Echo Speak - how to add Fire Tablet?
I have the same issue but it never bothered me. The only time though I get those screens are when I ask for weather or timer, etc… but normal ST commands like turn on & off lights doesn’t produce any additional screens. I will say though I renamed the activate word for my Fire-tablet from “Alexa” to “Computer” which prevents it sometimes doing a command I meant for an actual Echo device and when I do ask the Fire-Tablet for the Weather or Timer… when I’m done and I want to show again ActionTiles… I simply say to the tablet… “Computer, open ActionTiles” and ActionTiles then gets displayed again.
Sweet. I wonder if I could write a webcore piston to “open ActionTiles”? Thanks for the info. I’ll report back.
I’m not sure how webcore could work for that. Maybe another app could be used to ensure that ActionTiles is the always the “on-top” display as ActionTiles doesn’t actually close when an Alexa pop-up occurs. I bet such an app already exists… maybe even one of the KIOSK apps. Really wouldn’t work in my situation as I’ve also linked my Fire-Tablet to a in-wall bluetooth audio amplifier for my living room. When playing music, I like those Amazon screens to either show me the album cover or lyrics. But I bet an android app exists that could force which app is always displayed as the “on-top” display.
Initially this did not work. But I set it again, and it now seems to be working. Thanks.
I am still not able to add my Fire HD 10 (9th generation) to ES. I reset the pad to default. I registered it. I turned on Alexa. That’s all. And it still will not show up in ES or my ST app.
Same here. I’ve given up at this point. Maybe one day either Amazon will make the Tablet be more like an echo device or Echo Speak will update the app to include it. Hopefully we won’t be waiting too long.
I just started setting up multiroom echo/Alexa devices, 4 echo dots and 4 fire tablets, the echos work together, the tablets will only work individually, after some researching amazon has disabled fire tablets from joining a group, hopefully that helps
I am having the same problem with my fire hd 10 9th gen. Did anyone get this working? Thanks
Echo Speaks was discontinued over a year ago because it was using too many system resources. So no models work at the present time in the smartthings environment. :disappointed_relieved:
If you search the forum you can find some of the alternatives people are now using.
Using Amazon Echo for announcements
