That’s good news. In the Smartthings FAQ they say “This device will no longer be supported in the SmartThings app.” so I assumed the official driver would not work.
Hello @Mariano_Colmenarejo.
2 Questions for you:
- Is it normal that when we swype in a Device using “Window Treatment MC” Driver, the data is not refreshed?
- Is it normal not seeing the energy status of the device? It only shows up a cloud with a line crossing it. When I used a DTH this information was available.
This is a smartthings problema, i reported It in the community. Zwave devices not works refresh
It should work, it may not be paired correctly or the parameters that control the power and energy reports may not be configured correctly.
I don’t have these devices and I can’t see anything.
Ask other users of these devices to see if they want to help with something
Ok. I don’t think that is a parameter problem. There is nothing there that we can choose on or off for energy/power meters…
Is there anyone using these driver with “Fibaro FGR-222” and have energy/power meters working???
This works a treat on my FIBARO ROLLER SHUTTER 2 (FGR-222).
The only issue is I used the “invert switch” option in the DTH, is that something that can be added easily? Forgive me if I have missed something…
I have had an issue with Power and Energy Consumption levels not displaying properly for the FGR-222 for a while in the SmartThings app (using a DTH and now the same with an Edge driver).
I see the icon that is a cloud with a line through it.
If anyone knows a fix I would also like to know this!
I think the link you referred is for the Dimmer Version 1 only, the version 2 is supported
This is the invert option I was hoping to use in this new driver… Anyone have any ideas if this is possible to add?
This device has no parameters to change the setting of inverting the open and close inputs.
To do so, you would have to modify the driver code.
A possible solution is that you open the mechanism where the switch is and change the cables Q1 for Q2. This way when you command it to open it will close and when you command it to close it will open
Diagramas de cableado:
Diagrama de cableado de Roller Shutter
I made some changes in the subdriver of rollershitter 2 try to see if it shows power
│ Name │ Z-Wave Window Treatment Mc │
│ Version │ 2022-09-21T19:13:28.004274962 │
Yes it’s the dimmer 1 I’m asking about (FGD-211). Thanks.
Hi @yosarian
If you want I can include it as a generic dimmer and if you need to modify any configuration parameter you can use the Z-Wave Device Config Mc driver and the fibaro manual to see what parameters it has
If so, pass me the fingerprints
No. Still nothing. Only a cloud with a line crossing it. And even in the History of the devices it doesn’t report anything related to power.
I used this DTH along the way and it always worked well:
Today I won’t be able to do anything, I’m busy assembling furniture!!!
get some logs and I’ll look at them as soon as I can.
Without them I can not know what happens
That’s great - I switched the cables around and it’s correct now.
Appreciate the help.
I changed this blind opening % and the logs show this:
2022-09-22T11:26:54.794859409+00:00 TRACE Z-Wave Window Treatment Mc Received event with handler capability
2022-09-22T11:26:54.804563867+00:00 INFO Z-Wave Window Treatment Mc <ZwaveDevice: 0cc35113-7deb-474a-9195-bd9b3b08e7c6 [18] (Persiana Suite)> received command: {"args":{"shadeLevel":71},"capability":"windowShadeLevel","command":"setShadeLevel","component":"main","positional_args":[71]}
2022-09-22T11:26:54.809807950+00:00 TRACE Z-Wave Window Treatment Mc Found CapabilityCommandDispatcher handler in zwave_window_treatment
