This driver version is the same as test version with mane Mc.
Are you deleted app cache?
Name Zigbee Motion Sensor Mc
Version 2022-10-30T12:33:20.683132801
I assume you mean the Zigbee Light Multifunction Mc driver.
All yours light bulbs malfunction?
They all work fine for me.
Try to reboot the hub, if you haven’t already.
I can’t think of anything to explain that!
Yes sorry for the lack of information. It is the zigbee Light Multifunction MC driver I’m speaking of.
All lights using this driver is affected by the issues mentioned, and all can be fixed by using the ST ZigBee Switch Driver. But this is not an option as I need the sweet functions you have implemented in your driver.
I have tried restarting the hub a couple of times now, but it doesn’t seem to resolve the issue. It is an aeotec hub BTW.
I have no clue either to what is causing this, but hoped that I wasn’t the first one.
All my automations has gone to a halt. Thank good I have Direct Device binded all fixtures to my remotes…
I did now, it works!
I have no idea what could be going on.
Try to overwrite the driver with the CLI without uninstalling from the version you already have.
TX. Will post data as soon as I find them
Hi, I’ve been breaking my head over this SilverCrest gardenpin outlet that I’ve gotten from Lidl. It has two outlets but I can’t seem to get this thing to work. It recognized the unit as a thing and when I change the DTH into your integrated_zigbee_Switch. It seems to accept it as a switched outlet but it only works on the whole unit not the individual two outlets separately. It does show them as child devices though! Any chance this could be included in the EDGE packedge? BTW the * manufacturer: _TZ3000_br3laukf
- model: TS0101 for reference. Thanks Erwin
Hi Mariano, thanks for looking into this. Will send it tomorrow. Rgrts Erwin
Hi @Mariano_Colmenarejo , hope this is what you are looking for:
Name | Garden pin |
Label | |
Type | ZigBee Switch |
Version | Published |
Zigbee Id | 60A423FFFE091C23 |
Device Network Id | ED3A |
Status | OFFLINE |
Hub | [SmartThings Hub] |
Last Activity At | 2022-11-01 8:50 PM CET |
Date Created | 2022-11-01 5:51 PM CET |
Last Updated | 2022-11-01 5:51 PM CET |
Route | [This Device (ED3A) ]↔ [SmartThings Hub] |
Metrics | * Last Hop LQI: 210 |
- Last Hop RSSI: -74
- Received Messages From Device: 36
- Received Messages From Device (Duplicates): 0
- Messages Transmitted to Device: 79
- Messages Transmitted to Device (Failures): 37
- Updated Time: 2022-11-02 7:51 AM CET|
|Data|* zigbeeNodeType: ROUTER - firmwareManufacturerCode: 4098
- firmwareFullVersion: 00000041
- application: 41
- endpointId: 01
- firmwareImageType: 5634
- manufacturer: _TZ3000_br3laukf
- model: TS0101|
|Raw Description|01 0104 0009 01 05 0000 0003 0004 0005 0006 02 0019 000A|
|Firmware|[Check Now]|
|Current States|* [switch]: on - [checkInterval](: 1320 s|
|Execution Location|Local|
|Events|[List Events]|
|In Use By||
Added to this driver version
Name Zigbee Multi Switch and Child Mc
Version 2022-11-02T11:50:05.305118719
- id: "TS0101 /_TZ3000_br3laukf"
deviceLabel: TS0101 Switch
model: TS0101
deviceProfileName: two-outlet
New version Zigbee Siren Mc:
Added Frient Heat detector device with signal metrics to this driver version
Name Zigbee Siren Mc
Version 2022-11-02T11:29:51.830231722
- id: "frient/HESZB-120"
deviceLabel: frient Heat Detector
manufacturer: frient A/S
model: HESZB-120
deviceProfileName: temp-alert-alarm-battery
HI @Mariano_Colmenarejo, will try it this asap. Thanks for the effort!! Your a great help for this community!!!
Erwin
I just learned about Edge Drivers today. I have gotten this driver to work on three IKEA tradfri GU10 bulps sitting next to eachother in a lamp in a room. The driver works, but not great. The three bulps are grouped in the Smartthings app and can then be controlled together. When both turning the bulps on, off and changing brightness it almost seems like each bulp is being turned on and off one after the other. There is a very noticable lag between each of the bulps. When it was mentioned that locally running would be faster i think i expected all bulps to react at the same time due to the proposed increased execution speed. Is this behavior to be expected or does something seem off? My bulps are sitting around LQI 130-150 and RSSI: -80dbm.
Dear @Mariano_Colmenarejo
Thanks for your efforts
Would you mind adding this device please
It is Zigbee Dimmer Switch
thanks
Hi @amin300
Name Zigbee Light Multifunction Mc
Version 2022-11-03T22:22:59.923336401
- id: "3A Smart/LXN56-DS27LX1.3"
deviceLabel: 3A Smart Dimmer
manufacturer: 3A Smart Home DE
model: LXN56-DS27LX1.3
deviceProfileName: switch-level
Fantastic, thank you Mariano
Can you please add the following:
"deviceManufacturerCode": "_TZ3000_pv4puuxi",
"deviceModel": "TS0003",
Thank you
Apologies for taking so long.
The manufacturer sent a replacement but insists it has light sensing capabilities. The zigbee thing card still shows the same details however. Would it be possible to add it as a driver with light sensing even though the cluster is not available?
If not, just adding it as a simple contact sensor is fine. I’ll buy a light sensor separately haha.
Appreciate the addition of the motion sensor!
