Double Click one switch to turn off another
Hi. Can someone tell me how to create a routine so when I double click a switch, it turns off another light?
Thank you in advance!
The following is one of my routines that does what you want.
Thank you. When I go to setup the routines, I click routines in the app, choose create routine but don’t see where I can pick a devices under ‘if’. I only see ‘manual’. Does this makes sense?
Your device and the driver its using needs to support double click. What is the device make/model and what driver is it using?
No it doesn’t make sense. Switch, plugs, lights, and sensors should show up as triggers in the if part of automations.
This is what I see in the app when I create a routine when I select if.
This is the switch I have. Jasco Model zw3005
IIRC, the stock driver doesn’t support double click. Subscribe to this channel and install his Z-Wave Switch driver. You can change to that driver in the ST app or the AWA once it is installed.
