This bulbs is WS no CWS (Color + W), right?
Ikea WS works fine in all drivers
This bulb (Tradfri LED bulb E27 980 lumen) is WS with 2700 -4000K (NOT CWS)
This bulb the color temperature works with:
1.Zigbee switch stock lates driver
2.Zigbee Light multifunction XY
3.Zigbee Light multifunction XY-1
4.Zigbee Light multifunction Mc
The bulb (TRADFRI bulb E27 CWS opal 600lm)
- Works with Zigbee switch stock lates driver but has no color temperature
- Works with Zigbee Light multifunction XY all functions except color temperature not working
- Works with Zigbee Light multifunction XY-1 all functions except color temperature not working
Ok!
it seems that this bulb is equivalent to an RGB bulb, it has no color temperature attribute
RGBW bulbs has color temperature attribute.
Thatβs why I needed to see the logs.
You should get white color with the combination of rgb.
Tomorrow I will change it to another profile without color temperature like the stock driver.
Now Iβm going to sleep, itβs 1 am here.
components:
- id: main
capabilities:
- id: switch
version: 1
- id: colorControl
version: 1
- id: switchLevel
version: 1
- id: firmwareUpdate
version: 1
- id: refresh
version: 1
categories:
- name: Light
Report is below. lets do it tomorrow
Summary
PS C:> CD USERS
PS C:\USERS> CD aminhsm
PS C:\USERS\aminhsm> cd documents
PS C:\USERS\aminhsm\documents> cd CLI
PS C:\USERS\aminhsm\documents\CLI> .\smartthings edge:drivers:logcat
? Enter hub IP address with optionally appended port number: 192.168.1.58
Β» Warning: The authenticity of 192.168.1.58:9495 canβt be established. Certificate fingerprint is 25:94:6C:32:80:82:4E:70:6E:A6:8C:45:81:64:BF:07:5D:6C:9E:DA
? Are you sure you want to continue connecting? No
connecting⦠failed
Β» Error: Hub verification failed.
? Are you sure you want to continue connecting? Yes
Β» Warning: Permanently added 192.168.1.58:9495 to the list of known hubs.
ββββββ¬βββββββββββββββββββββββββββββββββββββββ¬βββββββββββββββββββββββββββββββββββββββ
β # β Driver Id β Name β
ββββββΌβββββββββββββββββββββββββββββββββββββββΌβββββββββββββββββββββββββββββββββββββββ€
β 1 β c411db9e-a042-459a-a145-f005c65412ee β ST Zigbee Button Mc β
β 2 β 981aab30-6f78-4b31-bf0b-b422bef161ec β Yeelight.Color β
β 3 β 3fb97b6c-f481-441b-a14e-f270d738764e β Zigbee Button β
β 4 β ad9f537d-e2d9-4354-8673-471a5306fad8 β Zigbee Button Groups β
β 5 β 1e45a851-8f07-48d1-bcbf-932fb377e95e β Zigbee Dimmer Remote β
β 6 β ccea734e-e56e-4d2c-a259-3b2e1fdebd82 β Zigbee Humidity Sensor β
β 7 β 6b86005f-95b4-49cb-a3d5-d3a17fd94177 β Zigbee Light Multifunction Mc β
β 8 β d5d863c7-40b8-4425-95f2-71080ba40567 β Zigbee Light Multifunction XY β
β 9 β be1fe1fa-b03d-4551-8ef7-134712386dbd β Zigbee Light Multifunction XY-1 β
β 10 β d620900d-f7bc-4ab5-a171-6dd159872f7d β Zigbee Motion Sensor β
β 11 β 00425c55-0932-416f-a1ba-78fae98ab614 β Zigbee Motion Sensor Mc β
β 12 β cf6324c4-22c0-49e0-a761-fa298b510e58 β Zigbee Switch β
β 13 β 27a1cfbe-1d4f-4be1-b803-2feb3a645e32 β Zigbee Switch β
β 14 β 07e8d581-9c59-4c10-9d06-7e1c75c00f5c β Zigbee Switch β
β 15 β 580a4441-7d16-437e-8cdc-97c03f59e2df β Zigbee Switch Mc β
β 16 β f732925a-9ae3-462a-9641-f03f474c661e β Zigbee Switch Power Mc β
β 17 β 026385b3-dfa9-43e5-b443-cfc42123f042 β Zigbee Temp Humidity Sensor Mc β
