I have exact same issue. New batteries. Deleted and re-added.
Only way ti make it work is to press the button to wake it up again. Few hours later it stops working. Plenty of Zigbee repeaters and devices behave the same when sat on top of the smartthings hub so jts not a distance issue or a mesh issue
Hi i try use this driver to control Aqara Double-rocker switch QBKG39LM. But Setting doesnât work with it and handle state of button (always standby)
Please send some log files from CLI in order debug the problem you have. Here are some instructions:
I dont what logs are need, its log when i press left after that right rocker.
2023-03-29T22:33:45.433916185+00:00 INFO Xiaomi/Aqara Switch and Button v1.11 <ZigbeeDevice: 2c4f24f8-1820-4c38-b9a0-2e21fa06a83c [0xDC20] (QBKG39LM E1 Wall Switch (No Neutral, Double Rocker))> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xDC20, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0x8E, rssi: -78, body_length: 0x000E, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0xD3, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Boolean, OnOff: true >, < AttributeRecord || AttributeId: 0x00F5, DataType: Uint32, Uint32: 0x03DC2000 > > > >
2023-03-29T22:33:45.459050518+00:00 TRACE Xiaomi/Aqara Switch and Button v1.11 Found ZigbeeMessageDispatcher handler in switch
2023-03-29T22:33:45.459876851+00:00 INFO Xiaomi/Aqara Switch and Button v1.11 Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2023-03-29T22:33:45.461752185+00:00 INFO Xiaomi/Aqara Switch and Button v1.11 <ZigbeeDevice: 2c4f24f8-1820-4c38-b9a0-2e21fa06a83c [0xDC20] (QBKG39LM E1 Wall Switch (No Neutral, Double Rocker))> emitting event: {âattribute_idâ:âswitchâ,âcapability_idâ:âswitchâ,âcomponent_idâ:âmainâ,âstateâ:{âvalueâ:âonâ}}
2023-03-29T22:33:45.465584185+00:00 DEBUG Xiaomi/Aqara Switch and Button v1.11 QBKG39LM E1 Wall Switch (No Neutral, Double Rocker) device thread event handled
2023-03-29T22:33:45.941693852+00:00 TRACE Xiaomi/Aqara Switch and Button v1.11 Received event with handler zigbee
2023-03-29T22:33:45.942935185+00:00 INFO Xiaomi/Aqara Switch and Button v1.11 <ZigbeeDevice: 2c4f24f8-1820-4c38-b9a0-2e21fa06a83c [0xDC20] (QBKG39LM E1 Wall Switch (No Neutral, Double Rocker))> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xDC20, src_endpoint: 0x29, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0x0012 >, lqi: 0x8A, rssi: -78, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0xD4, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0055, DataType: Uint16, Uint16: 0x0001 > > > >
2023-03-29T22:33:46.030517518+00:00 TRACE Xiaomi/Aqara Switch and Button v1.11 Found ZigbeeMessageDispatcher handler in switch
2023-03-29T22:33:46.033583852+00:00 INFO Xiaomi/Aqara Switch and Button v1.11 Executing ZclClusterAttributeValueHandler: cluster: 0x0012, attribute: 0x0055
2023-03-29T22:33:46.038283518+00:00 ERROR Xiaomi/Aqara Switch and Button v1.11 QBKG39LM E1 Wall Switch (No Neutral, Double Rocker) thread encountered error: [string âst/dispatcher.luaâ]:233: Error encountered while processing event for <ZigbeeDevice: 2c4f24f8-1820-4c38-b9a0-2e21fa06a83c [0xDC20] (QBKG39LM E1 Wall Switch (No Neutral, Double Rocker))>:
arg1: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xDC20, src_endpoint: 0x29, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0x0012 >, lqi: 0x8A, rssi: -78, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0xD4, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0055, DataType: Uint16, Uint16: 0x0001 > > > >
[string âst/device.luaâ]:121: attempt to index a nil value (local âcomponentâ)
2023-03-29T22:33:46.615912185+00:00 DEBUG Xiaomi/Aqara Switch and Button v1.11 driver device thread event handled
