Dim With Me App Updated
AspenCo’s code fixed my problem! awesome. now if i can only integrate Ajma’s code to update the slave’s state it’ll be perfect…
ok, i merged AspenCO’s and Ajma’s code together, so now you have the slave’s state updating and dimming following the master [tried it with hue bulbs and jasco wall dimmers and it works.] can someone please double check the code to make sure i did it efficiently?
  • dim-with-me.app.groovy
  • Dim With Me
  • Author: todd@wackford.net
  • Date: 2013-11-12
  • App Name: Dim With Me
  • Author: Todd Wackford
  •    twack@wackware.net
  • Date: 2013-11-12
  • Version: 0.2
  • Use this program with a virtual dimmer as the master for best results.
  • This app lets the user select from a list of dimmers to act as a triggering
  • master for other dimmers or regular switches. Regular switches come on
  • anytime the master dimmer is on or dimmer level is set to more than 0%.
  • of the master dimmer.
  •                            Changes
  • Change 1: 2014-10-22 (wackford)
  •    Fixed bug in setlevelwhen on/off was coming in
  • Change 2: 2014-11-01 (wackford)
  •    added subscription to switch.level event. Shouldn't change much
  •    but some devices only sending level event and not setLevel.
Other Info: Special thanks to Danny Kleinman at ST for helping me get the
state stuff figured out. The Android state filtering had me
stumped.
// Automatically generated. Make future change here.
definition(
name: “Dim With Me”,
namespace: “wackware”,
author: “todd@wackford.net”,
description: “Follows the dimmer level of another dimmer”,
category: “My Apps”,
iconUrl: “https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience.png”,
iconX2Url: “https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience%402x.png
preferences {
section(“When this…”) {
input “masters”, “capability.switchLevel”,
multiple: false,
title: “Master Dimmer Switch…”,
required: true
section(“Then these will follow with on/off…”) {
input “slaves2”, “capability.switch”,
multiple: true,
title: “Slave On/Off Switch(es)…”,
required: false
section(“And these will follow with dimming level…”) {
input “slaves”, “capability.switchLevel”,
multiple: true,
title: “Slave Dimmer Switch(es)…”,
required: true
def installed()
subscribe(masters, “switch.on”, switchOnHandler)
subscribe(masters, “switch.off”, switchOffHandler)
subscribe(masters, “switch.setLevel”, switchSetLevelHandler)
subscribe(masters, “switch”, switchSetLevelHandler)
subscribe(masters, “level”, switchSetLevelHandler)
subscribe(slaves2, “switch.on”, slavesOnHandler)
subscribe(slaves2, “switch.off”, slavesOffHandler)
log.info “installed to all of switches events”
def updated()
unsubscribe()
log.info “subscribed to all of switches events”
def switchSetLevelHandler(evt)
if ((evt.value == “on”) || (evt.value == “off” ))
return
def level = evt.value.toFloat()
level = level.toInteger()
log.info “switchSetLevelHandler Event: ${masters.latestValue(“level”)}”
slaves?.setLevel(masters.latestValue(“level”))
def switchOffHandler(evt) {
log.info “switchoffHandler Event: ${evt.value}”
slaves?.off()
slaves2?.off()
def switchOnHandler(evt) {
log.info “switchOnHandler Event: ${evt.value}”
def dimmerValue = masters.latestValue(“level”) //can be turned on by setting the level
slaves?.on()
slaves2?.on()
def slavesOnHandler(evt) {
def allOn = true
for(slave in slaves2) {
if(slave.currentValue(“switch”) == “off”) {
allOn = false
last
if(allOn && masters.currentValue(“switch”) == “off”) {
masters.on()
def slavesOffHandler(evt) {
def allOff = true
if(slave.currentValue(“switch”) == “on”) {
allOff = false
last
if(allOff && masters.currentValue(“switch”) == “on”) {
masters.off()
Some delay, but nice App :slight_smile:
please dont use the code i posted, it’s buggy and the lights sometimes turn on/off randomly after you turn lights off. someone will need to debug the code.
First off, thanks for providing this. I can’t imagine why this isn’t a built in feature. I am having an issue, however, and I was hoping for a little help. What I want from this is to be able to use a wall dimmer, likely a GE, to control my LIFX bulbs so that I can keep them powered and always have access to them. I don’t currently have an actual dimmer, so to test the app I used one of my GE fan controllers as a dimmer, since they show as dimmers in ST. The code from Todd was able to turn on/of a light following the fan dimmer, but not adjust dimming. So on a whim, and even though he said not to, I tried mrsmartypants version. With his, the lights follow the fan speed, but I sometimes get odd light surges during transition. Even though the fan technically only has 3 speeds, it seems that the bulbs will follow the indicated percentage I select with the slider. Is this an effect of my setup? Did I do something wrong creating the app? Unfortunately, I don’t know the first thing about writing stuff for ST, yet.
Thanks for providing this update. I am trying to control a Hue bulb dimming using a HomeSeer WD100+. This almost works, but not quite. When dimming using the WD100 as master, the Hue simply turns off. Thoughts on how to fix?
Where can I find the latest ‘Dim with me’ code? Is there an authoritative version in github? In general, how do I know which version of a SmartApp is the latest? Posting code to a community form doesn’t seem like a very good way to manage source code…
Sorry newbie questions…
Anyone have an update to this? Functionality is so close. Just a little buggy. Would love to see this ironed out. Sorely needed functionality in ST. Any thoughts appreciated.
ASpenCO,
Your changes worked for me on my GE Smart Dimmer (in-wall), which I use to control two SYLVANIA LIGHTIFY bulbs that are paired directly with the SmartThings hub. (Without this modified script I had on/off working fine through the ST app, but lacked Dimmer support.)
I have GE Smart Dimmer Z-Wave, In-Wall, 12724 and found I couldn’t use SmartThings in-app options to control the dimmer, on/off worked fine but that’s it.
The dimmer is recognized as an on/off switch by SmartThings but not fully as a dimmer. Your script changes resolved that for me. I’m still unclear if this is a support issue on the SmartThings side or the GE side.
For reference:
GE Dimmer https://www.amazon.com/gp/product/B006LQFHN2/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
Lightify Bulbs https://www.amazon.com/gp/product/B0197840KQ/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
edit: updated for clarity on On/Off vs dimmer support
Is Dim With Me still in use? I’m trying to use it on my Philips bulbs with no success.
I would suggest looking at Trend Setter instead. It may do what you want and works quite well.
Thanks @kes601. Seems like there’s lots of suggestions for Dim With Me on the forums, but they’re mostly dated. I’ll give Trend Setter a shot.
Mirror has been added to the SmartLighting App. Give that a shot.