β 18 β bd79913f-0309-4256-b669-74c489b81140 β Zigbee Temp Humidity Sensor Mc-(OLD) β
ββββββ΄βββββββββββββββββββββββββββββββββββββββ΄βββββββββββββββββββββββββββββββββββββββ
? Select a driver. 8
connecting⦠connected
2022-04-28T23:07:12.893723631+00:00 DEBUG Zigbee Light Multifunction XY driver device thread event handled
2022-04-28T23:07:12.988755298+00:00 TRACE Zigbee Light Multifunction XY Received event with handler capability
2022-04-28T23:07:13.012896298+00:00 INFO Zigbee Light Multifunction XY <ZigbeeDevice: 8c5573ad-d19d-41a9-8df6-16ea6eb70b9a [0x2902] (IKEA E27 Bulb)> received command: {βargsβ:{βtemperatureβ:3270},βcapabilityβ:βcolorTemperatureβ,βcommandβ:βsetColorTemperatureβ,βcomponentβ:βmainβ,βpositional_argsβ:[3270]}
2022-04-28T23:07:13.019354298+00:00 PRINT Zigbee Light Multifunction XY zll_xy >>>>>> yes
2022-04-28T23:07:13.025879632+00:00 PRINT Zigbee Light Multifunction XY zll_xy >>>>>> yes
2022-04-28T23:07:13.032376965+00:00 TRACE Zigbee Light Multifunction XY Found CapabilityCommandDispatcher handler in zigbee_light_multifunctions
2022-04-28T23:07:13.038442632+00:00 PRINT Zigbee Light Multifunction XY handler_Color Temp >>>>>>>>>>>>>> 3270
2022-04-28T23:07:13.046745632+00:00 INFO Zigbee Light Multifunction XY <ZigbeeDevice: 8c5573ad-d19d-41a9-8df6-16ea6eb70b9a [0x2902] (IKEA E27 Bulb)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x2902, dest_endpoint: 0x01, profile: 0x0104, cluster: Level >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x01, seqno: 0x00, ZCLCommandId: 0x04 >, < MoveToLevelWithOnOff || level: 0xFE, transition_time: 0xFFFF, options_mask: 0x00, options_override: 0x00 > > >
2022-04-28T23:07:13.131306632+00:00 DEBUG Zigbee Light Multifunction XY IKEA E27 Bulb device thread event handled
2022-04-28T23:07:13.149584632+00:00 DEBUG Zigbee Light Multifunction XY IKEA E27 Bulb device thread event handled
2022-04-28T23:07:13.206578965+00:00 DEBUG Zigbee Light Multifunction XY IKEA E27 Bulb device thread event handled
2022-04-28T23:07:13.274076632+00:00 TRACE Zigbee Light Multifunction XY Received event with handler zigbee
2022-04-28T23:07:13.363780965+00:00 INFO Zigbee Light Multifunction XY <ZigbeeDevice: 8c5573ad-d19d-41a9-8df6-16ea6eb70b9a [0x2902] (IKEA E27 Bulb)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x2902, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Level >, lqi: 0x70, rssi: -72, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x5C, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x04, ZclStatus: SUCCESS > > >
2022-04-28T23:07:13.503781298+00:00 PRINT Zigbee Light Multifunction XY zll_xy >>>>>> yes
2022-04-28T23:07:13.559687632+00:00 DEBUG Zigbee Light Multifunction XY IKEA E27 Bulb device thread event handled
2022-04-28T23:07:13.627367632+00:00 TRACE Zigbee Light Multifunction XY Received event with handler zigbee
2022-04-28T23:07:13.650402632+00:00 INFO Zigbee Light Multifunction XY <ZigbeeDevice: 8c5573ad-d19d-41a9-8df6-16ea6eb70b9a [0x2902] (IKEA E27 Bulb)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x2902, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: ColorControl >, lqi: 0x70, rssi: -72, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x5D, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x0A, ZclStatus: UNSUP_CLUSTER_COMMAND > > >
