No.
Edit: your device is the TS0601, not TS0001.
Short Summary: TS0001 vs TS0601
| Feature |
TS0001 (e.g. Zemismart ZN-LRL1E) |
TS0601 |
| Protocol |
Standard Zigbee clusters |
Tuya proprietary (datapoints via cluster 0xEF00) |
| Main control |
On/Off cluster (0x0006) |
Private Tuya cluster only |
| Typical devices |
Simple 1-gang switches & relays |
Advanced switches, plugs with power monitoring, sensors, thermostats, curtains |
| Compatibility |
Excellent (plug & play in zigbee2mqtt) |
Good in zigbee2mqtt once mapped; often needs quirks in ZHA |
| Power-on behavior |
Usually native |
Via datapoint |
| Your ZN-LRL1E |
Clean TS0001 → best compatibility |
Bottom line:
TS0001 = simple & reliable (your device).
TS0601 = more feature-rich but more complex to support.
