(EDGE Driver-Mc): Zigbee Drivers for Motion, Open/Close, Moisture, Smoke-Co Sensors and others Devices
before with the dth I read both power and energy
For smartthings water leak sensor not yet created, correct?
  • application: 14
  • endpointId: 01
  • manufacturer: Samjin
  • model: water
  • zigbeeNodeType: SLEEPY_END_DEVICE
01 0104 0402 00 07 0000 0001 0003 0020 0402 0500 0B05 02 0003 0019
Correct.
If it’s smartthings, they will, I hope
Perfect.
on this one too I read both power and energy
It does not work?
Work well.
also on this one
  • id: β€œSmartTings/outletv4”
    deviceLabel: SmartTings outletv4
    manufacturer: SmartTings
    model: outletv4
    J read energy and power in old dth
the correct id is this
  - id: "SmartThings/outletv4"
    deviceLabel: SmartThings outletv4
    manufacturer: SmartThings
    model: outletv4
    deviceProfileName: switch-power-energy-plug
and this driver version
β”Œβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”
β”‚ Name        β”‚ Zigbee Switch Power Mc               β”‚
β”‚ Version     β”‚ 2021-12-19T23:01:46.974176           β”‚
β””β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”˜
Grazie (Tanks)
Try this new version of zigbee switch power Mc to chek issue of 10x power meter
@Mariano_Colmenarejo when you create a device with more than one gang from the second onwards, switch2, switch3, etc. appears. Exiate some way to add something in that name to differentiate a switch2 from another switch2? I was following your advice to create virtuals but when mirroring the behavior appears more switch2, etc and I don’t know which is which.
@Mariano_Colmenarejo is it possible to add this Gledopto Plus GL-B-008ZS 12w lamp? Its color temperature ranges from 2000k-6500k as you can see in the link below
  • application: 01
  • endpointId: 0B
  • manufacturer: GLEDOPTO
  • model: GL-B-008ZS
  • zigbeeNodeType: ROUTER
0B C05E 0210 02 07 0000 0003 0004 0005 0006 0008 0300 00
Nothing can be added.
Smartthings has already been told that this is a serious problem and they should give it a solution
ok. Thanks
@Mariano_Colmenarejo If I’m being annoying about sending devices, let me know that I’ll stop… :frowning:
ZigBee RGBW Bulb
  • application: 42
  • endpointId: 01
  • manufacturer: _TZ3000_i8l0nqdu
  • model: TS0503B
01 0104 0102 01 08 0000 0003 0004 0005 0006 1000 0008 0300 02 0019 000A
Zemismart Contact Sensor (contact and battery)
  • application: 4D
  • endpointId: 01
  • manufacturer: TUYATEC-n4qd0btb
  • model: RH3001
01 0104 0402 00 04 0000 0001 0003 0500 01 0003
Added to this driver version
β”‚ Name        β”‚ Zigbee Light Multifunction Mc        β”‚
β”‚ Version     β”‚ 2021-12-19T23:32:51.599198           β”‚
  - id: "GLEDOPTO/GL-B-008ZS"
    deviceLabel: GLEDOPTO GL-B-008ZS
    model: GL-B-008ZS
    deviceProfileName: rgbw-level-colortemp-2700-6500
the consumption of this now appears but I need to keep updating (pulling down). Is there anything that can be done to automatically refresh every second?
this temperature is 2000k-6500k
Only have one profile for rgbw 2700-6500k
the power is 10x of real power?