2022-04-28T23:07:13.963245632+00:00 PRINT Zigbee Light Multifunction XY zll_xy >>>>>> yes
2022-04-28T23:07:13.976170632+00:00 DEBUG Zigbee Light Multifunction XY IKEA E27 Bulb device thread event handled
2022-04-28T23:07:14.016277965+00:00 DEBUG Zigbee Light Multifunction XY IKEA E27 Bulb device thread event handled
2022-04-28T23:07:14.143497299+00:00 DEBUG Zigbee Light Multifunction XY IKEA E27 Bulb device thread event handled
2022-04-28T23:07:14.150947299+00:00 TRACE Zigbee Light Multifunction XY Received event with handler zigbee
2022-04-28T23:07:14.169846299+00:00 INFO Zigbee Light Multifunction XY <ZigbeeDevice: 8c5573ad-d19d-41a9-8df6-16ea6eb70b9a [0x2902] (IKEA E27 Bulb)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x2902, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Level >, lqi: 0x6C, rssi: -73, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x5E, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0000, ZclStatus: SUCCESS, DataType: Uint8, CurrentLevel: 0xFE > > > >
2022-04-28T23:07:14.214778965+00:00 PRINT Zigbee Light Multifunction XY zll_xy >>>>>> yes
2022-04-28T23:07:14.223522632+00:00 PRINT Zigbee Light Multifunction XY zll_xy >>>>>> yes
2022-04-28T23:07:14.236716632+00:00 TRACE Zigbee Light Multifunction XY Found ZigbeeMessageDispatcher handler in zigbee_light_multifunctions
2022-04-28T23:07:14.243657632+00:00 INFO Zigbee Light Multifunction XY Executing ZclClusterAttributeValueHandler: cluster: Level, attribute: CurrentLevel
2022-04-28T23:07:14.256413299+00:00 INFO Zigbee Light Multifunction XY <ZigbeeDevice: 8c5573ad-d19d-41a9-8df6-16ea6eb70b9a [0x2902] (IKEA E27 Bulb)> emitting event: {βattribute_idβ:βlevelβ,βcapability_idβ:βswitchLevelβ,βcomponent_idβ:βmainβ,βstateβ:{βvalueβ:100}}
2022-04-28T23:07:14.300222299+00:00 DEBUG Zigbee Light Multifunction XY IKEA E27 Bulb device thread event handled
2022-04-28T23:07:14.307316965+00:00 TRACE Zigbee Light Multifunction XY Received event with handler zigbee
2022-04-28T23:07:14.325820299+00:00 INFO Zigbee Light Multifunction XY <ZigbeeDevice: 8c5573ad-d19d-41a9-8df6-16ea6eb70b9a [0x2902] (IKEA E27 Bulb)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x2902, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: ColorControl >, lqi: 0x6C, rssi: -73, body_length: 0x0006, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x5F, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0007, ZclStatus: UNSUPPORTED_ATTRIBUTE > > > >
2022-04-28T23:07:14.365808299+00:00 PRINT Zigbee Light Multifunction XY zll_xy >>>>>> yes
2022-04-28T23:07:14.371942966+00:00 DEBUG Zigbee Light Multifunction XY IKEA E27 Bulb device thread event handled
This log response confirms that this bulb does not support the color temperature attribute.
Iβll fix it tomorrow
Thank you very much for your help.
This is what Iβve got so far
Couldnβt make powerMeter to show on the dashboard as stock capability doesnβt have it in presentation.
Any idea how to put 2 capabilities into single group?
Thanks again
Published new driver MC version in this thread
Hello @ygerlovin
Iβm glad it worked for you!!
You can show up to 5 capability attributes in the same group, but you cannot exceed 5 total capabilities attributes.
