I successfully setup two z-wave devices; a open close switch and a plug-in dimmer switch. I then created a test routine that gave me the option to include either or both of those devices in the routine.
Yesterday, I successfully added several more devices to my list of Things. When I created a new routine, the choices given to me were to turn on or off something, and when I chose one of those choices, the two original devices were still the only choices I had. None of my new devices were listed as possible devices to include in the routine.
How do I get the new devices to show up in my list of “Things” that I can use in a Routine?
I first added two devices; an echo link door and window sensor, and a GE Plugin smart dimmer. I created a routine that when the sensor was open, the light plugged into the dimmer would come on. I deleted that Routine. I created another routine to just turn on the light.
A day later, I added another smart dimmer, another door and window sensor, and a smartthings multipurpose sensor.
All 5 devices show up in my “Things” list.
When I go to create a new Routine, my choices are:
turn on these lights and switches
Turn off these lights and switches
Set Smart Home monitor to.
4 Change mode to.
Then some additional settings.
Automatically perform routine
rename routine
When I choose either 1. or 2. above, The only devices, or “Things” that appear that I can control are the two GE dimmer controls. Further, they are still named a different name than what they are now. It is like nothing updated in the software when the additional items were added. There is no listing of either of my door and window sensor or the multifunction switch.
When I created the Routine that I deleted at first, there were more options than just turning on or off a switch. How do I get the software to “see” my other devices, and the Routine choices to give me more options than I currently have.
As with many things, SmartThings is both versatile and powerful, but unfortunately is neither intuitive nor very discoverable. But you can always just ask in the forums if you get stuck. We’ve all been there.
