Hi I have some Australian branded Cygnett Home Temp/Humidity Sensors which are actually eWeLink RHK08 devices. Using a modified version of the SmartSense Temp/Humidity Sensor DTH to utilise the 0x0402 and 0x0405 cluster IDs I can get them to work . However, I’m struggling with the checkInterval/Reporting settings to make sure they regularly report (e.g. hourly) but don’t keep going offline in ST. They seem to wake up again after a few hours, give a reading and then go offline again.
Any ideas on how to tune this to get them reporting more consistently?
DTH extract:
def configure() {
sendEvent(name: “checkInterval”, value: 2 * 3600 + 1 * 60, displayed: false, data: [protocol: “zigbee”, hubHardwareId: device.hub.hardwareID, offlinePingable: “1”])
return refresh() +
zigbee.temperatureConfig(30, 3600) +
zigbee.configureReporting(zigbee.POWER_CONFIGURATION_CLUSTER, 0x0021, DataType.UINT8, 3600, 21600, 0x10) +
zigbee.configureReporting(0x0405, 0x0000, DataType.UINT16, 30, 3600, 100, [destEndpoint: 0x01])
within parse for temp:
sendEvent(name: “checkInterval”, value: 15 * 60, displayed: false, data: [protocol: “zigbee”, hubHardwareId: device.hub.hardwareID, offlinePingable: “1”])
Below is an example log from pairing:
04/20/2020 06:55:22 | eWeLink RHK08 | battery | 100 | 100 |
04/20/2020 06:55:24 | eWeLink RHK08 | temperature | 22 | 22 C |
04/20/2020 06:55:26 | eWeLink RHK08 | humidity | 71 | 71 % |
04/20/2020 06:55:48 | eWeLink RHK08 | humidity | 72 | 72 |
04/20/2020 06:59:38 | eWeLink RHK08 | humidity | 73 | 73 |
04/20/2020 06:59:38 | eWeLink RHK08 | temperature | 21 | 21 C |
04/20/2020 07:12:00 | eWeLink RHK08 | humidity | 76 | 76 |
04/20/2020 07:12:00 | eWeLink RHK08 | temperature | 20 | 20 C |
04/20/2020 07:28:03 | eWeLink RHK08 | activity | offline | offline |
04/20/2020 08:12:01 | eWeLink RHK08 | humidity | 78 | 78 |
04/20/2020 08:12:02 | eWeLink RHK08 | activity | online | online |
04/20/2020 08:28:15 | eWeLink RHK08 | activity | offline | offline |
04/20/2020 09:12:03 | eWeLink RHK08 | activity | online | online |
04/20/2020 09:12:03 | eWeLink RHK08 | humidity | 76 | 76 |
04/20/2020 09:28:06 | eWeLink RHK08 | activity | offline | offline |
04/20/2020 10:12:04 | eWeLink RHK08 | humidity | 77 | 77 |
04/20/2020 10:12:05 | eWeLink RHK08 | activity | online | online |
04/20/2020 10:28:17 | eWeLink RHK08 | activity | offline | offline |
04/20/2020 11:12:06 | eWeLink RHK08 | activity | online | online |
04/20/2020 11:12:06 | eWeLink RHK08 | humidity | 78 | 78 |
04/20/2020 11:28:07 | eWeLink RHK08 | activity | offline | offline |
04/20/2020 12:12:08 | eWeLink RHK08 | activity | online | online |
04/20/2020 12:28:19 | eWeLink RHK08 | activity | offline | offline |
04/20/2020 12:57:37 | eWeLink RHK08 | activity | online | online |
04/20/2020 13:28:12 | eWeLink RHK08 | activity | offline | offline |
04/20/2020 14:12:10 | eWeLink RHK08 | humidity | 77 | 77 |
04/20/2020 14:12:11 | eWeLink RHK08 | activity | online | online |
04/20/2020 14:29:22 | eWeLink RHK08 | activity | offline | offline |
04/20/2020 15:12:11 | eWeLink RHK08 | humidity | 71 | 71 |
04/20/2020 15:12:12 | eWeLink RHK08 | activity | online | online |
04/20/2020 15:28:15 | eWeLink RHK08 | activity | offline | offline |
04/20/2020 16:12:13 | eWeLink RHK08 | temperature | 19 | 19 C |
04/20/2020 16:12:14 | eWeLink RHK08 | activity | online | online |
04/20/2020 16:28:28 | eWeLink RHK08 | activity | offline | offline |
04/20/2020 17:12:15 | eWeLink RHK08 | activity | online | online |
04/20/2020 17:12:15 | eWeLink RHK08 | humidity | 75 | 75 |
04/20/2020 17:12:15 | eWeLink RHK08 | temperature | 20 | 20 C |
04/20/2020 17:28:21 | eWeLink RHK08 | activity | offline | offline |
04/20/2020 18:12:16 | eWeLink RHK08 | humidity | 73 | 73 |
04/20/2020 18:12:17 | eWeLink RHK08 | activity | online | online |
04/20/2020 18:29:03 | eWeLink RHK08 | activity | offline | offline |
04/20/2020 18:58:01 | eWeLink RHK08 | activity | online | online |
04/20/2020 19:12:18 | eWeLink RHK08 | humidity | 76 | 76 |
04/20/2020 19:30:19 | eWeLink RHK08 | activity | offline | offline |
04/20/2020 20:12:20 | eWeLink RHK08 | humidity | 75 | 75 |
04/20/2020 20:18:13 | eWeLink RHK08 | activity | online | online |
