Has anyone figured out the integration with the Schulster Ditra infloor heating thermostat with Smarthings? I believe there is an integration with other smarthub platforms but cannot find anything with Smartthings?
You meant this one, right?
Schluter DITRA-HEAT-E-wifi Thermostat DHERT104/BW
Do you have a link to a specific example of an integration with another system?
Here you go;
Interesting! Well, if it’s doable with Home Assistant, it should be doable with smartthings, but it will take some custom code if no one‘s done one already. Hopefully someone will chime in who knows more.
Can we pull that other code developer with Home assistant to chime in on the smartthings integration for the ditra thermostat?
