EcoLink Door / Window Sensor won’t pair
Here is the procedure that worked for me. Good Luck
Resetting Instructions - October 2020
  1. Remove the Battery.
  2. Delete the Sensor in the App.
  3. You may have to wait in the exclusion mode for a while then force delete.
  4. While the Battery is removed
  5. Go to Devices
  6. Go to Your Hub select three dots upper right.
  7. Select Z-Wave Utilities
  8. Place Application in Z-Wave Exclusion Mode
  9. Replace Battery
  10. Sensor LED will be Blinking
  11. Go to Your AP & add EcoLink Sensor
  12. When The App is searching for the device remove The battery and count to 5.
  13. Replace battery… wait for App to find sensor
  14. Success. Should Work.
If your still having problems try power cycling the hub and try again.
Again Good Luck
