Thanks @phiz118
I have been working on an app for the harmony hub/amazon echo so have not done much with the j64 alarm recently. I have been wanting to give linux a spin so will setup a VM when i have a little extra time.
I use a mac so have not really set this up on windows to auto boot when the machine turns on so am also curious how you would do it. I “think” you would just put something in the startup folder but am open to any thought you have.
Yes, it should. I just tested it in stay & away mode from mine and it synced with the app and also SHM. Let me know if this is not working for you.
I can’t find that sentence in my current docs, maybe i fixed that?
The stay vs. away works for me in SHM. There is a little bit of code in the smart app that must be having a problem in your setup. Is that ArmingMode being set wrong for you?
// Keep smart home monitor (SHM) in synch with the j64 alarm server
// We sync SHM with partition 1 in the alarm system since it does
// not support multiple partitions
if ("${Id}" == "1") {
if ("${IsArmed}".toLowerCase() == "false") {
setShmAlarmMode("off")
} else {
log.debug "check ArmingMode ${ArmingMode}"
if (ArmingMode == "Away")
setShmAlarmMode("away")
if (ArmingMode == "Stay")
setShmAlarmMode("stay")
