Hi @9three
Disable “Signal Metrics Visible in Histiry” on devuce settings preferences
hi, yes i know this will remove it, i just wanted to keep it, however its obvious, the code to display it is not… correct? also, ive noticed the battery hasnt reported since 3 days ago and there is no variable to change its report interval. do i have a connection problem? thanks !
No connections problem. Your RSSI is -64dbm which should be fine.
Battery info. transmitted every 1 or 2 hours and usually it stays 100% for very long.
don’t worry about that as long as the device keep reporting the contact status correctly.
battery status hasnt been reported in over 3 days now. as you can see by the graph, last report was on the 14th, when the Thing was installed, today is the 17th, no reports.
Hi,
I need to know the fingerprints, model and manufacturer to see what attribute it uses to report battery.
If you paired it to the driver by doing a driver change from a different driver, zigbee thing for example, then it may not have been configured correctly and you need to uninstall and reinstall the device directly with the driver
thanks
|Mfg Name| SmartThingsCommunity |
|Mfg Code| Universal Electronics Inc |
|Model| URC4460BC0-X-R |
Ok, use battery voltage and it should work fine, this device was added a long time ago.
Have you tried uninstalling and reinstalling the device from scratch with this driver?
ok, yes, i did initially install without subscribing to your driver and then switched after install. i was able to reintall and it automatically found your driver and included without problem. looks ok now. thank you amigo.
Hi Mariano.
I have “Zigbee Repeater Amplifier Extender eWeLink” with no driver
can you please add it ?
Hi,
This device exists in the zigbee switch Mc driver, like a switch. I have one working.
It has cluster 0006, on/off
Hej Mariano, i ve been trying for a while with the aquara P1, installed your zigbee thing mc, (motion sensor edge driver you have hasnt the fingerprint). but i still got no functions…no routines. just your zigbee thing mc driver is now active with it…
any idea how to fix it?
Post the information of the device displaying the screen to see if it could work with the Motion Sensor Mc zigbee driver
ui that was a fast response. I already got another driver to work from ygerlovin
and lots of resets, app restarts , new connecting the sensors until it worked.
Hey,
I am having trouble adding your driver for my contact sensor. I tried the “Zigbee Contact Mc”, but got the error- “Error changing device driver to “Zigbee Contact Mc”. Ensure that the driver you are trying to change to has a valid fingerprint match with this device.”
Here’s my device info:
Manufacturer Code: _TZ3000_zgrffiwg
Model: TS0203
Thank you,
Chase
Added to this driver version
Name Zigbee Contact Mc
Version 2023-09-22T13:38:33.384090403
- id: "_TZ3000_zgrffiwg/TS0203"
deviceLabel: TS0203 Contact Sensor
manufacturer: _TZ3000_zgrffiwg
model: TS0203
deviceProfileName: contact-battery-profile
Thank you Mariano!
How did you get your XHS2-UE to report temperature?
fubka
The graph shows RSSI signal and Battery level signals.
XHS2-UE this is a contact sensor… @Mariano_Colmenarejo driver does not support Temp and contacts from a single device
one question i have regarding this sensor… with @Mariano_Colmenarejo driver, you can select what type of “tile” it shows, however, when you do choose the temperature tile, (by default contact tile is selected) you will gain the ability to see the temperature in your favorites, but you will lose the ability to see the open/close status from your Favorites screen. my question is, can we have both, ability to see temperatuee AND contact ??? no body likes “Or’s” but everyone loves “And’s” … peanut butter or jelly ??? Booooo, peanut butter AND jelly… yaaaaaay
Driver Settings for the XHS2-UE:
My Favorites screen when Contact Tile is enabled:
My Favorites screen when Temperature Tile is enabled:
