Driver Removal Issues
I am completely unable to remove any drivers. I keep getting the following error, I also get an error trying to unenroll a driver within a channel. Anyone with the same issue or a resolution?? In the case of the example below I have never used this particular driver so it is for sure not associated with a current device.
Error uninstalling driver “Zooz Double Switch ZEN30”. 504 504 Gateway Time-out
openresty
Report the issue to ST support. Probably a backend issue on their side that can be fixed.
Are you trying to delete the driver from the Advanced Web App website? Have you tried using the ST CLI?
Thanks, sent their way - they are sending to the engineering team.