This is what I saw based on trial and error since I did not find documentation on this
You could make a custom capability to display text, for example as I did with βinfoPanelβ on the thermostat.
- This capability makes a presentation that shows its attribute on the dashboard.
You do not need show this capability in detailView device presentation, only declare it in the profile and init.lua
"dashboard": {
"states": [
"label": "{{infoPanel.value}}"
"actions": [],
"basicPlus": []
"detailView": [
"label": "Thermostat Next State Change Information",
"displayType": "state",
"state": {
"id": "legendabsolute60149.infoPanel",
"version": 1
- In the code you define a string that contains the value of PowerMeter and EnergyMeter and that value is emitted in the attribute of the custom capability
-- emit thermostat information for next change state
local temp_scale = "C"
if device.preferences.thermTempUnits == "Fahrenheit" then temp_scale = "F" end
local text = "No Expected Change in Thermostat State"
if thermostatOperatingState == "heating" then
text = "T= "..current_temp.."ΒΊ"..temp_scale..", Next State: Pending Heat, T > "..string.format("%.2f",tempChangeToPendingHeat).."ΒΊ"..temp_scale
elseif thermostatOperatingState == "cooling" then
text = "T= "..current_temp.."ΒΊ"..temp_scale..", Next State: Pending Cool, T < "..string.format("%.2f",tempChangeToPendingCool).."ΒΊ"..temp_scale
elseif thermostatOperatingState == "pending heat" then
text = "T= "..current_temp.."ΒΊ"..temp_scale..", Next State: Heating, T <= "..string.format("%.2f",tempChangeToHeating).."ΒΊ"..temp_scale
elseif thermostatOperatingState == "pending cool" then
text = "T= "..current_temp.."ΒΊ"..temp_scale..", Next State: Cooling, T >= "..string.format("%.2f",tempChangeToCooling).."ΒΊ"..temp_scale
end
device:emit_event(info_Panel.infoPanel(text))
- In this way you make a device presentation with the custom capability that shows you PowerMeter and EnergyMeter in a single Attribute/group of the 5.
In this case I put in βmainβ gruop, but you mus put in other secundary group in order to icon control by switch atribute capability
driver updated and works very fine. Thanks
Hi, somwthing happened to your driver this morning. Zigbee light multifunction MC.
I have 3 GLEDOPTO RGBWW/CW controllers and all are unresponsive now.
I had similar problem today. I needed to turn lights on/off from switch and they started to work again.
Nothing has changed in my drivers that could make them stop working.
Something happened in the hubs this morning, someone else complained, but from a different driver.
Seeing the information of the Hub in IDE, it has the date of last update this morning. I donβt know if they have updated.
Hub Last Updated 2022-04-29 8:59 AM UTC
For this other user, with a reboot of the hub, everything was solved.
I did not notice anything strange, I have a smartthings special treatment !!! all my devices works with Edge drivers Mc
The problem of auto power off after 2 minutes of tuya switches I donβt think it has anything to do with the libraries.
It seems like a protection from being used on other platforms.
We already tried to write the value that the DTH writes in a specific attribute and it did not work
The device responded as attribute written correctly and I donβt know why it didnβt work.
I canβt think of anything new
Power cycling the controllers fixed mine too.
Thanks for the quick responce and updates!
I wanted to add Osram rgbw bulbs but it didnβt pick up any edge drivers.
I installed the new zigbee βthingβ and many MC drivers, but it didnβt add it either. still adds it as a goovy handler. I thought the zigbee thing driver suppose to add any make and model zigbee device?
Am I missing something here? Thanks in advanceβ¦
If itβs paired with a DTH, go into IDE and send me the manufacturer, model and if itβs RGBW or just color temperature.
Did you install the zigbee thing Mc?
Yes, I installed βthing MCβ and most all the other zigbee lighting drivers from your channel. I do appreciate all your hard work.
RGBW
- manufacturer: OSRAM
- model: LIGHTIFY A19 RGBW
Color Temp only
- model: LIGHTIFY A19 Tunable White