2023-03-29T22:33:50.022772520+00:00 TRACE Xiaomi/Aqara Switch and Button v1.11 Received event with handler zigbee
2023-03-29T22:33:50.024236187+00:00 INFO Xiaomi/Aqara Switch and Button v1.11 <ZigbeeDevice: 2c4f24f8-1820-4c38-b9a0-2e21fa06a83c [0xDC20] (QBKG39LM E1 Wall Switch (No Neutral, Double Rocker))> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xDC20, src_endpoint: 0x02, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0x8C, rssi: -75, body_length: 0x000E, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0xD5, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Boolean, OnOff: true >, < AttributeRecord || AttributeId: 0x00F5, DataType: Uint32, Uint32: 0x03DC2000 > > > >
2023-03-29T22:33:50.050179520+00:00 TRACE Xiaomi/Aqara Switch and Button v1.11 Found ZigbeeMessageDispatcher handler in switch
2023-03-29T22:33:50.051015854+00:00 INFO Xiaomi/Aqara Switch and Button v1.11 Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2023-03-29T22:33:50.052768187+00:00 INFO Xiaomi/Aqara Switch and Button v1.11 <ZigbeeDevice: 2c4f24f8-1820-4c38-b9a0-2e21fa06a83c [0xDC20] (QBKG39LM E1 Wall Switch (No Neutral, Double Rocker))> emitting event: {âattribute_idâ:âswitchâ,âcapability_idâ:âswitchâ,âcomponent_idâ:âbutton2â,âstateâ:{âvalueâ:âonâ}}
2023-03-29T22:33:50.068998520+00:00 DEBUG Xiaomi/Aqara Switch and Button v1.11 QBKG39LM E1 Wall Switch (No Neutral, Double Rocker) device thread event handled
2023-03-29T22:33:50.533003520+00:00 TRACE Xiaomi/Aqara Switch and Button v1.11 Received event with handler zigbee
2023-03-29T22:33:50.534242187+00:00 INFO Xiaomi/Aqara Switch and Button v1.11 <ZigbeeDevice: 2c4f24f8-1820-4c38-b9a0-2e21fa06a83c [0xDC20] (QBKG39LM E1 Wall Switch (No Neutral, Double Rocker))> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xDC20, src_endpoint: 0x2A, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0x0012 >, lqi: 0x8A, rssi: -76, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0xD6, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0055, DataType: Uint16, Uint16: 0x0001 > > > >
2023-03-29T22:33:50.544319520+00:00 TRACE Xiaomi/Aqara Switch and Button v1.11 Found ZigbeeMessageDispatcher handler in switch
2023-03-29T22:33:50.547390187+00:00 INFO Xiaomi/Aqara Switch and Button v1.11 Executing ZclClusterAttributeValueHandler: cluster: 0x0012, attribute: 0x0055
2023-03-29T22:33:50.552106520+00:00 ERROR Xiaomi/Aqara Switch and Button v1.11 QBKG39LM E1 Wall Switch (No Neutral, Double Rocker) thread encountered error: [string âst/dispatcher.luaâ]:233: Error encountered while processing event for <ZigbeeDevice: 2c4f24f8-1820-4c38-b9a0-2e21fa06a83c [0xDC20] (QBKG39LM E1 Wall Switch (No Neutral, Double Rocker))>:
arg1: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xDC20, src_endpoint: 0x2A, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0x0012 >, lqi: 0x8A, rssi: -76, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0xD6, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0055, DataType: Uint16, Uint16: 0x0001 > > > >
Hi veonua, thanks for taking the time to reply me. I have reinstalled the iOS app a couple of times since but am still unable to set the automations for the right gang of a 2 gang switch. Looks forward to hearing what other solutions might work.
Thanks in advance.
I believe that this is a regression in iOS no muti-components are available in the âThenâ section of routines.
It was broken then fixed and now broken again for the last month.
Your only option for now is to use an Android phone or Chromebook.
If automations have difficulties in Smartthings App, consider doing the same with Sharptools Rule Engine.
Register in https://sharptools.io/ and choose rule engine. This worked for me.
