Double Setpoint Trigger
I’m noticing that when a command is triggered by automation from my Smarthome version 2, the correct Setpoint is set out, followed by another Setpoint that’s incorrect. Either from, let’s say 65 to 64.9 or 65 to 72. Any ideas what may be causing this? I own two Zen thermostats. Thanks!
those values are configured by you. You can set unique values to trace who commanded what when.
You can also view the phone app log.
You can also view the IDE login, live log.
https://graph.api.smartthings.com/login/auth
Been some time since I’ve written here, but can some somebody make some sense of this. Why does it double trigger setpoints? The first command is right, but the second is what it should trigger at another time.
I’m also experiencing this issue.
