Hi, I was wondering if there was a quick way to swap out one outlet for another. One of my Samsung’s SmartThings outlet is keeping power always on, even though the blue light changes and I can hear the clicks. Whats the easiest way to replace this outlet without having to manually re-add the replacement to all the smartapps that the original was used in?
There isn’t one, but make sure you don’t remove the broken one before you add the new one, as it would make it so much more difficult to figure out which app was using it. The way I would do this, is pair the new one and then from the Classic app, go to the old one and click the “SmartApps” tab, then one by one replace the broken one with the new outlet.
