Hi @neod192
Sorry, Fixed in this driver version
Name Zigbee Light Multifunction Mc
Version 2022-11-19T19:10:08.753922831
- id: "GLEDOPTO/GL-C-009"
deviceLabel: GLEDOPTO GL-C-009
manufacturer: GLEDOPTO
model: GL-C-009
deviceProfileName: switch-level
Could you please add this fingerprint to Zigbee light multifunction?
zigbeeNodeType: ROUTER
application: 07
endpointId: 01
manufacturer: YSRSAI
model: ZB-CL01
Raw Description 01 C05E 0210 02 07 0000 0003 0004 0005 0006 0008 0300 00
It is RGB+CCT led strip controller
Thanks.
amin300
(Amin)
November 20, 2022, 7:41pm
510
Hi @Mariano_Colmenarejo
I am using your driver Zigbee light Multifunction Mc with Ikea Tradfri bulb E27 CWS opal 600lm
but the driver not able to get the status of color temperature as below
any idea why?
Also I have another question, how i can use this driver to change color by external remote. each time i press the remote key to change the color to next color. I am not looking to have continuous color change, only i want to have each time I press remote key to move to next color
Much appreciated
Hi @amin300
These Ikea bulbs were in the rgb-level profile.
Some users have commented to me that ikea CWS bulbs have 2200k-4000k color temperature control.
I have not any to check this.
I changed them all CWS to rgbw-colorTemperture-2200-4000 profile.
If the color temperature control doesn’t work on this one, I’ll put it back on the rgb-level profile.
You can try to set the color temperature with a routine or activate the circadian function and turn the bulb off and on so that it sends the color temperature corresponding to the local time.
amin300:
The function to change by external steps is only available for level and color temperature.
amin300
(Amin)
November 21, 2022, 5:28pm
513
Thanks @Mariano_Colmenarejo
I tried to create to set the color temperature with routine but color temerature didnt change. I think this bulb doesn’t support color temerature
Hi @amin300
What exact model is, please?
amin300
(Amin)
November 21, 2022, 6:54pm
515
Modifies to level-rgb profile
Version 2022-11-21T18:59:54.088049969
- id: "TRADFRI bulb E27 CWS opal 600lm"
deviceLabel: IKEA E27 Bulb
manufacturer: IKEA of Sweden
model: TRADFRI bulb E27 CWS opal 600lm
deviceProfileName: level-rgb # no RGBW @amin300
Hey, could you help me out with a couple of devices?
My specific Ledvance bulb isn’t there in the fingerprints. I have Ledvance A60S RGBW bulb which isn’t able to use the drivers. Data from IDE:
application: 00
endpointId: 01
firmwareFullVersion: 02136550
firmwareImageType: 160
firmwareManufacturerCode: 4489
manufacturer: LEDVANCE
model: A60S RGBW
Raw Description: 01 0104 010D 01 09 0000 0003 0004 0005 0006 0008 0300 0B05 1000 01 0019
I have Z-Wave Window treatment and switches by TechniSat that also need drivers, do you think you would be able to add those?
a. https://products.z-wavealliance.org/products/3779?selectedFrequencyId=1
b. https://products.z-wavealliance.org/products/3798?selectedFrequencyId=1
c. https://products.z-wavealliance.org/products/3677?selectedFrequencyId=1
d. https://products.z-wavealliance.org/products/3778?selectedFrequencyId=1
Hi @rowschank
Added to this driver version
Version 2022-11-22T18:23:01.789228024
- id: "LEDVANCE/A60S RGBW"
deviceLabel: LEDVANCE A60S RGBW
model: A60S RGBW
deviceProfileName: rgbw-level-colortemp-2700-6500
For zwave devices I have to watch it slower. I’ll tell you something
Excellent, thank you!
I hope you are able to figure out something for the Z-Wave devices; I think they’re not too dissimilar to maybe other in-wall controllers, but they have extra mounting hardware for the switches. But I’m not sure. As it is, things like scene control they describe don’t work with Smartthings so I’m not bothered if those go away.
Tristanoz
(Tristan van der Velden)
November 22, 2022, 7:34pm
520
I’m new to this so im not sure if im doing something wrong, but I cant seem the driver to run on the following device:
application: 42
endpointId: 01
manufacturer: _TZ3000_quqaeew6
model: TS0505B
Raw Description: 01 0104 010D 01 08 0000 0003 0004 0005 0006 1000 0008 0300 02 0019 000A
Is it not supported, or am i doing something wrong?
ETA: its a gu10 rgbw bulb from lidl (livarno)
Tristanoz:
application: 42
endpointId: 01
model: TS0505B
Hi @Tristanoz
If you see that colors are not the correct you select, tell me
Version 2022-11-22T19:42:05.857883595
- id: "_TZ3000_quqaeew6/TS0505B"
deviceLabel: TS0505B RGBW
model: TS0505B
Tristanoz
November 22, 2022, 8:03pm
522
Wow that was fast, its working great now! Thanks a lot . I’ve just joined but I already am loving the SmartThings community.
Hi @Mariano_Colmenarejo ,
could you please try to add the following
LIDL Livarno LED Ceiling Light (IAN 399629_2110, Version 07/2022, Model No: HG09369)
Currently it works with a stock ZigBee RGBW Bulb DH.
Temperature: 2000-6500K + Colours
application: 6B
endpointId: 01
manufacturer: _TZ3210_c0s1xloa
model: TS0505B
Raw Description 01 0104 010D 01 09 0000 0003 0004 0005 0006 1000 0008 0300 EF00 02 0019 000A
Many thanks in advance.
Hi @zoltan.yy
Version 2022-11-23T21:26:48.694669133
- id: "_TZ3210_c0s1xloa/TS0505B"
model: TS0505B
deviceProfileName: rgbw-level-colortemp-2000-6500
Many thanks, @Mariano_Colmenarejo , it works great.
Your great support and efforts are very appreciated!
frayer
(Frank)
November 27, 2022, 2:50pm
527
Would it be possible to add this bulb, which is basically the same as the GL-B-008ZS (with a final S) one already included in the fingerprints:
Data
application: 01
endpointId: 0B
model: GL-B-008Z
Raw Description 0B C05E 0210 02 07 0000 0003 0004 0005 0006 0008 0300 00
frayer:
application: 01
endpointId: 0B
model: GL-B-008Z
Hi @frayer
Version 2022-11-27T16:17:55.477881404
- id: "GLEDOPTO/GL-B-008Z"
deviceLabel: GLEDOPTO GL-B-008Z
model: GL-B-008Z
