This seems like something many would want to do so maybe I’m missing something obvious.
Is there a way from the smartthings app to either disable a sensor or disable an automation routine that is triggering off a sensor?
I’ve got driveway lights turning on then off after 10 minutes driven off Guardline outdoor sensors coupled to a Ecolink door sensor.
It appears that if I manually turn the lights on from the app, if a sensor is triggered, the lights go off after the automation time interval. Like for a party I’d like to have the lights stay on regardless of whether a sensor is triggered.
I’m a newbie so AIA if this is a dumb question.
Thanks, Bob
BTW, with X10 I would do this by having switches/sensors add or subtract to/from a “use count” (phantom device) and then a different task would turn a light on if the use count was greater than zero and off if the use count is zero.
