i have 2 lights exact same and when i turn one of them on it is instant 100% the other is a gradual on. i have checked and both devices labeled the same and well… im not sure
Are they using the same device handler? They are the same make and model? Both updated firmware?
hum firmware… i bet its different i totally forgot about that thanks.
can i update an osram lighify bulb without the lightify hub?
AFAIK you need the Osram hub to do this.
ok thanks. i didn’t even think about the firmware
