New SmartApp for Unlocking a door based on motion.
WARNING: USE AT YOUR OWN RISK. NOT EVERYONE CAN BE CHUCK NORRIS.
* Copyright 2015 Chuck Norris
* Unlock It When I Approach
* Author: Norris
* Date: 2015-07-20
definition(
name: "Unlock It When I Aproach",
namespace: "smartthings",
author: "Norris",
description: "Unlocks the door when you aproach. An attempt at seeing what it feels like to be Chuck Norris. Also helps if you flex your guns",
category: "Safety & Security",
iconUrl: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience.png",
iconX2Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience%402x.png",
oauth: true
preferences {
section("When I arrive..."){
input "motionSensor", "capability.motionSensor", title: "Where?", multiple: true
section("Unlock the lock..."){
input "lock", "capability.lock", multiple: true
def installed()
subscribe(motionSensor, "motion", motionHandler)
def updated()
unsubscribe()
def motionHandler(evt)
def anyLocked = lock.count{it.currentLock == "unlocked"} != lock.size()
if (anyLocked) {
sendPush "Unlocked door due to AWESOMENESS"
lock.unlock()
