If you want to use an Edge driver that works locally and that is how they work when groovy disappears, here is the link to the thread.
This driver has preferences for settings of intervals and precision of temperature reports.
I have one working, which I use as a Thermostat Edge driver.
I just flipped my sensor over to a different hub. To test it I put my finger on the top and the temperature changed almost instantly. Turns out that about three weeks ago the handler was updated to cope with a different model number and the reporting was also tweaked.
I havenât examined things too closely but it looks like temperature and humidity can report every ten seconds instead of every hour, but subject to a 0.5 degree change for temperature.
The checkInterval is still a bit out of bonk so presumably the device is frequently on the cusp of going offline.
That was a bit ambiguous. I have two v2 hubs in my Location and I switched the sensor from one to the other in the IDE, thus requiring it to be paired again and so picking up the changes in the handler.
I do have a different hub in another sense, but that is just an IKEA Gateway. I am not about to abandon ship.
You donât need to mess around like that. Just add it as a Sonoff/SONOFF multi-functional sensor or use âScan nearbyâ. It is recognised as a âSmartSense Temp/Humidity Sensorâ.
Thanks for the replay, I already connect my sonoff sensor with Sonoff/SONOFF multi-functional and the result was the sameâŚafter some hours they went down. Could the problem is my smartthings hub is close to my router? I read zigbee goes in conflict with router wifi?!
It is close to the hub, 2 meters away and the hub is 30 cm from the router.
My wifi channel is 6 and the zigbee channel is 24, I donât have any interference problems.
I use it as the main thermostat and I left the beko, which had as a backup 2°c below the sonoff and in more than 2 months it has never failed
What I have seen on this device is that the installation configuration response it well, answering success, but subsequent configuration changes, for changes in reporting intervals, do not always answer as accepted.
Therefore, it is very important that it is close to the hub in the installation process, because if it is not configured correctly, it will not periodically send battery, temperature and humidity reports and may become offline after a while.
Something similar also happens to the sonoff contact sensor
However the samjim sensors always accept configuration changes
I have four of them connected to SmartThings using the Zigbee Temp Humidty Sensor Mc Edge driver created by @Mariano_Colmenarejo and they stay connected all the time.
I have them configured to report every 10 minutes or 0.3 degress C or 1% humidty change.
I used the built-in SmartSense Temp/Humidity Sensor type. Iâm trying to get away from custom device handlers since theyâre going away. Do you have a link to that driver, looks like I need it. Thanks!
Delete the device from the app. (*)
Readd by sanning nearby.
(*) If you using the device in routines you may loose them when you delete the device. To avoid this you can put a virtual device in place of the sonoff.
In the Grooovy IDE it will show âPlaceholderâ for devices that use Edge drivers.
In the ST App, select the Sonoff sensor and press the three dots at the top right.
you should now have Edit, Settings, Driver, and Information entries.
