# Dim delay with 2 hue bulbs
**URL:** <https://community.smartthings.com/t/dim-delay-with-2-hue-bulbs/75979>\
**Category:** Devices & Integrations\
**Created:** [January 30, 2017, 1:31am UTC](https://community.smartthings.com/t/dim-delay-with-2-hue-bulbs/75979 "2017-01-30T01:31:11Z")\
**Posts on this page:** 1\
**Showing post:** 2
<div class="post-metadata">
**Author:** ![JDRoberts](https://yyz2.discourse-cdn.com/smartthings/user_avatar/community.smartthings.com/jdroberts/32/56577_2.png) [@JDRoberts](https://community.smartthings.com/u/JDRoberts)\
**Post date:** [January 30, 2017, 1:52am UTC](https://community.smartthings.com/t/dim-delay-with-2-hue-bulbs/75979/2 "2017-01-30T01:52:48Z")
</div>
The short answer is that unfortunately you probably can’t get guaranteed simultaneous execution for commands that start from SmartThings.
This is called a “popcorn effect” and some members have been working with support on this for a couple of months and not been able to resolve it. 😥
> [@Hue delay between bulbs?](https://community.smartthings.com/t/hue-delay-between-bulbs/62888):
> Hi, Is anyone else seeing a delay between hue bulbs setting a level? i.e. one has almost finished turning on before the next starts to turn on… I’m using the standard Hue (Connect) and have a custom smart app running the below line of code settings.“sDimmers$i”?.setLevel(settings.“sBLevel$i”) i is a variable (1) in this instance This doesn’t go through any “each” loops or anything like that, and has been working fine until recently… The only thing I can think is that I upgraded to “Hue B Connect” 4 days ago and downgraded back to the standard Hue (Connect), I don’t think the issue was at the same time but it’s possible that I just hadn’t noticed…For a day or so… I assume when I reverted to Hue (Connect) that this was actually a newer set of code which is causing the issue I am seein…
There is a new update scheduled for tomorrow, we can always hope that might improve things, but they haven’t said anything specific about this issue.
_[View the full topic](https://community.smartthings.com/t/dim-delay-with-2-hue-bulbs/75979)._