@veonua
Hi just received [Aqara E1 Wireless Remote Switch (Single Rocker) WXKG16LM]
Manufacturer: LUMI Model: lumi.remote.acn003 , as @Elishai_Poran have (He bought it for me for debug)
I tried your driver, the device paired successfully. But no respond from the switch. Here is a log from pairing, I also tried presses but not respond in LOG:
Log
2023-04-05T11:50:02.530120950+00:00 DEBUG Xiaomi/Aqara Switch and Button v1.11 driver device thread event handled
2023-04-05T11:50:32.544136276+00:00 DEBUG Xiaomi/Aqara Switch and Button v1.11 driver device thread event handled
2023-04-05T11:50:42.826510940+00:00 TRACE Xiaomi/Aqara Switch and Button v1.11 Received event with handler device_lifecycle
2023-04-05T11:50:42.932725482+00:00 TRACE Xiaomi/Aqara Switch and Button v1.11 Zigbee Device: ab5a893a-5b3b-4e19-bf43-17be4c8e202d
[1]: Basic, PowerConfiguration, Identify, 0x0012, 0xFCC0
2023-04-05T11:50:42.933326315+00:00 INFO Xiaomi/Aqara Switch and Button v1.11 <ZigbeeDevice: ab5a893a-5b3b-4e19-bf43-17be4c8e202d [0x141E] (Aqara E1 Wireless Switch (Single Rocker))> received lifecycle event: added
2023-04-05T11:50:42.934323440+00:00 TRACE Xiaomi/Aqara Switch and Button v1.11 Received event with handler device_lifecycle
2023-04-05T11:50:42.935183774+00:00 INFO Xiaomi/Aqara Switch and Button v1.11 <ZigbeeDevice: ab5a893a-5b3b-4e19-bf43-17be4c8e202d [0x141E] (Aqara E1 Wireless Switch (Single Rocker))> received lifecycle event: doConfigure
2023-04-05T11:50:42.938080815+00:00 TRACE Xiaomi/Aqara Switch and Button v1.11 Found DeviceLifecycleDispatcher handler in switch
2023-04-05T11:50:42.940183357+00:00 INFO Xiaomi/Aqara Switch and Button v1.11 Ep#1 device_id:0x0000 profile_id:0x0104 model:âlumi.remote.acn003â manufacturer:âLUMIâ Client clusters:[Identify, OnOff, OTAUpgrade, ] Server clusters:[Basic,
PowerConfiguration, Identify, MultistateInput, AqaraOpple, ]
2023-04-05T11:50:42.941061899+00:00 WARN Xiaomi/Aqara Switch and Button v1.11 No configuration found for device: lumi.remote.acn003
2023-04-05T11:50:42.941934357+00:00 INFO Xiaomi/Aqara Switch and Button v1.11 <ZigbeeDevice: ab5a893a-5b3b-4e19-bf43-17be4c8e202d [0x141E] (Aqara E1 Wireless Switch (Single Rocker))> emitting event: {âattribute_idâ:âsupportedButtonValue
sâ,âcapability_idâ:âbuttonâ,âcomponent_idâ:âmainâ,âstateâ:{âvalueâ:[âpushedâ,âpushed_2xâ]}}
2023-04-05T11:50:42.970790899+00:00 INFO Xiaomi/Aqara Switch and Button v1.11 number of buttons: 1
2023-04-05T11:50:42.975092399+00:00 INFO Xiaomi/Aqara Switch and Button v1.11 <ZigbeeDevice: ab5a893a-5b3b-4e19-bf43-17be4c8e202d [0x141E] (Aqara E1 Wireless Switch (Single Rocker))> emitting event: {âattribute_idâ:ânumberOfButtonsâ,âca
pability_idâ:âbuttonâ,âcomponent_idâ:âmainâ,âstateâ:{âvalueâ:1}}
2023-04-05T11:50:42.983211940+00:00 DEBUG Xiaomi/Aqara Switch and Button v1.11 Aqara E1 Wireless Switch (Single Rocker) device thread event handled
2023-04-05T11:50:42.987149482+00:00 TRACE Xiaomi/Aqara Switch and Button v1.11 Found DeviceLifecycleDispatcher handler in switch
2023-04-05T11:50:42.991199315+00:00 INFO Xiaomi/Aqara Switch and Button v1.11 Ep#1 device_id:0x0000 profile_id:0x0104 model:âlumi.remote.acn003â manufacturer:âLUMIâ Client clusters:[Identify, OnOff, OTAUpgrade, ] Server clusters:[Basic,
2023-04-05T11:50:42.991929190+00:00 WARN Xiaomi/Aqara Switch and Button v1.11 No configuration found for device: lumi.remote.acn003
2023-04-05T11:50:42.992636940+00:00 INFO Xiaomi/Aqara Switch and Button v1.11 <ZigbeeDevice: ab5a893a-5b3b-4e19-bf43-17be4c8e202d [0x141E] (Aqara E1 Wireless Switch (Single Rocker))> emitting event: {âattribute_idâ:âsupportedButtonValue
2023-04-05T11:50:42.998198649+00:00 INFO Xiaomi/Aqara Switch and Button v1.11 number of buttons: 1
