This device is added with a generic profile without preference settings in both the stock driver and mine.
For these cases, parameters can be configured by installing the Z-Wave Device Config Mc driver.
Change to that driver, configure the required parameters and then return to the original driver.
Hello @Mariano_Colmenarejo , thank you for your work on this siren! I have a wink siren which is a rebranded Zipato Siren with the 10 sounds, would you be so kind as to add the fingerprint to your driver so i can use your driver? Right now I can only use it as a switch. Thank you so much!
For the moment i didnt manage to connect the external sensors. I think until now it is not working with the external sensort . Hopefully sombeody will also implent this as also i have 2 smart implants for the temperature sensors and at the moment i cant use them.
Iβve been trying this out since the switchover from ovidiu.pruteanuβs device handler. I also have two DS18B20 sensors wired up. It kind of looks like the internal temperature field is showing both the internal device temperature as well as one of the two sensor temperatures and alternating between them. The external temperature field is continuously showing the other sensorβs input.
I greatly appreciate your support for the Smart Implant.
You can create child virtual thermostat for probe 1 a nd probe 2 as option.
In tile internal temp will show for profile 2 probes
Install this driver version
Perform a driver change to this driver and wait one minute to install new driver
Close device and perform app delete cache memory to see new profile
In device settings preferences select 2 external temperature probes
This driver works for 1 or 2 extenal temperature probes
βββββββββββββββββββββββββββββββββββββββββββββββββββ
Name Fibaro Smart Implant BETA-2
Package Key zwave-fibaro-smart-implant-2
I updated the driver with the method you explained and also changed the settings to show two external temperature sensors. However, the display appears to show no different that the original Beta driver. Not sure what else to do.
I am using IOS, but I switched the driver and then offloaded the Smartthings app just to delete any temporary files. Restarted app, phone, etc. No luck.
It seems that when I add a routine, the temperature range that I can select must be between -4 to 122 deg F. Since this is for a home boiler application, temperatures will regularly exceed this limitation. Is there a way to fix this, or is it a Smartthings issue?
