I have an automation that pushes a collection of settings to a thermostat on a trigger. 4 Settings. When I create the automation everything behaves as you would expect.
When I go in later to edit the automation and adjust a particular setting the display implies that I’ve not set 3 out of 4 settings. So now I have to set all of the settings again just in case.
I assume this is a bug applied only to my thermostats as I do not have the same display problem when building automations with dimming switches.