2023-04-05T11:50:43.002760732+00:00 INFO Xiaomi/Aqara Switch and Button v1.11 <ZigbeeDevice: ab5a893a-5b3b-4e19-bf43-17be4c8e202d [0x141E] (Aqara E1 Wireless Switch (Single Rocker))> emitting event: {âattribute_idâ:ânumberOfButtonsâ,âca
2023-04-05T11:50:43.004533607+00:00 DEBUG Xiaomi/Aqara Switch and Button v1.11 Aqara E1 Wireless Switch (Single Rocker) device thread event handled
2023-04-05T11:50:43.013004024+00:00 TRACE Xiaomi/Aqara Switch and Button v1.11 Found DeviceLifecycleDispatcher handler in switch
2023-04-05T11:50:43.017061649+00:00 TRACE Xiaomi/Aqara Switch and Button v1.11 Found CapabilityCommandDispatcher handler in switch
2023-04-05T11:50:43.017876774+00:00 INFO Xiaomi/Aqara Switch and Button v1.11 Ep#1 device_id:0x0000 profile_id:0x0104 model:âlumi.remote.acn003â manufacturer:âLUMIâ Client clusters:[Identify, OnOff, OTAUpgrade, ] Server clusters:[Basic,
2023-04-05T11:50:43.018762149+00:00 WARN Xiaomi/Aqara Switch and Button v1.11 No configuration found for device: lumi.remote.acn003
2023-04-05T11:50:43.019410440+00:00 INFO Xiaomi/Aqara Switch and Button v1.11 <ZigbeeDevice: ab5a893a-5b3b-4e19-bf43-17be4c8e202d [0x141E] (Aqara E1 Wireless Switch (Single Rocker))> emitting event: {âattribute_idâ:âsupportedButtonValue
2023-04-05T11:50:43.024380565+00:00 INFO Xiaomi/Aqara Switch and Button v1.11 number of buttons: 1
2023-04-05T11:50:43.030004815+00:00 INFO Xiaomi/Aqara Switch and Button v1.11 <ZigbeeDevice: ab5a893a-5b3b-4e19-bf43-17be4c8e202d [0x141E] (Aqara E1 Wireless Switch (Single Rocker))> emitting event: {âattribute_idâ:ânumberOfButtonsâ,âca
2023-04-05T11:50:43.033517232+00:00 INFO Xiaomi/Aqara Switch and Button v1.11 <ZigbeeDevice: ab5a893a-5b3b-4e19-bf43-17be4c8e202d [0x141E] (Aqara E1 Wireless Switch (Single Rocker))> sending Zigbee message: < ZigbeeMessageTx || Uint16:
0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x141E, dest_endpoint: 0x01, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: 54EF441000685D76
, src_endpoint: 0x01, cluster: 0x0012, dest_addr_mode: 0x03, dest_address: D052A8A4E1940001, dest_endpoint: 0x01 > > >
2023-04-05T11:50:43.037538149+00:00 ERROR Xiaomi/Aqara Switch and Button v1.11 Aqara E1 Wireless Switch (Single Rocker) thread encountered error: [string âst/dispatcher.luaâ]:233: Error encountered while processing event for <ZigbeeDevi
ce: ab5a893a-5b3b-4e19-bf43-17be4c8e202d [0x141E] (Aqara E1 Wireless Switch (Single Rocker))>:
arg1: doConfigure
arg2: table: 0xb3af10
[string âst/zigbee/device_management.luaâ]:103: attempt to index a nil value (field âdata_typeâ)
2023-04-05T11:50:43.056881274+00:00 DEBUG Xiaomi/Aqara Switch and Button v1.11 Aqara E1 Wireless Switch (Single Rocker) device thread event handled
2023-04-05T11:50:43.287740148+00:00 TRACE Xiaomi/Aqara Switch and Button v1.11 Received event with handler device_lifecycle
2023-04-05T11:50:43.288552940+00:00 INFO Xiaomi/Aqara Switch and Button v1.11 <ZigbeeDevice: ab5a893a-5b3b-4e19-bf43-17be4c8e202d [0x141E] (Aqara E1 Wireless Switch (Single Rocker))> received lifecycle event: infoChanged
2023-04-05T11:50:43.294940273+00:00 TRACE Xiaomi/Aqara Switch and Button v1.11 Found DeviceLifecycleDispatcher handler in switch
2023-04-05T11:50:43.295379815+00:00 DEBUG Xiaomi/Aqara Switch and Button v1.11 Aqara E1 Wireless Switch (Single Rocker) device thread event handled
2023-04-05T11:50:43.541803107+00:00 TRACE Xiaomi/Aqara Switch and Button v1.11 Received event with handler zigbee
2023-04-05T11:50:43.545079107+00:00 INFO Xiaomi/Aqara Switch and Button v1.11 <ZigbeeDevice: ab5a893a-5b3b-4e19-bf43-17be4c8e202d [0x141E] (Aqara E1 Wireless Switch (Single Rocker))> received Zigbee message: < ZigbeeMessageRx || type: 0
