Thanks for letting me know. I am working on finding out more information for you! Thanks so much for your patience!
We just posted a blog with some tips and tricks for life with Alexa, so check that out in the meantime. I’ll get back to you once I hear from my team regarding Harmony / Alexa / Yonomi functionality.
I have had this happening with my Philips smart bulbs since day one. I just gave up on a resolution and decided that nothing works 100%. If you get an answer from Echo tech support, please post.
Today, fast forward and rewind are no longer working with my TV viewing.
I use a momentary contact relay as a garage door opener and the device is called “garage door relay”. “Open Garage door” works for that, even though it’s a switch. “Close garage door” does not work but I can say "open garage door to close it again
Yup same here, but I didn’t like to say open when I was trying to close it. Ask Alexa skill works for close. I rather say alexa ask my home to close the door, instead of alexa open the door to close it. A matter of semantics nonetheless…
So I have that same semantic dilemma. I created a group called “bedtime” to power off the TV and living room lights. But, I have my “off” switch position in the start activity sequence. It didn’t seem to work to power off TV, etc in the end sequence.
However, I have to say “turn on bedtime” to turn the TV off, but “turn off bedtime” to turn the lights off. I feel like I’m missing the obvious in my set up, but I tried a few methods and then nothing would power off.
i created a group of thermostats called Downstairs, which confused Alexa (I presume because ‘down’ is a trigger word for thermostats). I had to call it “ground floor”, but to be honest that sounds a bit stupid when I say it.
I have an issue for Echo & Google in naming conversion:
Google Home - google advised not to include “group name” in the device name, e.g. Bed room fan. So i name it in ST as “broom fan” and in Google Home app to give a nickname as “Bed room fan”.
Echo - once i done above naming conversion. I can’t command echo to turn on Bed room fan, unless i move “broom fan” into single group name called “Bed room fan”.
Please advise how to support both assistance naming conversion in ST. Thanks
