Solved (29 October): it was timing. Thanks to SmartThings support: the one step smartthings edge:drivers:package . --channel <id> --hub <id> installs too soon after the upload. That fails with NotFoundError, and the version stays failing on later installs too. Package, assign and install as separate commands with about two minutes in between, and package a new version if one already failed. Tested on 29 October on a v2 hub: separate steps installed, the one step command failed again. Details: [ST Edge] UniFi Protect Local: doorbell ring, motion and smart detections via API key
Hi,
Since about 14:25 UTC today (October 22), every driver package I upload fails to install on my hubs with:
`NotFoundError: Error installing driver (DRIVER_ID). Reason - Failed to install Driver with the driverId = DRIVER_ID`
What I have verified:
- The upload and the channel assignment succeed every time. Only the hub install fails.
- A package that installed fine at 14:24 UTC fails when uploaded again unchanged a few minutes later.
- The version processed at 14:24 UTC still installs fine on a fresh hub right now. Every version processed after 14:25 UTC fails.
- It fails on two hubs (v2 and v3, both online), in two channels (including a brand new one), and under two driver IDs (new packageKey).
- Official drivers and a driver from another developer install fine on the same hub at the same time.
- The driver never starts on the hub, logcat shows nothing.
- I uploaded about 13 versions today while debugging, so a limit or throttling on my account may be involved.
Driver IDs: 27595fa5-a979-491e-8c16-6cf5362cd859 and 9133afcf-c6a9-4f12-8764-187cd9e2a7f2 (the second one is deleted again)
Hub: 6926f63c-c337-40c3-875a-c2afb6eaf528 (v2), firmware 0.62.x
Request IDs: 6ada271e00000000aa1afd3d212237b8, 2C7CC77E-0AA3-4B00-92CA-53E040431941, d3ef2ff3-4e34-4694-a7eb-afe21cc64f92, 6ada3072000000007bc3fcb378d9e161
Could you check what the backend reports for these requests?