x00, < AddressHeader || src_addr: 0x141E, src_endpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: 0x8021 >, lqi: 0xFE, rssi: -41, body_length: 0x0002, < ZDOMessageBody || < ZDOHeader || seqno: 0x11 >, < Bind
RequestResponse || status: 0x00 > > >
2023-04-05T11:50:43.548892940+00:00 DEBUG Xiaomi/Aqara Switch and Button v1.11 Aqara E1 Wireless Switch (Single Rocker) device thread event handled
2023-04-05T11:51:02.544816561+00:00 DEBUG Xiaomi/Aqara Switch and Button v1.11 driver device thread event handled
2023-04-05T11:51:32.549894753+00:00 DEBUG Xiaomi/Aqara Switch and Button v1.11 driver device thread event handled
2023-04-05T11:52:02.551465990+00:00 DEBUG Xiaomi/Aqara Switch and Button v1.11 driver device thread event handled
2023-04-05T11:52:32.562866785+00:00 DEBUG Xiaomi/Aqara Switch and Button v1.11 driver device thread event handled
2023-04-05T11:53:02.572928747+00:00 DEBUG Xiaomi/Aqara Switch and Button v1.11 driver device thread event handled
2023-04-05T11:53:29.984050167+00:00 TRACE Xiaomi/Aqara Switch and Button v1.11 Received event with handler zigbee
Please note that an error appear while pairing, copied from the log:
Error
arg1: doConfigure
@Mariano_Colmenarejo can you please look and give some ideas how to fix the driver ?
If that can help here is device details from ZigBee Thing:
Device Info
Manufacturer: LUMI
FingerPrinted_EndPoint.Id: 0x01
App Version: Ox07
ZCL Version: 0x03
Network ID: 0x141E
Zigbee EUI: 54EF441000685D76 Device ID: ab5a893a-5b3b-4e19-bf43-
17be4c8e202d
Server Cluster:
Ep: 0x01={0000,0001,0003,0012,FCC0}
Client Clusters:
Ep: 0x01={0003,0006,0019}
Signal Metric
LQI: 255⌠RSSI: -52 dbm
@veonua , @Mariano_Colmenarejo , @ygerlovin
No solution for Hubitat users as well, for now:
This works perfectly! Thanks for the suggestion.
Hi @veonua,
Just added switch lumi.switch.n2aeu1 which works almost right. However it shows 10x more power as it should� My ceiling lamp power is approx. 30W but with your driver it shows 320W. Is there anything to do?
Some time ago I have similar issues with Aqura H1 switch but then issue was solved when I change Edge driver couple of times. Now this doesnât seem to helpâŚ
Hi @veonua
Was there any updates to your drivers recently. Iâve had my Zigbee Aqara Single rocker button working fine until about 2 days ago and now they just sit on Standby in smartthings. Iâve deleted and readded. Its for WXKG11LM button.
Really appreciate your help, the drivers have been working perfectly for over a year so found it odd it suddenly stopped functioning properly. Have the same issue with all 3 buttons, all stopped at the same time so realized it wasnât a coincidence that only 1 stopped working.
Please share some logs from CLI while pairing and pressing.
Battery-powered Aqara remotes require a good Zigbee network preferably based on wired Aqara switches. Please check that the device is still online and reboot the hub.
Aqara has used different multipliers for various models, and the multiplier mapping has not been fully implemented or given priority. We welcome pull requests to address this issue.
Ok, thank you. How to make a pull request? Iâm too new here and donât know how to do this
Seems like everything is good againâŚi guess that update that was being pushed out broke my buttons for a couple days.
Fingers crossed all good going forward =)
Thanks everyone for responding.The aqara devices for the price and quality are quite good especially with Smartthings.
Hi @veonua ,
Would like to ask if you would be able to add a triple gang switch to the list? GBKG29LM. I am new to this smart home and smartthings entirely. Do let me know what you would require! Much appreciated.
