Double Tap from GE Auxiliary switch
I have a new GE Z wave wall switch that I have up and running in Smartthings using the double tap feature to trigger a Webcore piston. The switch is in a 3-way configuration with an older GE auxiliary switch. My double tap setup does not work on the aux, only the main. Do the newer aux switches support sending double taps to back to the main switch? Any other way to accomplish this?
Thanks.
Pretty sure the auxiliary switches have the same model number for the last 4 years. In other words I think they only communicate to the main one, I don’t believe they support any additional functions other than simple on-off and dimmer control.
