I have an Aoetec “remote” / button (which which turns on 3 lights when pressed.
I want to add a 4th bulb.
I press it, see the 4 buttons contained in the remote. For button 1, I press the “Pressed” .
“THEN - choose what you want to happen when conditions are met” appears.
I click PLUS
It basically is making me set up the whole thing from scratch.
I don’t even mind that, but when I click “control devices”, then pick all 4 bulbs, then click on each to tell it what I want it to do (turn on in this case), and do it for all the bulbs, and make every select (color, dimmer, etc) , the “DONE” is still disabled at the top right.
Any ideas?