2022-09-22T11:26:54.815214659+00:00 INFO Z-Wave Window Treatment Mc <ZwaveDevice: 0cc35113-7deb-474a-9195-bd9b3b08e7c6 [18] (Persiana Suite)> sending Z-Wave command: {args={duration=1, value=71}, cmd_class="SWITCH_MULTILEVEL", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x47\x01", src_channel=0, version=2}
2022-09-22T11:26:54.820462284+00:00 TRACE Z-Wave Window Treatment Mc Z-Wave command(d9654502) queued for radio transmission: CC:Switch Multi-level, CID:0x01
2022-09-22T11:26:54.830361742+00:00 DEBUG Z-Wave Window Treatment Mc Persiana Suite device thread event handled
2022-09-22T11:26:54.835461950+00:00 DEBUG Z-Wave Window Treatment Mc Persiana Suite device thread event handled
2022-09-22T11:26:54.999774450+00:00 TRACE Z-Wave Window Treatment Mc Z-Wave command(d9654502) transmit status: TRANSMIT_COMPLETE_OK
2022-09-22T11:26:59.844679242+00:00 INFO Z-Wave Window Treatment Mc <ZwaveDevice: 0cc35113-7deb-474a-9195-bd9b3b08e7c6 [18] (Persiana Suite)> sending Z-Wave command: {args={}, cmd_class="SWITCH_MULTILEVEL", cmd_id="GET", dst_channels={}, encap="AUTO", payload="", src_channel=0, version=1}
2022-09-22T11:26:59.850062617+00:00 TRACE Z-Wave Window Treatment Mc Z-Wave command(c2490972) queued for radio transmission: CC:Switch Multi-level, CID:0x02
2022-09-22T11:26:59.859308451+00:00 DEBUG Z-Wave Window Treatment Mc Persiana Suite device thread event handled
2022-09-22T11:26:59.999801034+00:00 TRACE Z-Wave Window Treatment Mc Z-Wave command(c2490972) transmit status: TRANSMIT_COMPLETE_OK
2022-09-22T11:27:00.090305159+00:00 TRACE Z-Wave Window Treatment Mc Received event with handler unnamed
2022-09-22T11:27:00.095234284+00:00 INFO Z-Wave Window Treatment Mc <ZwaveDevice: 0cc35113-7deb-474a-9195-bd9b3b08e7c6 [18] (Persiana Suite)> received Z-Wave command: {args={value=75}, cmd_class="SWITCH_MULTILEVEL", cmd_id="REPORT", dst_channels={}, encap="NONE", payload="K", src_channel=0, version=1}
2022-09-22T11:27:00.104733618+00:00 TRACE Z-Wave Window Treatment Mc Found ZwaveDispatcher handler in zwave_window_treatment -> window treatment venetian
2022-09-22T11:27:00.108319534+00:00 INFO Z-Wave Window Treatment Mc <ZwaveDevice: 0cc35113-7deb-474a-9195-bd9b3b08e7c6 [18] (Persiana Suite)> emitting event: {"attribute_id":"windowShade","capability_id":"windowShade","component_id":"main","state":{"value":"partially open"}}
2022-09-22T11:27:00.119656409+00:00 INFO Z-Wave Window Treatment Mc <ZwaveDevice: 0cc35113-7deb-474a-9195-bd9b3b08e7c6 [18] (Persiana Suite)> emitting event: {"attribute_id":"shadeLevel","capability_id":"windowShadeLevel","component_id":"main","state":{"value":75}}
2022-09-22T11:27:00.130039201+00:00 DEBUG Z-Wave Window Treatment Mc Persiana Suite device thread event handled
Nothing seems related to power/energy
Device does not send any for power or Energy.
Please, capture logs when push open or close in mechanical switch
This is the OPEN command using the button:
2022-09-22T13:56:23.630294435+00:00 TRACE Z-Wave Window Treatment Mc Received event with handler unnamed
2022-09-22T13:56:23.635451143+00:00 INFO Z-Wave Window Treatment Mc <ZwaveDevice: 146aedd6-1c2a-411f-9c6f-86f1654d6a37 [1A] (Persiana Cozinha)> received Z-Wave command: {args={switch_value="ON_ENABLE"}, cmd_class="SWITCH_BINARY", cmd_id="SET", dst_channels={}, encap="NONE", payload="\xFF", src_channel=0, version=1}
2022-09-22T13:56:23.642575268+00:00 TRACE Z-Wave Window Treatment Mc Found ZwaveDispatcher handler in zwave_window_treatment -> window treatment venetian -> fibaro roller shutter 2
2022-09-22T13:56:23.645664727+00:00 PRINT Z-Wave Window Treatment Mc cmd.args.switch_value >>>>>>>>>>>>> 255
