The main switch is S1 and the child is S2.
You say that the one that doesn’t work is the main one, right?
Oh yes, of course you’re right, the physical switch on S2 should work correctly anyway, and the doubt is whether the physical switch on S1 works. I’ll perform a test tomorrow. Thank you
Can anyone explain how the Fibaro Smart Implant works with multiple temperature sensors connected? If you wire three, they all wire to the same connections, so is the reported temperature an average of the three? Thanks.
Not average. Each measurement is separate.
Really? How does one see that in the app with this driver? I had initially connected it all up with two probes but could not find more than one temperature measurement in the device itself…
Hello Mariano. I was just posting a question on Daniele_Ratti’s [ST Edge] Driver for FIBARO Roller Shutter 3 (with energy monitoring and venetian blinds support) page, before I found this.
I think about to buy 9 used Fibaro Roller Shutter 2 FGR-222 for only 15€ and was wondering if this driver works with the venetian blinds feature. I saw this topic on this page multiple times but not a clear answer.
I’m also curious what the difference between your and Daniele’s driver is?
Thank you very much for your support! I don’t know what I would do to my smartthings hub if you wouldn’t release so many great drivers!
Hi @KochS
The Venetian blind functions are not implemented in my driver, because I saw in the manual that to operate in Venetian mode need set parameter 3 to value = 1 (commands are sent to the hun with Fibaro command class instead Zwave command class).
GENERAL SETTINGS:
3. Reports type
0 - Blind position reports sent to the main controller using Z-Wave Command Class.
1 - Blind position reports sent to the main controller using Fibaro Command Class.
Parameters value shoud be set to 1 if the module operates in Venetian Blind mode.
Default setting: 0
Parameter size: 1 [byte]
Since I don’t know what this entails, I only implemented it in the fibaro FGR-223
I don’t know, I haven’t seen Daniele’s driver code
And again! Thank you very much for your incredible fast response! I really appreciate your work in this community!
I will buy them anyway for my other non-venetian blinds.
Thanks again!
Hi @Mariano_Colmenarejo ,
First of all, congratulations for the great contribution you offer to the SmartThings community.
I intervene in this discussion because I need your support for a problem that I will now try to illustrate.
I used your DriverEdge “Z-Wave Window Treatment Mc” to manage the sectional garage door equipped with a Nice motor, to which I integrated its own Z-Wave module (mod. IBT4ZWAVE).
Yours is the only DriverEdge, among several tested, that allows me to obtain acceptable functionality, however some defects still persist.
The first discordant note is certainly the icon with which the device is represented in the APP, in fact SmartThings considers the device as if it were a motorized window blind rather than a garage door.
Furthermore, the device’s capabilities include the measurement of Power and Energy, values that the Nice device obviously does not detect. Due to this anomaly, every time I select the device from the APP, the note appears: “This device has not yet updated all of its settings of the states. Please try again later”.
Last note concerns the “Default position” function which is not configurable.
Given the above, I ask you if there is the possibility of updating your DriverEdge so that the Nice accessory is actually recognized as a “garage door” type device and so that it offers only its specific capabilities in the Tile.
I thank you in advance.
Greetings
Hi @dbHAxST
I need to know all the data, fingerprints, command class of the device.
Could you change to the zwave thing Mc driver and publish the data?
Hi @dbHAxST
Changed to profile nice-garage-door without power, energy and preset position
Try if works
Name Z-Wave Window Treatment Mc
Version 2023-09-28T20:08:30.327874442
- id: NICE/IBT4ZWAVE
deviceLabel: NICE Door IBT4ZWAVE
manufacturerId: 0x0441
productType: 0x2400
productId: 0x1000
deviceProfileName: nice-garage-door
