Trying to start building my first device, following Todd’s manual instructions at rpi-st-device/ConfigGuide.pdf at main · toddaustin07/rpi-st-device · GitHub since I wanted to run through it once in detail to understand how setup worked.
I’ve gotten as far as starting to create the new project in the Developer Workspace. I selected Direct Connect, and it’s asking me to “Give this directly connected device integration a name”. Todd’s instructions referred me to How to Build Direct Connected Devices, which shows an example with this field filled in as Switch Example
. However, when I try to enter a simple name for my device, PiIR
, the workspace gives me an error saying “The field must be between 5 and 100.”
Is the Workspace broken somehow? Incompatible with Firefox? Or am I misunderstanding the instructions?