2022-09-22T13:56:23.649511935+00:00 INFO Z-Wave Window Treatment Mc <ZwaveDevice: 146aedd6-1c2a-411f-9c6f-86f1654d6a37 [1A] (Persiana Cozinha)> emitting event: {"attribute_id":"windowShade","capability_id":"windowShade","component_id":"main","state":{"value":"open"}}
2022-09-22T13:56:23.663962060+00:00 INFO Z-Wave Window Treatment Mc <ZwaveDevice: 146aedd6-1c2a-411f-9c6f-86f1654d6a37 [1A] (Persiana Cozinha)> emitting event: {"attribute_id":"shadeLevel","capability_id":"windowShadeLevel","component_id":"main","state":{"value":100}}
2022-09-22T13:56:23.678156102+00:00 DEBUG Z-Wave Window Treatment Mc Persiana Cozinha device thread event handled
2022-09-22T13:56:23.682904227+00:00 DEBUG Z-Wave Window Treatment Mc Persiana Cozinha device thread event handled
2022-09-22T13:56:28.694666434+00:00 INFO Z-Wave Window Treatment Mc <ZwaveDevice: 146aedd6-1c2a-411f-9c6f-86f1654d6a37 [1A] (Persiana Cozinha)> sending Z-Wave command: {args={}, cmd_class="SWITCH_MULTILEVEL", cmd_id="GET", dst_channels={0}, encap="AUTO", payload="", src_channel=0, version=1}
2022-09-22T13:56:28.700137600+00:00 TRACE Z-Wave Window Treatment Mc Z-Wave command(ce5e395d) queued for radio transmission: CC:Switch Multi-level, CID:0x02
2022-09-22T13:56:28.710397350+00:00 INFO Z-Wave Window Treatment Mc <ZwaveDevice: 146aedd6-1c2a-411f-9c6f-86f1654d6a37 [1A] (Persiana Cozinha)> sending Z-Wave command: {args={}, cmd_class="BASIC", cmd_id="GET", dst_channels={0}, encap="AUTO", payload="", src_channel=0, version=1}
2022-09-22T13:56:28.716118600+00:00 TRACE Z-Wave Window Treatment Mc Z-Wave command(a1e7347f) queued for radio transmission: CC:Basic, CID:0x02
2022-09-22T13:56:28.720127767+00:00 INFO Z-Wave Window Treatment Mc <ZwaveDevice: 146aedd6-1c2a-411f-9c6f-86f1654d6a37 [1A] (Persiana Cozinha)> sending Z-Wave command: {args={scale=0}, cmd_class="METER", cmd_id="GET", dst_channels={0}, encap="AUTO", payload="\x00", src_channel=0, version=3}
2022-09-22T13:56:28.724900267+00:00 TRACE Z-Wave Window Treatment Mc Z-Wave command(0ccb71fc) queued for radio transmission: CC:Meter, CID:0x01
2022-09-22T13:56:28.728928767+00:00 INFO Z-Wave Window Treatment Mc <ZwaveDevice: 146aedd6-1c2a-411f-9c6f-86f1654d6a37 [1A] (Persiana Cozinha)> sending Z-Wave command: {args={scale=2}, cmd_class="METER", cmd_id="GET", dst_channels={0}, encap="AUTO", payload="\x10", src_channel=0, version=3}
2022-09-22T13:56:28.733596642+00:00 TRACE Z-Wave Window Treatment Mc Z-Wave command(bb3f88fa) queued for radio transmission: CC:Meter, CID:0x01
2022-09-22T13:56:28.736647600+00:00 DEBUG Z-Wave Window Treatment Mc Persiana Cozinha device thread event handled
2022-09-22T13:56:28.847027975+00:00 TRACE Z-Wave Window Treatment Mc Z-Wave command(ce5e395d) transmit status: TRANSMIT_COMPLETE_OK
2022-09-22T13:56:28.852899892+00:00 TRACE Z-Wave Window Treatment Mc Received event with handler unnamed
2022-09-22T13:56:28.857655600+00:00 INFO Z-Wave Window Treatment Mc <ZwaveDevice: 146aedd6-1c2a-411f-9c6f-86f1654d6a37 [1A] (Persiana Cozinha)> received Z-Wave command: {args={value=38}, cmd_class="SWITCH_MULTILEVEL", cmd_id="REPORT", dst_channels={}, encap="NONE", payload="&", src_channel=0, version=1}
2022-09-22T13:56:28.871629892+00:00 TRACE Z-Wave Window Treatment Mc Found ZwaveDispatcher handler in zwave_window_treatment -> window treatment venetian
2022-09-22T13:56:28.875064934+00:00 INFO Z-Wave Window Treatment Mc <ZwaveDevice: 146aedd6-1c2a-411f-9c6f-86f1654d6a37 [1A] (Persiana Cozinha)> emitting event: {"attribute_id":"windowShade","capability_id":"windowShade","component_id":"main","state":{"value":"partially open"}}
2022-09-22T13:56:28.886478892+00:00 INFO Z-Wave Window Treatment Mc <ZwaveDevice: 146aedd6-1c2a-411f-9c6f-86f1654d6a37 [1A] (Persiana Cozinha)> emitting event: {"attribute_id":"shadeLevel","capability_id":"windowShadeLevel","component_id":"main","state":{"value":38}}
