What’s the easiest way ? Would prefer a button to do it as a Automation Routine inside the ST app if possible. Thx.
I don’t know if this is the easiest (depending on how many pistons you have) but you can create a simulated switch and then add a condition to each of your pistons that looks to see if the switch is on. If so, proceed with running the piston. If the switch is off then don’t run the piston.
Well, there you go. That definitely is the easiest. I forgot about pausing from the app.
I have a disabled mode that no apps are assigned to, and i ensure every app is assigned to run in Home, away or both modes. So when i want to kill all smart apps i just change the mode to disabled and viola!
