Devices that work with a fan controller
I have a ceiling fan where I can install a controller so it can be controlled by a single switch fan/light combo. Is there a switch that comes with a module to put into the fan that will integrate well with ST?
Thanks,
Joe
Unfortunately not, the only known module as such is the Insteon FANLinc module which doesn’t use ZigBee or Z-Wave, so not compatible with ST as such.
That being said you can technically connect an Insteon hub and there is community created code that connects to it but I don’t think it has been made to work specifically with FANLinc yet.
Do they make a smart switch for Fan/Light control in a 1 gang box like this:
http://ecx.images-amazon.com/images/I/51t0NHgEoWL.SL1000.jpg
I think I can run a wire pretty easily however I only have a one gang box at my disposal.
what about using 2 micro controller/switches at the fixture for both the light and fan?
That’s a possibility. Would a fan/light combo faceplate connect to 2 micro-controllers and allow for manual and automated settings?