2022-09-22T13:56:28.896693642+00:00 DEBUG Z-Wave Window Treatment Mc Persiana Cozinha device thread event handled
2022-09-22T13:56:28.980557017+00:00 TRACE Z-Wave Window Treatment Mc Z-Wave command(a1e7347f) transmit status: TRANSMIT_COMPLETE_OK
2022-09-22T13:56:29.021168767+00:00 TRACE Z-Wave Window Treatment Mc Received event with handler unnamed
2022-09-22T13:56:29.026061809+00:00 INFO Z-Wave Window Treatment Mc <ZwaveDevice: 146aedd6-1c2a-411f-9c6f-86f1654d6a37 [1A] (Persiana Cozinha)> received Z-Wave command: {args={value=38}, cmd_class="BASIC", cmd_id="REPORT", dst_channels={}, encap="NONE", payload="&", src_channel=0, version=1}
2022-09-22T13:56:29.038024934+00:00 TRACE Z-Wave Window Treatment Mc Found ZwaveDispatcher handler in zwave_window_treatment -> window treatment venetian
2022-09-22T13:56:29.041414809+00:00 INFO Z-Wave Window Treatment Mc <ZwaveDevice: 146aedd6-1c2a-411f-9c6f-86f1654d6a37 [1A] (Persiana Cozinha)> emitting event: {"attribute_id":"windowShade","capability_id":"windowShade","component_id":"main","state":{"value":"partially open"}}
2022-09-22T13:56:29.050513059+00:00 INFO Z-Wave Window Treatment Mc <ZwaveDevice: 146aedd6-1c2a-411f-9c6f-86f1654d6a37 [1A] (Persiana Cozinha)> emitting event: {"attribute_id":"shadeLevel","capability_id":"windowShadeLevel","component_id":"main","state":{"value":38}}
2022-09-22T13:56:29.059385600+00:00 DEBUG Z-Wave Window Treatment Mc Persiana Cozinha device thread event handled
2022-09-22T13:56:29.117025517+00:00 TRACE Z-Wave Window Treatment Mc Z-Wave command(0ccb71fc) transmit status: TRANSMIT_COMPLETE_OK
2022-09-22T13:56:29.122849184+00:00 TRACE Z-Wave Window Treatment Mc Received event with handler unnamed
2022-09-22T13:56:29.131651559+00:00 INFO Z-Wave Window Treatment Mc <ZwaveDevice: 146aedd6-1c2a-411f-9c6f-86f1654d6a37 [1A] (Persiana Cozinha)> received Z-Wave command: {args={delta_time=0, meter_type="ELECTRIC_METER", meter_value=2.38, precision=2, rate_type="IMPORT", scale="KILOWATT_HOURS", size=4}, cmd_class="METER", cmd_id="REPORT", dst_channels={}, encap="NONE", payload="\x21\x44\x00\x00\x00\xEE\x00\x00", src_channel=0, version=3}
2022-09-22T13:56:29.141575850+00:00 DEBUG Z-Wave Window Treatment Mc Persiana Cozinha device thread event handled
2022-09-22T13:56:29.179815809+00:00 TRACE Z-Wave Window Treatment Mc Z-Wave command(bb3f88fa) transmit status: TRANSMIT_COMPLETE_OK
2022-09-22T13:56:29.220418267+00:00 TRACE Z-Wave Window Treatment Mc Received event with handler unnamed
2022-09-22T13:56:29.229266392+00:00 INFO Z-Wave Window Treatment Mc <ZwaveDevice: 146aedd6-1c2a-411f-9c6f-86f1654d6a37 [1A] (Persiana Cozinha)> received Z-Wave command: {args={delta_time=0, meter_type="ELECTRIC_METER", meter_value=172.1, precision=1, rate_type="IMPORT", scale="WATTS", size=2}, cmd_class="METER", cmd_id="REPORT", dst_channels={}, encap="NONE", payload="\x21\x32\x06\xB9\x00\x00", src_channel=0, version=3}
2022-09-22T13:56:29.235160392+00:00 DEBUG Z-Wave Window Treatment Mc Persiana Cozinha device thread event handled
Well, here a get is done for power and energy, the device answers and the received values should have been emitted since the driver uses the defaults edge.
Another thing is why it doesn’t send power and energy until it is interrogated with a get.
I would do a factory reset and re-pair it as close to the hub as possible
Factory resetting the device won’t cause the driver to start processing those z-wave commands properly. The logs indicate that those Meter reports don’t have a handler assigned in the driver. Does your driver register for the default handlers for power and energy?
