Their seems to be two issues with dimmer settings. First, running on an iPhone when you are editing a Scene and try to adjust the dimmer setting it doesn’t show you the dimmer number while you are making the adjustment. Second, if you are running on an iPad you can’t adjust the dimmer at all when you are editing a scene because the dialog box doesn’t even show the dimmer slider. Seems like pretty poor QA testing.
