So, the LED indicators use the standard dimming endpoint for lighting products.
So, as a workaround, if you change your device handler in the IDE for the “Smart Double Socket 1” to a “Zigbee Dimmer”, reboot the app, then you then get a dimmer bar in the app. Adjust to the desired level, then reset the device handler to “Zigbee Multi Switch Power” and hey presto.
This will allow you to set to a good level for the bedroom.
Bought an Aurora double socket this weekend and installed it, works a treat and looks good, set up was very easy just using the ST app.
Would be good to be able to dim the LEDs on the socket more easily as i’d like to place a few of these in the bed room and set up a an automation to dim/turn-off the LEDs when i go to bed.
One quirk i did find is that while each socket is treated as a different device in the ST app they do have different icons, one showing as a switch and one as an outlet, hope this get resolved at some point. the execution point is also in the cloud, was hoping this would be local.
The lowest dim is still pretty bright in daylight I find so I’ve not needed to keep changing it. If you do change the socket to a dimmer to change the brightness you will find you cannot change it back to being a Zigbee switch again (thats why you have a dimmer for one icon, although I dont think the below fixes that icon) which can lead to you not being able to control it. To get around this I raised a ticket with support and they had the following to help, it works for me just fine but is unsupported by the ST support team, they were just very helpful to provide this work around:
Blockquote If you still wish to give it a try, then they have advised to self publish the “Zigbee Multi Switch Power” Device Handler via the IDE (https://graph-eu01-euwest1.api.smartthings.com/) and remove the call to createChildDevices() in the installed() portion of the code. Once you publish this Device Handler in the IDE with those changes made, you can assign it to the Left Outlet device and it should stick. Because the Device Handler has been modified you will find it at the bottom of the list.
@AndyPrice-Aurora Any updates on a new DTH which will allow us to easily control the LED lights on your double wall socket? I want to put a few of these in the bedroom but with those LEDs won’t be appropriate at night. Was hoping I could set the LEDs for this room to turn off after sunset using ST automation etc.
@AndyPrice-Aurora Hi Andy, Any update on this please? I would also be interested in any update for dimming and energy consumpotion capabilities across both outlets (with maybe the power Icon for the second too). I have had limited success incorporating a dimmer pane in the classic app but it does not reflect in the new implementation. As @djsat2 says it would be very useful to have these available to ST automations.
These double sockets are great - recently installed a few of them with ST. However I still have Not found a way to change the settings for the red ‘led rings’ around the on/off switch which is annoying. Can anyone help?
