(EDGE Driver-Mc): Z-wave Remotec ZRC-90 Scene Master and Namron Button Remote Mc
Hey, I have been having the same problem. I noticed that the raw data is different on mine.
This is a ZRC-90
I noticed in your fingerprint code that this is not the same…
Hi @Marty_Petraitis
That fingerprints 0000, 0000, 0000 is not correct.
That is that it has not been paired with anything.
It has happened to me once and it was resolved by re-pairing from the beginning and moving the device very close to the hub
Hey Thank you for the response I will try that
I am getting a connection error that is not secure. I wonder if that is the problem.
It connects with the same footprint…
@Marty_Petraitis
Try installing driver Z-Wave Thing Mc to see if pair with it
I do have it installed and subscribed to your site. I have it in before I try to pair
It appears that it is picking up the generic driver and not β€œZ-Wave Button Mc” driver. That is why I thought it was a Fingerprint issue.
Oops I see you want me to use Z-Wave Thing Mc. I will remove Z Wave Button Mc and replace
Nope still uses the generic Z Wave driver. It will not pair with either Z-Wave Button Mc or Z-Wave Thing Mc. I reset the Hub as well as factory settings on the ZRC 90. Grrrgh
Sorry, I do no konow wath is happen with your device
Where can I find the list of fingerprints this driver supports? Have a few GoControl WA00Z-1 switches I haven’t got covered for the end of Groovy.
This is the link to Zwave Button Mc fingerprints
6 posts were split to a new topic: GoControl WA00Z-1 Edge Driver?
I just added this device with the Edge device handler. The ZRC-90 shows in my app and all the buttons are listed and I have manage to program a button. However, I get a message that reads β€œThis device hasn’t updated all of its status information yet. Check again later”. The device shows in Standby mode and the buttons do not seem to do anything. Any help?
The ZRC-90 is working great, it just a very long time (a few hours) to update the status. Sorry for jumping the gun.
I got my 4-channel (8 button) Namron switch to work with Z-Wave Button MC Thanks @Mariano_Colmenarejo!
However the 2-channel (4 button) did not work. They are being added as β€œZ-Wave devices”. Any clue why @Mariano_Colmenarejo?
Hi @Magnus1
Because I only added the 8-button device to driver for two users who requested it, but they have not said anything if they have tried it or not.
Make sense. Any chance to add the 4-button device to to driver as well @Mariano_Colmenarejo?
Hi @Magnus1
If you provide me with a link to the documentation and fingerprints, I’ll look at it.
Great, works fine, many thanks :slight_smile:
Regarding the 4 button device, I don’t have that myself yet, but this is the manual: https://www.elektroimportoren.no/docs/lib/4512720-Brukerveiledning-5.pdf
Appears to be exactly the same, just with fewer buttons.
However I suspect the β€œProduct Type ID” in the manual is wrong (or they have multiple). Since for the 8 button device I have, the manual lists it as 0x0003, but it actually is 0x0300.
Great! Here is the link to Z-wave database: https://products.z-wavealliance.org/products/3911
Hi @Magnus1 @teo78
Added to this driver version, 2Kanal an 1Kanal buttons. The 4Kanal already existed in driver
I hope the fingerprints are correct as there is a discrepancy between the manual and zwave alliance
 Name         Z-Wave Button Mc
 Version      2023-01-30T15:56:18.094875445
- id: Namron/4kanal
    deviceLabel: Namron 4kanal
    manufacturerId: 0x0438
    productType: 0x0300
    productId: 0xA305
    deviceProfileName: multi-button-8
- id: Namron/2kanal
    deviceLabel: Namron 2kanal
    productType: 0x0300
    productId: 0xA306
    deviceProfileName: multi-button-4
- id: Namron/1kanal
    deviceLabel: Namron 1kanal
    productType: 0x0300
    productId: 0xA30F
    deviceProfileName: multi-button-2
