700k and the maximum k set in preferences.
The preferences βCircadian Lighting MIN Level %β, βCircadian Lighting MAX Level %β and βColorTemp Increment Max value (k)β are used.
Here it is explained how it works
It is essential to set the local time in preferences with the GMT time offset
Every time you turn on the switch, it calculates the level value and color temperature corresponding to that time of day.
Every 10 minutes it recalculates the values if it stays on
If the local time is less than 06h or greater than 18, it turns on with the last values at which it was turned off
The algorithm emit this curve of values for these limits in preferences as one example:
If you can see the logs with the CLI, you will be able to see the values calculated at the moment of pressing ON with circadian activated.
You can see that they match the values of the curve
(In the example I have set the local time -5 GMT to be able to see it work)
2022-03-04T18:07:58.098457143+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: a983309d-3963-4bdd-bc3b-3855f1106d14 [0x1EE7] (Luz H. Irene)> received command: {βcomponentβ:βmainβ,βargsβ:,βcommandβ:βonβ,βcapabilityβ:βswitchβ,βpositional_argsβ:}
2022-03-04T18:07:58.105140476+00:00 TRACE Zigbee Light Multifunction Mc Found CapabilityCommandDispatcher handler in zigbee_light_multifunctions
2022-03-04T18:07:58.110616143+00:00 PRINT Zigbee Light Multifunction Mc <<<<< Turn On transitio Time = = 0 >>>>>
2022-03-04T18:07:58.118308810+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: a983309d-3963-4bdd-bc3b-3855f1106d14 [0x1EE7] (Luz H. Irene)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x1EE7, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x01, seqno: 0x00, ZCLCommandId: 0x01 >, < On || > > >
2022-03-04T18:07:58.130819143+00:00 PRINT Zigbee Light Multifunction Mc circadian_Running ; circadian[device] table: 0x199dfe8 Active
2022-03-04T18:07:58.144139476+00:00 PRINT Zigbee Light Multifunction Mc <<<<<<<<<<<<<<< In Circadian timer On >>>>>>>>>>>>>>>>
2022-03-04T18:07:58.161647476+00:00 PRINT Zigbee Light Multifunction Mc localHour, localMinutes = 13 07
2022-03-04T18:07:58.167868143+00:00 PRINT Zigbee Light Multifunction Mc circadian_Running= running
2022-03-04T18:07:58.173910810+00:00 PRINT Zigbee Light Multifunction Mc TempHour, TempNextHour 4921.6294004649 4691.8584287042
2022-03-04T18:07:58.180094810+00:00 PRINT Zigbee Light Multifunction Mc New Level= 89.078260869565
2022-03-04T18:07:58.188597143+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: a983309d-3963-4bdd-bc3b-3855f1106d14 [0x1EE7] (Luz H. Irene)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x1EE7, dest_endpoint: 0x01, profile: 0x0104, cluster: Level >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x01, seqno: 0x00, ZCLCommandId: 0x04 >, < MoveToLevelWithOnOff || level: 0xE2, transition_time: 0xFFFF, options_mask: 0x00, options_override: 0x00 > > >
2022-03-04T18:07:58.201905476+00:00 PRINT Zigbee Light Multifunction Mc colorTemp = 4894
2022-03-04T18:07:58.211479476+00:00 PRINT Zigbee Light Multifunction Mc colorTemp Mired 204
2022-03-04T18:07:58.236727810+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: a983309d-3963-4bdd-bc3b-3855f1106d14 [0x1EE7] (Luz H. Irene)> emitting event: {βcapability_idβ:βcolorTemperatureβ,βattribute_idβ:"colorTemperature",βstateβ:{βvalueβ:4894},βcomponent_idβ:βmainβ}
2022-03-04T18:07:58.528154477+00:00 TRACE Zigbee Light Multifunction Mc Received event with handler zigbee
2022-03-04T18:07:58.536795143+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: a983309d-3963-4bdd-bc3b-3855f1106d14 [0x1EE7] (Luz H. Irene)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x1EE7, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Level >, lqi: 0x98, rssi: -62, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x2D, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Uint8, CurrentLevel: 0xE2 > > > >
2022-03-04T18:07:58.564310143+00:00 TRACE Zigbee Light Multifunction Mc Found ZigbeeMessageDispatcher handler in zigbee_light_multifunctions
2022-03-04T18:07:58.569808477+00:00 INFO Zigbee Light Multifunction Mc Executing ZclClusterAttributeValueHandler: cluster: Level, attribute: CurrentLevel
2022-03-04T18:07:58.576916477+00:00 INFO Zigbee Light Multifunction Mc <ZigbeeDevice: a983309d-3963-4bdd-bc3b-3855f1106d14 [0x1EE7] (Luz H. Irene)> emitting event: {βcapability_idβ:βswitchLevelβ,βattribute_idβ:βlevelβ,βstateβ:{βvalueβ:89},βcomponent_idβ:βmainβ}
Iβve tried changing the level limits and it works fine.
I donβt know if this is what it says it doesnβt work
Hi,
Thanks. I was expecting that the MIN/MAX Circadian settings set to 99/100 would over-ride the minimum level so I could use this to just set the colour temp rather than the brightness, too. I understand what Circadian lighting should be for and do (so technically should be brightness too).
With the option set to on, each time I turn it on or off, the percentage changes each time e.g. 54, 17, 12, 24β¦
Thank you.
Do you mean setting min level =99 and max level 100?
I do it and it always turns on at 100% level
Do you have this version of driver installed?
β Version β 2022-03-03T22:52:18.303456 β
