It looks like the default “next” status for the stock doorControl capability is currently set to open/close, meaning when you tap the control action in the UI, it skips right over the opening/closing intermediate statuses. Even if I explicitly emit opening or closing in the edge driver, it still briefly flips to the open/close state.
Ideally, tapping the control when the door is open should immediately flip to closing; tapping it when closed should immediately flip to opening.
@nayelyz - is this something we can have changed? Or perhaps even have some way to override the default behavior in cases where we’d like to intercept the “next” status in the UI?
When I tap the UI open button in the mobile app (iOS), it immediately goes to Open/Closed. If I have the Edge command handler emit opening/closing, it will flip to that soon after but you still see that initial status. I’m actually not sure that the open/closed status truly gets set…it may just be an oddity in the UI itself.
Ok. I do see that as well. It is a recent quirk. It didn’t do that when I first wrote the virtual garage door. It looks like it is just a UI thing. I don’t see the event being emitted from the driver unless I explicitly emit it.
