Hi @Shaikin
This feature does not work on all devices. Thatβs why it says try.
When you change the value in preferences you can see in the CLI logs if the device supports attribute 0x4003 or 0x8002 or neither.
Hi @Shaikin
Hi,
Please add , 4 relays module. Can be used for garden watering:
Model: TS0004
Manufacturer: TZ3000_u3oupgdy
hello is there an Edge driver for this sensor
Sorry typo
@Mariano_Colmenarejo , I have the following Zigbee Multisensor. Can you tell me if it is supported by one of your drivers? If so, which one? Thanks.
Data * application:
Thank you @Mariano_Colmenarejo. I think you mentioned somewhere that you have integrated βSmartThings Multipurpose Sensor Mcβ into βZigbee Contact Mcβ. So does this mean that if we have any device using βSmartThings Multipurpose Sensor Mcβ, we should switch it to βZigbee Contact Mcβ?
I appreciate all you are doing for this platform.
One more basic magnetic Door/Window switch. Similar one found driver, but there must be different fingerpring.
Thanks much.
Hi @Kimmo_Liias
Added to this driver version
βββββββββββββββββββββββββββββββββββββββββββββββββββ
Name Zigbee Contact Mc
Version 2022-11-15T19:33:04.216485895
- id: "_TZ3000_osu834un/Contact Sensor"
deviceLabel: TS0203 Contact Sensor
manufacturer: _TZ3000_osu834un
model: TS0203
deviceProfileName: contact-battery-profile
Dear @Mariano_Colmenarejo
Thanks always for your great efforts
I am using your Edge driver βZigbee Multi Switch and Child Mcβ latest version β2022-11-15T19:59:17.536797195β with Zigbee 2 gangs multi switch
Once i change from settings and create single Device for Switch2, the new created tile for switch 2 starts working on/off very well but after some time, it become not responding and doesnt switch on/off!!
Is this known issue?
in order to make it working again, i go to settings in main tile and change " Single Device to Action All on-off" from no create to creat then click on new created tile of " Single Device to Action All on-off" and then delete the new created tile for Action all on-off`, after that the tile for switch 2 starts working again for sometime then stops again
any idea why?
Hi @amin300
I have two multi-component devices with child devices created quite a while ago, when the driver was released, and they have never gone dead.
If it happens again, you can send some logs of when you click on the child devices to see if there are any errors
@Mariano_Colmenarejo , I have a few IRIS Open/Close sensors that I am using for temperatures only.
I am using your βZigbee Contact Mcβ Driver
And selected βTemperature Tile Infoβ in Settings. I was expecting the temperature to show up as default in the Tile, but it is showing βOpen/Closeβ. Is my expectation incorrect?
Hi @damohabir
Try with this driver version. Temperature vid missing in profile
Version 2022-11-17T09:55:48.318482363
@Mariano_Colmenarejo , thank you very much. That works.
To you, and all the others on this forum who use so much of your personal time to provide drivers and support to everyone on here, please know that your effort is so much appreciated. The amount, and quality, of the drivers and support that you all provide is so much better than SmartThings. So thank you all.
Oh, one small bug. While the temperature is displayed in the Tile, the default icon is still door (open/close), and not an icon of a temperature sensor.
The profile has the thermostat icon, but if you changed the icon to one of the ones that gives you to choose the App in the edit menu, then that is the one that device keep.
I kept the βContactSensorβ categories so that the ContactSensor icons could be chosen
You can uninstall the device and re-bind it to show the profile icon or install this version which has the Thermostat categories
Version 2022-11-17T14:40:31.52675132
Another one to your collection:
Manufacturer: _TZ3000_iwhuhzd
Model: TS0003
