Here are all the ones I have made.
They are all together in the same repository
Vimar switch works great!!
do you think to release a zigbee windows shade version ?
Does that bulb have the profile 2700-6500?
@milandjurovic71,
The VID of that profile may have been generated wrong, I have them working with the profile 2700-6000
Do you want I pass them to 2700-6000 profile and test?
I don’t have any of those devices
Bulb is 2700-6500.
Can you have v2 and v3 drivers. Assuming they could be switched, like we did recently with Progressive and Non-progressive?bulb shows on/off button for a split second, and than goes to “cloud” status
Anyway we could test with another profile
I had to reboot my hub to get the updated bulbs working.
I have rebooted my twice
@milandjurovic71,
I just changed your bulbs to profile 2700-6000 and testing
Although something strange is happening on the servers, almost all the automations and scenes have disappeared again
I also removed and re-added the new driver before I rebooted.
What model are your bulbs?
Do they work well?
Believe me I did all of that, not just once.
Still same issue. Rebooted, cleared cache, re-added driver, and nothing changed.
1 was an EcoSmart color temperature adjustable and dimmable bulb and 1 was Sengled E11-G13 warm white dimmable bulb.
After adding, deleting and re-adding the driver plus rebooted the hub they both are work good. I have not tried any of the advanced features.
If you can, uninstall the driver from hub and reinstall it and then change driver switching to the new controller.
Once installed, clear the cache to show a new presentation
I did all of that, and it still have issue, looks like it Checking
But actually nothing is happening
Like bulb is not connected at all. I’ll wait couple of hours to see if anything changes
I have tried mine with the 2700-6500 profile and they work fine too.
The Ecosmart also works well.
It’s a bit weird, it’s as if the driver had hung up
In these cases I unplug the hub, it is a v3
V2. All changes that we made in past weeks, worked flawlessly. This is the first time I have an issue
On-off, dimming and color temperature change all work smoothly.
I have released version 2.2 for you to use until you can use version 3.0
When you don’t need it you tell me to remove it from the channel
